#1 Posted : 04 August 2012 20:42:00(UTC)
Is there a way to remove debris of glue of a sticker from a loco shed without destroy the paint?Any help will be appreciated,thank you very much.
Offline Unholz
#2 Posted : 04 August 2012 22:34:02(UTC)
Unholz
I generally take a new (unused) piece of sticky tape (the glossy variety) and remove the remains of the previous sticker by lifting it off with rapid up-and-down movements. Perhaps a bit difficult to describe in words, but the action transfers the remains of the old sticker to the piece of tape in your hands. After a while, take a new piece of adhesive tape and repeat the operation until the last remains have disappeared.
You can also try to soften the remains with a diluted solution containing alcohol (for instance an after-shave) and wipe them off.
Sorry, I can't accept any claims in case of damage to the roof. Wink
Offline Markus Schild
#3 Posted : 04 August 2012 22:34:34(UTC)
Markus Schild
I use this product and I'm very satisfied:
MELLERUD Aufkleber und Klebereste Entferner (remover for stickers and sticker-glue): http://www.mellerud.de/d...g/product/view/1225.html
They also have a Greek page: http://www.mellerud.de/d...tional/griechenland.html
Markus
Offline Ausipeet
#4 Posted : 05 August 2012 01:09:04(UTC)
Ausipeet
try some fresh lemon jiuce or even fresh orange jiuce
thanks 1 user liked this useful post by Ausipeet
Offline GTSE800
#5 Posted : 05 August 2012 02:25:18(UTC)
GTSE800
WD-40
GTSE800
thanks 1 user liked this useful post by GTSE800
#6 Posted : 05 August 2012 05:56:02(UTC)
Thank you very much,all off you.
Offline Besra
#7 Posted : 05 August 2012 10:22:18(UTC)
Besra
I think WD-40 is a good idea. It's main component should be kerosene, so you may take that also (be careful kerosene is called differently throughout the world: It is kerosene in the US, paraffin oil in the UK, Petroleum in German). Lamp oil and smoke fluids (e.g. from Seuthe) are the same stuff.
Leave it on for few minutes then you should be able to remove the debris easily.
Besra
thanks 1 user liked this useful post by Besra
Offline kskato
#8 Posted : 05 August 2012 18:10:43(UTC)
kskato
Goo-Gone may only be a N.A. product.
But that's what its made for.
thanks 1 user liked this useful post by kskato
Offline guiverc
#9 Posted : 14 August 2012 16:20:49(UTC)
guiverc
If problem not solved Eucalpytus oil is very good at dissolving glues & the muck left behind from stickers (and smells much better than kero/wd40...)
I'm not aware of it damaging paints, but no warranties provided ....
Chris g.
thanks 1 user liked this useful post by guiverc
This page was generated in 0.338 seconds.
