Offline FrankF
#1 Posted : 09 February 2012 01:01:06(UTC)
FrankF
The USB Version of the Marklin CS2 Update V2.0.1 is ready for download on Marklin's site.
A new Document with Information about the Marklin CS 2 CAN Protocol (v2.0) is also on the website for Download.
Link : Marklin - Software Update
CS3+ 60216 ( SW:2.5.2 ) / CS2 60215 ( SW:4.3.0 ) / MS2 60653/57 ( SW:4.28 ) / MS1 60652 ( SW:1.8 AP ) / 60883 S88 LINK ( SW:1.1 )
MDT 3 (SW 3.6.0) - HW: ( 60970 / 60971 / 60801 ) & ESU LOKPROGRAMMER ( SW 5.2.12 ) / ESU HW: 53451 / 53900 / 53901
thanks 1 user liked this useful post by FrankF
Offline Oscar0645
#2 Posted : 02 August 2012 22:35:45(UTC)
Oscar0645
BigGrin
Thanks for info.
Unable to determine which one the CS2 v2.0.1 download is in the list on the website you mention.
Please advise
Cheers Bruce
Offline FrankF
#3 Posted : 02 August 2012 23:02:38(UTC)
FrankF
Hi Bruce
If you want the 2.0.1 version for your CS2 download the "file" called :
cs2update.tgz (5.694,83 kb)
which is the same version which is placed on Marklin's Online-Server when you connect your
CS2 to the Internet at the moment.
If you wish to take a look inside the cs2update.tgz-file download this program and install it :
TotalCommander (Website : http://www.ghisler.com )
Once Installed you can double-click on the file to see the content of the packed .tgz file.
You should also try taking a look at the interal Webserver running in your CS 2.
Use the IP-Address you have setup to be used with your CS2 and enter that in a Webbrowser (Internet explorer / Firefox or other Browsers)
Example :
http://xxx.xxx.xxx.xxx (replace the xxx.xxx.xxx.xxx with the IP-Address which your own cs2 has been setup to use) and press ENTER.
Offline Oscar0645
#4 Posted : 03 August 2012 10:45:46(UTC)
Oscar0645
BigGrin
Hi Bruce
Example :
Thankyou for that info. The update worked perfectly. I had the V1.6 in my CS2 and it was not sufficient to run the new I pad app.
All up and running. I now have to get used to having an I pad in my hand at times.
Cheers Bruce.BigGrin
Offline FrankF
#5 Posted : 03 August 2012 11:05:07(UTC)
FrankF
Hi Bruce
Nice that you got it to work with your Ipad.
If you need "more" help with Marklin Mainstation App and the Ipad just send me a mail.
Remember that if you insert (draw) your track-layout under the "Layout" part on the CS2,
the Ipad can show up to 25 x 40 fields without you having to scroll up/down and around on the Ipad
to see the whole layout.
My Track-layout is managed with 4 pages (for the tracks) and 6 other pages on the Ipad for the stearing
of 4 x 7051 Cranes / 7294 Transfer Brigde / 7286 Turntable and with a 2 special pages for the S88-contacts
allowing me to monitor up to 128 feedbacks on the IPad.
Offline Danlake
#6 Posted : 03 August 2012 23:09:09(UTC)
Danlake
I must be blindConfused
But I can only see USB download version 1.6.4 tgz file on Marklin website...Crying
Brgds - Lasse
#7 Posted : 03 August 2012 23:37:26(UTC)
As Frank wrote: the latest version has no version number in the file name:
Offline RUBEN SPAIN
#8 Posted : 04 August 2012 20:15:51(UTC)
RUBEN SPAIN
You can try to update by Internet Connection. So you are sure the latest software is installed.
Offline Danlake
#9 Posted : 06 August 2012 23:15:06(UTC)
Danlake
Well I tried updating my CS2 with 1.6.4 tgz file (which is 18mb) from Marklin website.
With this file the CS2 got updated to version 1.6.4 and not 2.0.1
Did anyway manage to update CS2 to version 2.0.1 with USB stick only?
Else I guess only option is the internet thingy.
Brgs - Lasse
Offline Fredrik
#10 Posted : 07 August 2012 00:40:55(UTC)
Fredrik
Click below to download the latest update:
Link to latest version of CS2 software
It's named: cs2update.tgz.
Fredrik.
WWW: MJ-fjärren
thanks 1 user liked this useful post by Fredrik
Offline Danlake
#11 Posted : 07 August 2012 05:05:05(UTC)
Danlake
Ups - I got it now.
Should have read the post more carefully...
Thanks - all working nowBigGrin
Brgds - Lasse
Offline Oscar0645
#12 Posted : 09 August 2012 09:30:36(UTC)
Oscar0645
Brgs - Lasse
Hi, Yes I did manage to update using stick to 2.0.1. No problems at all.
Cheers Bruce
#13 Posted : 09 August 2012 09:31:58(UTC)
Hi Bruce,
Welcome to the forum.
Offline Oscar0645
#14 Posted : 21 August 2012 23:34:47(UTC)
Oscar0645
Hi Bruce,
Hi Steven,
This maybe a topic you have discussed in the past.
Marklin Turntables
I have had 7286 for a ouple of years and have decided to go digital with a retrofit kit 7687.
Wired up Ok ( although tried to use another transformer to operate the turntable only..didn't like it) all via the CS2.60214
Did the programming and so far so good. Turntable is operating.
Have only 7 spokes and I have programmed those in of which one is No1.
Operation:
Can step through and TT will go to first programmed spoke. Press again and it will go to next one and so. That's OK
Will do a 180.
I can press No1 on the CS2 Keyboard and it will return direct to this position.
What it doesn't do is : If I select a programmed spoke it does not go direct to it. According to manual it should. Is there something more I need to do or haven't done?
Next Question: Can I run the TT operation with another transformer Like I did with the analogue?Smile
This page was generated in 0.679 seconds.
