Offline Ian555
#1 Posted : 29 May 2012 10:38:30(UTC)
Ian555
We just bought the Canon EOS 600D camera, can you suggest a suitable lens for close up photo's.
Thanks.
Ian.
Offline DigitalNZ
#2 Posted: : 29 May 2012 11:55:08(UTC)
DigitalNZ
Evening Ian.
I've been a bit slack lately with commenting on anything, but this post however took my eye! Excellent choice!
Did you but the camera body only or with one of the lens kits? We have the twin lens kit with the 18-55 and the 55-250mm, I personally use the 18-55 and used that in my train photos that are in this section.
Daniell
Offline Ian555
#3 Posted : 29 May 2012 12:20:41(UTC)
Ian555
Hi Daniell,
We have the 18-55mm lens, and I just wondered if a different lens would allow really close up photo's.
Ian.
Offline Ian555
#4 Posted : 29 May 2012 12:33:54(UTC)
Ian555
Took this photo yesterday at 19.30, lights on in the cabin, but the flash automatically came on for the photo, so not enough natural light for the camera.
As you can tell, still a beginner. Smile
Ian.
Uploaded with ImageShack.us
#5 Posted : 29 May 2012 14:51:25(UTC)
Ian,
It took me a while to get used to my Sony camera and the zoom is still to fast for me or to have the time and feel for it to expand or retract the zoom smoothly.
I've got a canon camera but the shutter is not working anymore and to replace it I thought I better buy a digital camera body instead and use the lenses I've got.
Offline Ian555
#6 Posted : 29 May 2012 15:27:44(UTC)
Ian555
Hi John,
As with most things in life, it will take time to get used to it. Smile
Ian.
#7 Posted : 29 May 2012 15:40:52(UTC)
Hello Ian and all.
Your kit lens is all you need for train pictures.
It focuses close enough to cover the whole field, and capture the details you want to show.
IMHO, no need for a macro lens.-
Now, it is just a matter of learning to use your camera in "manual" (or semi manual mode)
First disable the build in flash, use ambient light.
Use the A mode (aperture priority, and turn the aperture (aka "diaphragm") down to 16 or even 22. This will maximize the depth of field
Adjust the sensitivity to 200 asa or less, as to ensure best signal/noise ratio (i.e. minimize "snow")
Select the "automatic white balance" setting, as to ensure proper color rendition.
You will often need exposure time of several seconds, therefore mount the camera on a tripod and use a flexible release cable, or a remote or the camera build-in timer , as to avoid shaking on long exposures.
Take a few shots and you'll see the difference....
Good luck!
Offline Ian555
#8 Posted : 29 May 2012 15:53:29(UTC)
Ian555
Hi Jacques,
Thanks, plenty information there to get me started. ThumpUp
Ian.
#9 Posted : 29 May 2012 18:14:31(UTC)
I have Nikon lenz 18-55 which was as kit.
This lenz allowed at least 28 cm to snapshoot close pictures.
If you really wants extrem closeup pictures i suggest macro lenz to buy.
But it´s not neccesary...
Offline Ian555
#10 Posted : 29 May 2012 18:21:57(UTC)
Ian555
Hi Anders,
Thanks. ThumpUp
Ian.
Offline DigitalNZ
#11 Posted : 29 May 2012 21:33:18(UTC)
DigitalNZ
Hi Ian,
I usually use either Aperture priority or shutter priority mode (Av and Tv) and lock it on a tripod. The manual modes automatically disable the flash and let you select either shutter speed to freeze or blur motion or aperture to control your depth of field.
I'd suggest putting the camera on live view mode if you want to get an idea of composition and what the white balance looks. The changes will appear instantly, I think I used the shade or cloudy setting for my profile picture.
Daniell
Offline NewMB
#12 Posted : 29 May 2012 21:42:10(UTC)
NewMB
A superb lens for Canon's are their own EF 24-70/2,8 L USM or EF 17-40/4L USM.
Saying that, the lens kit that comes as standard (most of the times it is the EF-S 18-55/3,5-5,6 IS II) is actually really really good though.
Offline Ian555
#13 Posted : 29 May 2012 21:50:04(UTC)
Ian555
Hi Daniell,
Thanks, will try all of this thro' the week.
Ian.
Offline Ian555
#14 Posted : 29 May 2012 21:51:38(UTC)
Ian555
Hi Patrik,
Thanks. ThumpUp
Ian.
Offline BrandonVA
#15 Posted : 29 May 2012 22:16:54(UTC)
BrandonVA
I agree, Canon and Nikon's 18-55mm lenses are great, I have owned/own both. Very close focus, very sharp. I think in this case a macro lens is not really necessary unless you find that the 18-55 is still limiting you after you nail down the technique.
-Brandon
#16 Posted : 29 May 2012 23:47:13(UTC)
In addition I would go for a Canon EF-S 60mm f/2,8 macro usm
Very good for close range photo and it has a relatively large aperture opening (2,8), so maybe the flash is not needed. But a good tripod is, or a stable place to rest the camera.
see http://www.the-digital-picture....cro-USM-Lens-Review.aspx
Offline Ian555
#17 Posted : 30 May 2012 07:26:58(UTC)
Ian555
Hi Brandon,
Thanks. ThumpUp
Ian.
Offline Ian555
#18 Posted : 30 May 2012 07:28:29(UTC)
Ian555
Hi Svein,
Thanks for the information and also the link. ThumpUp
Ian.
#19 Posted : 30 May 2012 11:30:17(UTC)
Hi Svein and all
Yes and no...Wink
In the case of model photography, a large aperture may dispense of the flash or even dispense of a tripod, but....at 2.8 your depth of field will be very shallow.
I agree it is often an advantage in macro photography, since you can get all the attention on the main subject, while the background is blurred in a nice bokeh.
(FYI, my Olympus 4/3 Macro lens is a 50 mm, that even opens at 2.0 and does just that)
But for model RR photography, you will often want the *deepest* DOF possible to "sharply" show details that are not all in the same plane.
This can only be achieved by using the smallest possible aperture like f16 or f22) when you are at close range.
Of course there are as many ways to shoot pictures as there are photographers and "blurr" can sometimes be very "artistic" !BigGrin Wink
Offline NewMB
#20 Posted : 30 May 2012 20:47:19(UTC)
NewMB
I have this lens and I can concur, it's seriously good!
Offline Shintaro
#21 Posted : 04 June 2012 09:41:28(UTC)
Shintaro
Hi, Ian.
We have the same camera.
Best option for close-up would be a 50mm f/1.4
Offline Marius in Africa
#22 Posted : 04 June 2012 19:23:42(UTC)
Marius in Africa
Hi Ian
Indeed these lenses which Patrik recommends are excellent. The EF24-70 2.8L (refered to as a standard zoom lens) has now been replaced with version II. I still have version I and have no intension of changing it for the II. Attached is a picture taken with a 600D & an EF 16-35 2.8L II (refered to as a wide angle lens).
If you want really close up pictures you may have to invest is a dedicated macro lens. Canon have a few of these. http://www.usa.canon.com...s/cameras/ef_lens_lineup
Marius
Marius in Africa attached the following image(s):
Marius in Africa
Offline Ian555
#23 Posted : 05 June 2012 08:09:28(UTC)
Ian555
Thanks for the information. ThumpUp
Ian.
Offline pab
#24 Posted : 05 June 2012 21:11:14(UTC)
pab
Lots of good advice.
I mostly use my standard lens, which is an EFS 15-85.
For details I use a macro lens (EF 100 mm, 2.8). Very nice for close up details for both trains and scenery.
Normally with a small aperture (F/22 or higher), but in special occassions it's good to focus on the subject, use a large aperture and blur the background.
Most of the time with long exposure times with the help of a tripod or an other stabile platform. Avoid the flash, but never say never.
If you use the available light you may experience dark spots in the picture, unwanted shadows or too much light on the top, caused by the light on the ceiling or the sun peeping through a window. That's were you use your reflection screens. You can buy those in a shop, but a piece of white cardboard will do for a start. You can place the screen between the lights and the subject but also bring some extra light to the wheels or something like that.
I mostly don't use the A preset, but I use the M (=manual) setting.
Take a number of shots with different exposure times and maybe different use of reflection screens and pick the best one.
Edited by user 06 June 2012 10:48:24(UTC)  | Reason: Not specified
#25 Posted : 06 June 2012 00:26:48(UTC)
All this talking about focal length is interesting.
But, it might be meaningless for people without a photo background or hobby.
What do all the numbers mean?
In this case, the focal lenght massurement is based on cameras with 24x36mm film size, so called 135 film format.
50 mm focal lenght gives the same magnification as the human eye (1x magnification). A 50 mm iens is therefore called a normal lens.
Below 50 mm is wide angle lenses, the lower the number the wider the angle.
Above 50 mm is tele lenses. A 100mm lens gives 2x magnification, 200 mm 4x, 400mm 8x and so on. Compare with binoculares.
But, today most digital single lens reflex cameras has a sensor which is smaller than 24x36mm.
Canon EOS 600D has a so called APS-C sensor, 14.9x22.3 mm, 1,6 times smaller than 24x36 mm.
Cameras with 24x36 mm sensor size are called Full Format (FF) cameras. My Canon EOS 5D is a FF camera.
1,6 is is the so called the "crop factor" for APS-C sensors.
Therefore the old magnification scale must be altered, as we don't use the whole image size.
With a APS-C sensor will a 50 mm lens give the same magnification or viewing angle as a 80 mm lens with a FF camera.
A normal lens for APC-S cameras will be 50/1,6 = 31,25 mm.
A 35 mm lens is often concidered as normal lens for APS-C cameras.
Examples:
Canon EF-S 60 mm macro on a EOS 600D will give the same viewing angle as a Canon EF 100 mm macro on my EOS 5D camera.
Canon EF-S 10-22 mm on a APS-C camera gives the same angle as a EF 16-35 mm on a FF camera
This has no practical meaning when it comes to picture quality or viewing angle; what you see in the viewfinder or on the display is what the sensor records.
But, it is nice to know the difference.
See http://en.wikipedia.org/wiki/APS-C and http://en.wikipedia.org/wiki/Crop_factor
Offline Ian555
#26 Posted : 06 June 2012 12:00:53(UTC)
Ian555
Hi Svein,
Thanks very much for all that information, but, and it's a big but, it's all way over my head.
What settings should I use on the 600D to get me started, I don't really want to start this as another hobby, all I want is to be able to take good quality photo's of my Märklin.
Thanks and any help much appreciated.
Ian.
#27 Posted : 06 June 2012 17:25:36(UTC)
Ian555 wrote:
We just bought the Canon EOS 600D camera...
Did you buy the camera in a kit with a zoom lens?
Offline Ian555
#28 Posted : 06 June 2012 18:15:32(UTC)
Ian555
Hi Svein,
The lens I have is a 18-55mm efs.
Ian.
Offline pab
#29 Posted : 07 June 2012 11:01:59(UTC)
pab
Hi Ian
It's not so difficult as you may think. For he moment, forget all the information about the sensor measurements andd the cropfactor. That is important if you decide to buy another lens. If your camera won't focus automatically you're to close to the subject (or the subject is too dark).
To take a picture, use manual settings for the aperture. It's important to control your depth of field. With Canon it's the Av setting.
If you want less DOF, choose a low number (large aperture) e.g when you take a picture of a loco from the side, the whole loco has more or less the same distance to the lens, so less DOF could by enough. If you want the front and the side in a picture than you need to use a high number (small aperture) . Focus on 1/3 of the front.
For a landscape use a small aperture too.
Use live view to check your settings.
If the light is insufficient, swith to the M setting and use a longer exposure time.
Edited by user 07 June 2012 20:23:48(UTC)  | Reason: Not specified
thanks 1 user liked this useful post by pab
Offline Ian555
#30 Posted : 07 June 2012 13:29:08(UTC)
Ian555
Hi Piet,
Thanks for the information, will try those settings out over the weekend.
Ian.
#31 Posted : 07 June 2012 18:11:13(UTC)
Hi Ian
I agree with Piet.
When people ask me what kind of lens they should buy, I ask them what the miss with their excisting lens.
Get used to the 18-55 zoom lens and it's possibilities, play a little bit with different appertures and shutter times, as well as focal length.
When they find out what they are missing, it's time to look at an additional lens.
But, for real close-ups, I would still recommend the EF-S 60 mm macro.
I use my EF 100 mm macro (with my camera the same viewing angle as your camera and 60 mm) a lot, for all kinds of pictures.
Offline pab
#32 Posted : 07 June 2012 20:21:51(UTC)
pab
Hi Piet,
Ian.
Just to see how it works. Take a white sheet of paper and hold it in different angles for the subject. You could be amazed about how more (or less) light you can have on the subject.
And ir's digital camera, so extra pictures with different settings costs nothing but time BigGrin
You can also use your display to check the pictures. If you want to know if it is sharp enough, zoom in as much as possible.
Edited by user 08 June 2012 22:01:46(UTC)  | Reason: Not specified
Offline Mark5
#33 Posted : 08 June 2012 04:09:46(UTC)
Mark5
I have a Canon 40D and have been thinking of getting the Mark II (much cheaper than the new Mark III for starters, anyone have this?) ...
so the question of lenses interests me... when tied to the resulting images... so I am curious to see the results of layout photos with the lenses that people are recommending.
Anyone?
- Mark
Offline NewMB
#34 Posted : 08 June 2012 11:53:02(UTC)
NewMB
Anyone?
- Mark
Here's an example of 350D using a 18-55mm lens (no IS!!). Aperture is f/5.6, Focal 55mm, ISO speed 125 and no flash:
18-55mm, Ap f/5.6, Focal 55mm, ISO speed 200 and no flash:
Not so good light (was learning at the time) with some very different settings... Ap f/18.0, 43mm, ISO 200 and no flash (tripod):
One with a longer Exposure time, using a Tripod. F/36.0, 45mm, ISO 800 and no flash:
Then we have the Canon "L" glas which is there best ones.... this one is taken, handheld (!) using a 17-40mm L-glas, AP F/4.0, 27mm, ISO 400, no flash.
I do also have some Macro pics using my EF-S 60mm macro lens, but not uploaded them on flickr yet.
thanks 1 user liked this useful post by NewMB
Offline Ian555
#35 Posted : 08 June 2012 18:54:42(UTC)
Ian555
Hi Patrik,
Great looking photo's. ThumpUp
Ian.
Offline BrandonVA
#36 Posted : 08 June 2012 19:33:01(UTC)
BrandonVA
Patrik,
This one brings back memories! (Sorry to be OT).
-Brandon
#37 Posted : 09 June 2012 16:01:06(UTC)
MM-MarkMontreal wrote:
I have a Canon 40D and have been thinking of getting the Mark II...
Are you talking about the 5D MkII, Mark?
#38 Posted : 09 June 2012 16:02:46(UTC)
Nice photos, newMB!
Offline pab
#39 Posted : 10 June 2012 10:40:11(UTC)
pab
The night picture is great
#40 Posted : 10 June 2012 10:42:20(UTC)
Great pictures, NewMB.
#41 Posted : 10 June 2012 18:42:52(UTC)
I suggest the new one 5D MkIII.
One of the best in the market...but the prices is high!
Offline NewMB
#42 Posted : 10 June 2012 20:00:30(UTC)
NewMB
Hi Patrik,
Ian.
Thanks Ian. Gives you an idea of what even the simple things can do.
Patrik,
-Brandon
I love HK and simply can't get enough of the place.
Nice photos, newMB!
Thanks alot!
Thank You very much!
Thanks alot Steven!
Offline Shintaro
#43 Posted : 16 June 2012 01:54:10(UTC)
Shintaro
Love the pic of Victoria Harbour, HK, it brough back alot of memories from when I was there.
Guest (7)
This page was generated in 0.941 seconds.
