Offline perz
#1 Posted : 01 July 2007 01:12:30(UTC)
perz
Henrik (hxmiesa) has shown us how to build the ultimate stone arch bridges https://www.marklin-users.net/fo...ault.aspx?g=posts&t=5533.
The alternative if you are too lazy to engrave the stone pattern yourself, is to use ready-made stone-plate imitations. I am usually too lazy to do any scratchbuilding at all, but sometimes there is no ready-made model that fits your need. I needed a bridge for the C-track R9 curve, so I had to build it myself. I used cardboard and the "Heki-Dur" foam stone-plates. The result is not really as good as what Henrik achieved, but good enough I would say. The Heki-Dur material is very easy to work with, and in my opinion it gives a much better result than the plastic or cardboard stone-plate imitations. Here is a picture of the bridge. Final painting and weathering still remains to be done.
thanks 1 user liked this useful post by perz
#2 Posted : 01 July 2007 01:22:07(UTC)
WEll done Perz. Bridge looks good to me. R9 curves are great if you have the room for them.
David
#3 Posted : 01 July 2007 02:27:38(UTC)
Fantastic job Per. The bridge looks very authentic to me.
Offline ulf999
#4 Posted : 01 July 2007 12:31:40(UTC)
ulf999
Lazy is good (as long as it gets the job done Smile). Great result!
#5 Posted : 01 July 2007 13:05:43(UTC)
Count me in... This looks like something within my skill limitations.. Thanks Per...
Offline Rowan
#6 Posted : 01 July 2007 13:26:53(UTC)
Rowan
Very nice mate,looks cool!
Smile
#7 Posted : 01 July 2007 18:54:34(UTC)
Looks excellent to me!
Regarding my walls and bridges; I´m not rellay THAT happy doing it "the hard way", but as I need tons of walls, and I am too "cheap" to dish out dough for things I can do myself almost at no cost, well... I went the way of the plaster and engravings.
Your bridge, and also the one Almagic showed some time ago, proves there is no reason to go the "long way around" to get things done.
Two thumbs up! ;-)
Offline rschaffr
#8 Posted : 01 July 2007 20:21:05(UTC)
rschaffr
Looks fine to me. Certainly better than my hand scribed and painted styrofoam as seen here
Edited by moderator 22 November 2012 09:28:59(UTC)  | Reason: Not specified
-Ron
Offline ulf999
#9 Posted : 01 July 2007 22:32:41(UTC)
ulf999
Not bad at all Ron!
Offline rschaffr
#10 Posted : 01 July 2007 23:39:30(UTC)
rschaffr
Thanks, but it is not in the same class of work as Henriks or Perz. However, when I put some scenery around them they don't look too bad. I need to to more at the top..should flare out some. Actually they are a little darker than the picture shows (it is Woodland's Slate Gray). I have two installed in mountain faces but they are currently masked for painting the mountain. I'll try to get some pictures when I unmask them.
-Ron
#11 Posted : 02 July 2007 01:09:01(UTC)
Good job Ron. You must have a lot of patience doing these bricks by hand.
David
#12 Posted : 02 July 2007 13:42:29(UTC)
Hi Ron,
That styrofoam scribing sure looks OK.
Quick too.
Offline rugauger
#13 Posted : 02 July 2007 15:00:36(UTC)
rugauger
Yep - I'd be more than happy with that! Nice work, Ron.
Richard
Offline rschaffr
#14 Posted : 02 July 2007 16:35:38(UTC)
rschaffr
Thanks. It all came as an inspiration. I had a dual track on my layout that was a little too wide for the Kibri double tunnel face. I was wondering what to do, and sitting on my workbench was a sheet of one inch Woodlands landscaping styrofoam, so I tried it. Under close inspection, it doesn't look as good as the work done by the others here, but when it is in place and the other scenery around, they look fine.
-Ron
Offline mmervine
#15 Posted : 12 March 2008 01:49:38(UTC)
mmervine
In both cases, after they are weathered and installed on the layout they will look awesome! Great job to both of you!
r/marj
Offline petestra
#16 Posted : 22 November 2012 00:36:45(UTC)
Great work! PeterBigGrin
Offline charles Sharpe
#17 Posted : 22 November 2012 06:36:27(UTC)
charles Sharpe
Nothing wrong with that keep up the good work.
Charles.
CHARLES SHARPE
Offline kariosls37
#18 Posted : 23 November 2012 09:44:48(UTC)
kariosls37
Great bridge buildingThumpUp I too am lazy, and will only resort to hand carving when all other option have been exhausted.
Offline Mark5
#19 Posted : 24 November 2012 20:45:58(UTC)
Mark5
http://www.sem-co.com/~r...ins/images/stonearch.jpg
Ron,
I'd like to see another photo of that if you ever painted and weathered.
Curious to see final result.
- Mark
Offline Danlake
#20 Posted : 24 November 2012 21:04:49(UTC)
Danlake
Fantastic Job Per!
Can't wait to see it all finished.
Brgds - Lasse
#21 Posted : 25 November 2012 10:24:50(UTC)
Looking good, Ron.
This page was generated in 0.998 seconds.
