Offline TrainIride
#1 Posted : 09 May 2012 14:06:24(UTC)
TrainIride
Hi everybody,
I've found on ebay a nice Br18 without box.
I was almost convinced it was a #3093,
but I've heard about the #3091 number (this number that was re-used after for a blue P8)
So, please help me to identify my model.
Don't hesitate to post pics of these two Br18 to show the differences.
Here's mine:
Edited by user 13 May 2012 21:49:03(UTC)  | Reason: solved - thanks my friends
Offline TrainIride
#2 Posted : 09 May 2012 17:43:23(UTC)
TrainIride
Seen on the web:
#3091 equipped with a smoke unit
#3093 not equipped with a smoke unit
Is it true ?
Strange to have only this difference....
Offline Ian555
#3 Posted : 09 May 2012 18:06:38(UTC)
Ian555
Hi Joël,
I have boxed 3093 number 18. 478.
Couple of photo's soon.
Ian.
Offline Ian555
#4 Posted : 09 May 2012 18:18:29(UTC)
Ian555
Hi Joël,
Couple of photo's.
Ian.
Uploaded with ImageShack.us
Offline Ian555
#5 Posted : 09 May 2012 18:24:33(UTC)
Ian555
Hi Joël,
Forgot to say, there is no smoke unit fitted to my 3093.
Ian.
#6 Posted : 09 May 2012 18:31:55(UTC)
However no smoke generators on 3093 - Koll 2012.
Offline TrainIride
#7 Posted : 09 May 2012 18:43:42(UTC)
TrainIride
Ian and Stephen,
Thank you so much.
Let's have a look at the inside of my lady:
looks like the bended metal part upon the bulb in front of the reversing unit
is there to feed a smoke generator...
Do you agree ?
There is a hole in the chimney but I don't have any smokey thing else:
Offline Yumgui
#8 Posted : 09 May 2012 23:02:35(UTC)
Yumgui
Joël,
While I own several BR18s, I don"t have either of these great looking locos but from Koll's 2011 (und mit meine sehr, sehr schlecte Deutsch ...^^) I see the following;
3091.1 : has a smoke generator and a road number shield on the boiler which is 5mm long ...
3091.10 : as you pointed out ... is the blue version with different road number ...
3093.1 : same as 3091.1 without smoke generator
3093.2 : road number shield on the boiler which is 8mm long ...
3093.3 : (not sure about this one) smooth cylinder with printed factory shield .. I think this is lower left in the pix ^^ ?
I'd say ... first thing to check is the length of the road number shield on the boiler, if it's 5mm, and knowing you have a smoke generator, then your loco is probably a 3091 !
I agree it's not much difference, but at least you will know ^^ Wink
See below for Koll's 2011 comparisons ...
Hope it helps,
Yum Tongue
Edited by user 10 May 2012 07:42:25(UTC)  | Reason: Bad German ;)
Offline petestra
#9 Posted : 09 May 2012 23:58:29(UTC)
Hi Yum, yes here are some photos of my 3091.1. The box is dated 03 72. I probably bought it later
that same year, new. Peter
Offline TrainIride
#10 Posted : 13 May 2012 21:36:41(UTC)
TrainIride
Joël,
Hope it helps,
Yum Tongue
Hi Yum,
Thank you so much !
I've measured the "road number shield on the boiler" and you can see it on the pic after:
the two vertical lines on the paper are spaced of 5mm,
...so the shield is a 8mm one
...so my Br18 is a 3093.2
You solved my question !
By the way I've downloaded the Schematics of the 3093 and saw the bended metal part
above the front bulb. #29 "Federplatte". Looks like a smoke generator could be installed
even if it was the no-smoke version Unsure .
Still a bit strange ...
Joël
Offline TrainIride
#11 Posted : 13 May 2012 21:43:51(UTC)
TrainIride
Hi Peter,
Thank you so much for your pictures.
I'm now sure of the number of my model.
Best Regards
Joël
This page was generated in 0.481 seconds.
