Offline biedmatt
#1 Posted : 01 May 2012 01:51:05(UTC)
biedmatt
My 1st post. I got my layout for Christmas 1972 and have played with it off and on since then. I was an early digital buyer, getting my 6020 Central Unit from the dealer on Christmas Eve 1986.
Anyway, I am converting a 3001, the one from the 125th anniversary set 2874, to digital operation. I have the 60903 motor conversion set, but need to know which decoder to get. It must be small and work with my 6021 control unit. Directional lighting is the only other feature the decoder must have. Does anyone have a suggestion?
Matt
Era 3
Offline franciscohg
#2 Posted : 01 May 2012 02:32:07(UTC)
franciscohg
Chile
Hi, welcome to the forum, i have used lokpilot 4.0 to do the conversion. Works fine...
Offline 3rail4life
#3 Posted : 01 May 2012 06:04:02(UTC)
3rail4life
Welcome to the forum, the decoder from the the 60760 kit is also a good choice for your locomotive as well and can be found sold separately on ebay.de for decent prices, or also sometimes on US ebay as well.
Gordon
Offline biedmatt
#4 Posted : 01 May 2012 12:19:38(UTC)
biedmatt
Thank you for the replies. I was not familiar with the 60760 conversion kit. Is it meant to convert the SFCM?
Matt
Era 3
#5 Posted : 01 May 2012 13:57:50(UTC)
The 60760 kit is for DCM only. Many people keep the motor parts and sell the decoder on eBay.
It's a basic decoder.
You can go for the 60942 decoder "mLD" from Märklin (a 60942 without motor parts is as expensive as the 60760 with decoder and motor parts).
Personally I prefer ESU decoders.
A CU 6021 is somewhat limited. ESU LoPi and mLD will still be better than a 60760 even with a CU 6021. They'll make a bigger difference if you even switch to a more modern controller.
Offline 3rail4life
#6 Posted : 01 May 2012 17:47:57(UTC)
3rail4life
biedmatt,
Tom "HO" is right about the decoders, both the mLD and the ESU are better decoders, I recommended the 60760 decoder from the kit, because it is one of the more cost effective solutions for a basic decoder with directional lighting and it will work well with your 3001 using the motor from the 60903 kit. Which ever way you go, it is also a good idea to change the lights and sockets to provide for ground return to the decoder. You did not mention if you had the decoder from the 60903 or other locomotives to convert but if you do, the then the 60760 kit makes sense, since you can then use the left over motor parts with the 60903 decoder in something like a steam engine with the smoke function or telex for example.
Gordon
#7 Posted : 01 May 2012 19:03:54(UTC)
Hi biedmatt,
Welcome to the forum.
Offline biedmatt
#8 Posted : 01 May 2012 21:41:39(UTC)
biedmatt
Thanks everyone for your input and the welcome.
A typo on my part. I have the 60943 motor conversion that comes without the decoder, hence the request for decoder info. The LokPilot decoders are readily available at Ebay and the price is fair enough. I'll give one a try and report on how I do once it is finished. I am afraid I will like it too much though, I have two dozen other engines with the old 6080 decoder. I would hate to feel the need to update them all.
Matt
Era 3
#9 Posted : 01 May 2012 22:17:17(UTC)
You know, once you get bitten by the bug of running everything smoothly - you will upgrade the 6080 ones too eventually since they will look inferior to this new conversion...
Believe me, you will get less tolerant with the old 6080 decoders when you see how well a loco can really perform... BigGrin
Better plan for it within your train budget... Been there - doing it myself at a slow pace....
Offline franciscohg
#10 Posted : 01 May 2012 22:39:05(UTC)
franciscohg
Chile
absolutely right..
#11 Posted : 02 May 2012 05:18:58(UTC)
I have a thought (rare but there you go).....
Who would be interested in a chart compiled and contributed by members of successful conversions?
I have to admit this is a daunting area for me. I don't have many loco's, but the ones I do have I would like to put Decoders into many of them.
Some of mine have 6080 decoders, and they work ok, but I wonder what I might be missing out on in performance or smooth operation with a better decoder, either a newer Marklin unit, or one of the many other units?
What I envisage is really something like a simple spreadsheet, with the Marklin model number in the first column, the motor type in the second column, the decoder installed (make, model), and then any additional relevant info such such as functions, features etc. I would probably think it helpful to add WHY that particular decoder was chosen, especially if others would also work - cost, availability, performance, size, tech info, reduction of noise etc etc
What I (personally) find really hard going is trying to find the info on a conversion that has probably been covered before, so I would tend to simply ask the question again and risk the 'RTFM' flames, than have to try to search through all the threads and risk missing something helpful.
Alternatively, how would others feel about ALL conversion questions having their own folder or topic - presently they are mostly listed under 'Digital', along with a heap of other non-conversion threads.
The 'sticky' "Motor-parts-for-digital-conversion-of-M-locos" is really helpful but I want to go a little further.
Something that might tell me that for a 3022 for example, Marklin Decoder X, ESU Decoder X, Uhlenbrock Decoder X, etc etc.
If a chart / spreadsheet was seen as too difficult or limiting, one other way I would find helpful is similar to above where we have a topic just for conversions, and then have threads within that topic relating to the item being converted. In other words, all discussions relating to digital conversion of a 3022 Austrian Crok would simply go into a thread or subject named "3022 conversion".
I am mindful of not just creating new topics for the sake of it, but it does seem to me that if anything/everything relating to digital conversions was grouped together, it might be easier for members and potential members to research and reference?
If a chart was felt to be better and can be implemented, how could this be done interactively within the forum so that it could be added to and edited (by verified members) easily?
Hope I have explained my goal clearly enough. I'm trying to get the information that already exists into a better cross-reference. If anyone has an easier way or better idea, let's have it BigGrin
Thoughts
Melbourne
#12 Posted : 02 May 2012 05:24:20(UTC)
By the way, in terms of a topic name, this actual thread that we are in now "Which Decoder", sums it up perfectly ThumpUp ThumpUp ThumpUp
#13 Posted : 02 May 2012 07:07:33(UTC)
You have been a member since:: 17/09/2006(UTC)
Motor type info for various locos is available on Helmut Kern's site, as is decoder information.
#14 Posted : 02 May 2012 07:33:35(UTC)
"Helmut Kern's site" ??
#15 Posted : 02 May 2012 08:08:31(UTC)
http://www.hfkern.gmxhome.de/
It is in German BUT nil knowledge will still give answers.
#16 Posted : 02 May 2012 08:56:37(UTC)
Thanks Nev, took a look at that site, not really much help to me and not what I was suggesting.
1: Site design prevents google translate from functioning
2: Only lists Märklin Decoders, but I suggested a cross-reference of all brands because as we are hearing so often, some of the alternative brands seem to be better value for money than the M. equivalent.
3: Appears only to list M. decoders factory fitted - NOTHING do do with conversions which was my whole point (not getting at you Nev) BigGrin - or have I missed something??
4: I HATE WITH A VENGEANCE, sites that bombard me with this bullshit.... (an insult to my intelligence, I mean who in their right mind would follow such a dumb-arsed link) Cursing Cursing Cursing Cursing
Frigging dickheads (the site I mean, not any of you lovely folks) Huh Huh
#17 Posted : 02 May 2012 09:05:39(UTC)
Hi Dave, ditto my reply to Nev.
Not really what I was proposing.
What I was suggesting/aiming for was a simple one-location reference to check a particular loco type for which decoders, (M. & non-M.) that others have used with success in that item.
Thanks anyway
#18 Posted : 02 May 2012 09:11:24(UTC)
Maybe not, but the site offers useful information on locos that you want to convert, before you convert them.
#19 Posted : 02 May 2012 10:50:09(UTC)
It's even simpler: you only have two know which motor conversion options there are.
If you convert the engine to a DC motor, you can use any decoder for DC motors.
If you leave the AC/DC motor in it, there are always the same options (that one Uhlenbrock decoder with load regulation or some Tams decoders without load regulation).
So there would be one chart with motor conversion options per Märklin ref. number.
And another chart with decoder options per motor type - and user experiences since some decoders work better than others.
The former chart already exists (compiled by a Danish site and available as PDF - will have to search for it if I find the time).
The latter chart would be new (unless I missed something).
#20 Posted : 02 May 2012 10:54:10(UTC)
Mr. Kern uses several free web space providers.
If you bookmark his Märklin loco page, you can always go there without stupid popups.
If people have problems with their "31234", I google for "märklin hfkern 31234" to find the class of the loco - this way also avoids the stupid popups.
Works for pre-2005 locos only (but locos from 2000 or later can be found in Märklin's product database).
Offline Tex
#21 Posted : 04 May 2012 00:16:12(UTC)
Tex
matt
I am operating with ESU locpilot (3), locsound (1) as well as Marklin FX (6) , mFX (1), and Delta (1) on my 6021 layout. All work well , however, speeds need to be adjusted manually as mFX and locsound locos need a higher setteing for same speed. The three locpilot engines are all on older Marklin engines with moter upgrades. The locpilot decoder is in a Brawa engine.
Richard
Offline biedmatt
#22 Posted : 08 May 2012 01:12:22(UTC)
biedmatt
Oh my that's nice.
I am waiting for the Marklin five comm armature kits to show up, so I ordered two ESU conversion kits with the permanent magnet for my 3048 and 3089. It looked like the LFCM kits would not work so I went with the ESU conversion kits. The slow running characteristics and quiet operation is truly remarkable. The toy like running properties the Marklin equipment had is gone. Now to program the addresses and functions. I bought the ESU programmer since this appears to be the start of a large project. I figured I might as well have it from the beginning. Thanks one and all for the help and recommendation to proceed with this upgrade. Can't imagine it getting any better, but I suspect the improved armatures will make them even nicer.
Matt
Era 3
#23 Posted : 08 May 2012 03:16:20(UTC)
anyone has any questions about converting locos can ask me.
over 20 years in the making from 6080 to 6090 to 60901, 60903 or 60904, the latter being replaced by new numbers.
Anybody byuing a conversion kit with a Maerklin decoder has to be a millionaire.
the cheapest way out, is a conversion kit without a decoder and than you decide, which decoder you fit to your loco.
And when you get this far things are becoming more complicated or choices of decoders come into the quotation.
Mr or Ms or Mrs. Biedmatt has opted for a conversion kit from ESU.
Well I haven't had any luck with programming a loco successfully with this conversion kit compared with a 5 star armature and an ESU decoder.
I'm slightly confused what the above member has achieved, bought or changed in his post.
An ESU conversion kit has the following important ingredients: 1 permanent magnet, 1 decoder. to change your current loco 3048, these are the 2 parts which will change your loco from analog to digital. When you talk about improved armature, ther is no improved armature, you have to use the current armature which is in the loco and the same goes for your 3089.
Another part which is re-used is your bruhsplate, so all in all, you are keeping 1/2 of the old motor with a large flat disk armature and the suitable brushplate.
If you thinking about, it can't get any better, only years of knowledge will convince you there are better things out there.
getting back to decoders:
although ESU decoders are popular, there are others on the market but it isn't just the decoer, it is the command station you are going to use will make all the difference for the future and especially when you are starting off new.
the most important part is what command station to choose from is:
how many locos are you intending to have
how big is your layout
how many sound decoders will you have
how many Lokpilots will you have
When you get a rough idea of the above components you than decide which command station is suited for you.
If your loco collection is on a small number or will stay small and there are no sound decoders involved and most of your current locos are analog, I would suggest ESU decoders and as you have already purchased a Lokprogrammer, this is a good choice.
Your 3048 loco for instance is not suitable for a 5 star armature conversion unless you do some work on the new brushplate itself, although you have taking this choice (ESU conversion kit) you did'nt have an other choice and the same goes for your 3089, you don't have another dhoice unless you alter the new brushplate (60904 (old number) 60944 (new number)
below is a conversion table
#24 Posted : 08 May 2012 04:25:59(UTC)
Thanks anyway
Hi Cookee,
Your first task is to convert the motor from analog to digital. I have posted an attachment on my previous post for locos suitable under the 60904 (60944) conversion kit.
there is also a 60903 (60943) conversion kit table but I can't find it at this moment and another one 60901 (60911) wich has a drum armature.
We've gone through this before, there are 3 main different motors und you can locoate or find the difference within your own loco
1.) motor with small flat(disk) armature
2.) motor with large flat (disk) armature
3.) motor with drum armature
there are several locos which would need some alterations, e.g. 3027, 3048, 3089 and some of the DB BR 212 locos and I think the 3001 (60903/60943) conversion set, I'm not going into details why at this moment.
When you establish which conversion motor set you need, you than can go one step further. as mentioned in my above post, it isn't only the deocoder but your overall requirement, e.g. how many locos you have or thinking of buying, hjow big your layout is and what type of functions you wish for and what is available for what use and what choices have you got.
There are many different options available with different decoder manufacturers and when choosing a particular decoder you have to be able to program them and when it comes to sound decoders you have to ahve a command station whereas you can apply all the sound slot functions.
So it isn't just about which decoder, it has a lot to do with the application you use.
For the connoiseur enthusiasts Zimo decoders are the way to go, for the most popular decoder it is ESU.
ESu offers you:
Multiprotocol decoders with the latest release: V4 M4, it can read most of the systems, e.g. mfx, RailcomPlus, old & new motorola, CS 2 and MS 2. (go to: http://www.esu.eu/en/pro...oksound/loksound-v40-m4/
with ESU decoders you have further options with the type of connections you need
a.) 8 pin wire plug
b.) 21 mtc connections with several adapterplates (extension of functions F3-F4) with a new one coming out soon (F5-F6)
ESU decoders are able for your loco to stop exactly at the signal every time regardless of the speed of your loco, for example if it is 5km/h or 200km/h. (braking module is required=there are cheaper ones than Maerklin on the market))
ESU decoders are fully programmable with the easy help of a Lokprogrammer.
You have a lot of options of programming your decoder or loco for your requirements, e.g. smoke generator adjustments, light adjustments (automatic high beam for instance when loco gets into motion without using an extra function to do so), Telex, Crois or Roco electric uncoupling device, you can adjust the time the uncoupler is activated = seconds.
RailComPlus is a more superior version of your mfx system, you can program all your CV's manually, the loco registers automatically etc etc.
With sound decoders you can download your loco sounds from the ESU website or establish your own sound file.
You have a guarantee and when installing an ESU decoder you don't have to send back the whole loco just the faulty decoder.
You have regular updates for your decoder or when improvements are applied
What I've demonstratesd here, it isn't just the decoder it has a lot to do with applications you intend to use.
Now that you've established the decoder issue what about the command station.
Why would you buy ESU decoders and not go for an ECoS as well.
What about all your old equipment such as the 6021, MS1, boosters, memories, etc etc. they all can be used and connected in an easy way to your ECoS, the EcoS itself has an inbuild booster of 4amp.
You also can now use your 6021 with 3 decoder addresses now, this gives you 12 functions for your sound decoder, attach 3 MS1 directly to your ECoS,
This demonstrates the versatility, choices and easy attachment of old motorola components and the new MS1 system.
My explanation doesn't mean, Maerklin is not working or releasing something better in the future or visa versa and how long this would take is anybody's guess.
regards.,
Which decoder??? (Digital)
by s_christos 20/12/2013 20:04:10(UTC)
Three pole w/ permanent magnet - which decoder? (Digital)
by trainbuff 20/06/2009 21:49:17(UTC)
This page was generated in 1.335 seconds.
