Offline Dgriman
#1 Posted : 24 April 2012 15:19:22(UTC)
Dgriman
My project was, to convert the analog marklin 3123 - "micheline" bus to digital controlled with mLd.
Also I decide to add interior light in the driver cab, and to change the interior lights of bulbs with 3mm yellow LED.
My first thought was to use the 60962 mLD for the conversion, but I found better idea to use the 60942 mLD, without the board of 21pin, because it is smaller from 60962.
For the driver cab, I choose to use a 2 x 1,3 mm SMD yellow LED.
All the cables that I use are 0,04 mm.
The Micheline
Marklin 3123-01 by dgriman, on Flickr
The SMD LED, 2 x 1,3 mm, the Green box is 1cm x 1 cm
Marklin 3123-02 by dgriman, on Flickr
The SMD LED soldered with the cables of 0,04mm
Marklin 3123-03 by dgriman, on Flickr
Driver's cab
Marklin 3123-04 by dgriman, on Flickr
The interior of the driver's cab
Marklin 3123-06 by dgriman, on Flickr
The SMD LED in position, inside the Driver's cab
Marklin 3123-07 by dgriman, on Flickr
The bus without the driver's cab
Marklin 3123-08 by dgriman, on Flickr
The cable harness coming out of the driver's cab
Marklin 3123-09 by dgriman, on Flickr
The light is switched on in the driver's cab
Marklin 3123-10 by dgriman, on Flickr
Marklin 3123-10b by dgriman, on Flickr
The light is switched off In the driver's cab.
Marklin 3123-10a by dgriman, on Flickr
Interior look from top view
Marklin 3123-11 by dgriman, on Flickr
The Micheline bus without the top
Marklin 3123-12 by dgriman, on Flickr
The interior floor without the interior lights
Marklin 3123-13 by dgriman, on Flickr
How the cables come from the driver's cab and they pass inside the floor plastic
Marklin 3123-14 by dgriman, on Flickr
The analog situation inside of the car before the conversion
Marklin 3123-15 by dgriman, on Flickr
Removing parts - the reverser
Marklin 3123-16 by dgriman, on Flickr
Removing parts - the motor
Marklin 3123-17 by dgriman, on Flickr
How well the new decoder fit inside the car
Marklin 3123-19 by dgriman, on Flickr
The new mLD 60942 decoder on the 21 pin board
Marklin 3123-18 by dgriman, on Flickr
Cabling of the new decoder
Marklin 3123-20 by dgriman, on Flickr
Everything connected with the decoder
Marklin 3123-21 by dgriman, on Flickr
3mm LED in position instead of plain bulb
Marklin 3123-22 by dgriman, on Flickr
The new LEDs soldered
Marklin 3123-23 by dgriman, on Flickr
Interior lights switched off
Marklin 3123-24 by dgriman, on Flickr
Interior lights switched on
Marklin 3123-25 by dgriman, on Flickr
The decoder ready inside the car
Marklin 3123-26 by dgriman, on Flickr
The bus floor again in possition
Marklin 3123-27 by dgriman, on Flickr
Interior lights in place - Finish
Marklin 3123-28 by dgriman, on Flickr
The conversion of the 60942 to use it as 60962, I'll post it in a new topic.
My web directory for Model RailRoading (Greek and English Language)
http://trains.dgservices.gr
My Photo Album
http://www.flickr.com/photos/dgriman/
My Video Channel
Trainsmodeler Video Channel
Thank you for visiting
Dimitris
thanks 2 users liked this useful post by Dgriman
#2 Posted : 24 April 2012 17:18:35(UTC)
Dimitrios,
A successful conversion, congratulation,
Offline Dgriman
#3 Posted : 24 April 2012 22:45:54(UTC)
Dgriman
Dimitrios,
Thank you John
My Photo Album
My Video Channel
Dimitris
#4 Posted : 25 April 2012 07:49:55(UTC)
Nice... I have the red one - 3124 and a micro decoder from ESU that I plan to install - one day..
Thank you for leading the way...
Offline Oliver SBB-CFF-FFS
#5 Posted : 25 April 2012 08:59:30(UTC)
Oliver SBB-CFF-FFS
Great work! Looks very neat!
I have always liked the odd (but cool) look of that michelin bus.
Maybe you could post a video of it in action when you get the time?
SBB Era IV - VI
Offline jeehring
#6 Posted : 25 April 2012 13:38:26(UTC)
jeehring
Quite explicit, thank you for sharing !
BTW...I don't understand what the red wire in a green tube is for ...(Also : where it comes from/where it goes ) Confused
Offline Dgriman
#7 Posted : 25 April 2012 22:32:35(UTC)
Dgriman
Thank you for your comments Adrian !
My Photo Album
My Video Channel
Dimitris
Offline Dgriman
#8 Posted : 25 April 2012 22:37:24(UTC)
Dgriman
Thank you Oliver, Yeah, I like it a lot this rail bus.
There is one small, at my channel at youtube, but nothing special .
here it is ...
My Photo Album
My Video Channel
Dimitris
Offline Dgriman
#9 Posted : 25 April 2012 23:45:15(UTC)
Dgriman
You are welcome jeehring,
Τhe green tube is a heat shrink tube. It is hiding a 2k2 1/4w current limiter resistor, for the power supply of the SMD LED inside the driver's cab.
My Photo Album
My Video Channel
Dimitris
Offline Ross
#10 Posted : 26 April 2012 00:02:33(UTC)
Ross
Hi Adrian,
When your ready to convert using the ESU micro have a look at my tips page as I have done this conversion.
I decided to use the original lamps rather than LEDs because you get much better even light also the speed can be profiled to run at 100km/h instead of the 250km/h plus the way it came originally from Marklin.
Ross
Offline Ross
#11 Posted : 26 April 2012 00:06:04(UTC)
Ross
Hi Dimitrios,
Nice conversion with plenty of photos to help others try and convert their bus.
Ross
Offline nelsonajm
#12 Posted : 26 April 2012 08:42:30(UTC)
nelsonajm
outstanding work... thanks for the explanation...
regards.
Marklin and TRIX fan... from Portugal...
#13 Posted : 26 April 2012 10:27:27(UTC)
Great work.ThumpUp
Offline Dgriman
#14 Posted : 26 April 2012 19:57:15(UTC)
Dgriman
Hi Dimitrios,
Thank you Ross.
My Photo Album
My Video Channel
Dimitris
Offline Dgriman
#15 Posted : 26 April 2012 19:58:51(UTC)
Dgriman
regards.
You are welcome nelsonajm.
My Photo Album
My Video Channel
Dimitris
Offline Dgriman
#16 Posted : 26 April 2012 20:00:28(UTC)
Dgriman
Great work.ThumpUp
Thank you Steven.
My Photo Album
My Video Channel
Dimitris
Guest (7)
This page was generated in 0.714 seconds.
