Joined: 10/07/2002(UTC) Posts: 3,298 Location: Patagonia
Hi everybody, again long time away for my trains, i think now i'm back for good........ I have digitized all of my locos, the bedroom layout is working fine controlled by a CS2, half of the turnouts controlled by K83 ( more are on the way ) so, a couple of days ago i decided that is time to upgrade the software, and it was very easy, just plug it to the router, press the update button and voila! now i'm running version 2.0, since it was so easy and kids are more impressed by technological stuff i have decided to explore the world of computer control, setting up the network was a little more tricky since i'm using a crossover network cable but finally i managed to make itrain to work fine. Other thing is with windigipet however, there is no way to make it works. I'm running windows 7, set the firewall off and tried to run wdp in windows XP and Vista compatibility mode but nothing happens. Can anybody give me a clue of what am i doing wrong? Thanks in advance Francisco |
 German trains era I-II and selected III, era depends on the mood, mostly Maerklin but i can be heretic if needed XD, heresy is no longer an issue.. LOL |
Joined: 27/08/2005(UTC) Posts: 11,071 Location: Murrumba Downs QLD
Check the Ip Settings in WDP for the Cs2, they could be wrong.
Nev |
NOt wearing the Pink Pinny, which is hard to see and now I have a white Pinny which also is hard to see against MY pure white Skin Still have 2 new shiny tin Hips that is badly in Need of Repair matching rusting tin shoulders and a hose pipe on the aorta Junior member of the Banana Club, a reformist and an old Goat with a Bad memory, loafing around |
Already did, it is ok........... |
well, problem solved or a least clarified, i have installed the test version of WDP 2012 wich runs on windows 7 and it works just fine, sadly it is only in German, so a little bit tricky to me. So, i think that the problem maybe just an incompatibility of WDP 2009 and windows 7? |
Joined: 13/09/2005(UTC) Posts: 262 Location: Johannesburg
Try Railroad & Co. There is a demo version which unfortunately only runs for 10 minutes. The software is fully compatible with Win 7, 16 & 32, CS2 and in English. You can get it at http://www.freiwald.com/pages/index.htmlPieter |
Era I-V / HO / C-Track / MS2, CS2 & CS3 Z gauge. Insider
Member of Märklin Modellers Group |
Joined: 15/03/2003(UTC) Posts: 9,603 Location: Australia
Originally Posted by: franciscohg  well, problem solved or a least clarified, i have installed the test version of WDP 2012 wich runs on windows 7 and it works just fine, sadly it is only in German, so a little bit tricky to me. So, i think that the problem maybe just an incompatibility of WDP 2009 and windows 7? I can confirm that WDP 2009 works with the 32 bit edition of windows 7. Did you install the latest version of 2009? I believe that support for the CS2 was not available until the third interim update. Unfortunately, WDP2012 is unlikely to be available in English until Christmas this year. |
Adrian Australia flag by abFlags.com |
I am also running WDP 2009 with Windows 7 and the CS2, works perfectly.
Elliott |
Elliott CS2 4.1.2 (3), CS 2.04, 6021, 3x 60174 Boosters, L88, 2x 60881, 13x 6088(0) ,Windigipet 2015 Premium, Marklin K-track layout (in progress) |
mmmmm, hi Adrián, ir has been a long time.... i used the demo version from the WDP site... it is strange since version 2012 runs flawlessly.... im working tonight, i will give ir another try tomorrow |
Originally Posted by: franciscohg  mmmmm, hi Adrián, ir has been a long time.... It has indeed... It's great to see you back with us - we all missed you.. Cheers |
