Offline 20-VOLT-AC
#1 Posted : 18 March 2012 16:52:12(UTC)
20-VOLT-AC
Hello Guy's
I am going through ideas for a vintage H0 layout and wondered how many lighting accessories i can run from a single 280A super transformer ( Station lamps / lamposts / via the yellow lighting circuit output terminal ?
Many regards Neil.
20-VOLT-AC attached the following image(s):
1950's Marklin Fan .
#2 Posted : 18 March 2012 17:28:13(UTC)
Hi, Neil,
Modern rule of thumb says 1.5 VA per light bulb. That would be 20 light bulbs from a 30 VA transformer (no power left for anything else).
Don't know if those vintage bulbs need more power.
#3 Posted : 18 March 2012 22:03:52(UTC)
I always thought it was 1.0va per bulb. There, you have another 10 bulbs from your 30va transformer, just like that!
Offline Markus Schild
#4 Posted : 18 March 2012 23:51:36(UTC)
Markus Schild
Hi Neil,
The larger type of bulbs, which is used for the lamps you show are specified with a consumption of 1.25 VA. Smaller bulbs like the headlights of locos or the bulbs in Signals of the 704X-Series are specified with 0.9 VA consumption.
All 280A transformers should be checked before use today. Often the insulation of the cable (high-voltage-side) has disintegrated inside the transformer.
Markus
Offline 20-VOLT-AC
#5 Posted : 19 March 2012 21:43:05(UTC)
20-VOLT-AC
Hi Neil,
Markus
Hi Markus, yes good point on the transformer lead, i always replace the high voltage " MAINS INPUT " cable on old transormers before use and test them on a bench tester for output voltage !
So i should be able to use quite a few bulbs before they start dimming down then !
Has anyone tried using the new low power consumption LEDS which are available with many different socket sizes nowadays ?
Thanks Neil.
Offline kbvrod
#6 Posted : 19 March 2012 23:35:11(UTC)
kbvrod
Hi Neil,all,
See: http://www.trainaidsa.com/shop-leds.shtml and I am sure there are other suppliers out there,...BigGrin
Resistors and diodes,I think your in business,...Wink
Dr D
This page was generated in 0.566 seconds.
