Offline pyxa69
#1 Posted : 05 March 2012 00:01:21(UTC)
pyxa69
Hi everyone, got those two locos of the ebay other dayBigGrin.
NOw im trying to give them new (digital) life.
But not sure with decorders should i use Marklin 60901 or Esu 54633Confused.
Never use to do it on my own and kind of scare to brake or damage somethingBlink.
MaRkLiN rules
#2 Posted : 06 March 2012 19:09:01(UTC)
Hi Serge,
The Marklin 60901 kit is now long out of production, and uses an old decoder, with DIP switches and pots on the board for address selection and adjustments. Though it is an excellent decoder it falls short of the latest standards. From Marklin you can use one of these options:
60760 set - very cost effective but with a more basic decoder
60941 kit with 60942 decoder - the closest to the ESU set, with 21 MTC board, but with the benefit of a 5 pole motor upgrade
60941 kit with 60962 decoder - similar to the previous option but with a hardwired decoder instead of the 21 MTC board
The ESU 54633 kit is much more up to date than the 60901 set, with a 21 MTC connector board so you can use the plug-in decoder supplied. It is, however, the wrong set for your locos. You should use the 54635 set which has the correct field magnet. The ESU sets have a superior Lokpilot decoder, but don't include a 5 pole motor upgrade.
The ESU 54632 set is like the 54635 but with the decoder hardwired instead of with the 21 MTC board.
I'm sorry if I've now confused you even more. There are so many options, including mixing the ESU decoder with the Marklin motor kits!
Have a look at prices if that's important for you. For me the performance is not such an issue, and I tend to use the Marklin 60760 kits or the ESU 54632 set for this type of loco conversion.
Offline pab
#3 Posted : 06 March 2012 21:15:19(UTC)
pab
if you want a new life with sound you can use the 60945/60965 decoder
Offline Johnvr
#4 Posted : 07 March 2012 07:32:36(UTC)
Johnvr
Such gracious locos !!
From another era !!
I would use a 60760 decoder for a simple conversion without sound.
But watch out for the trick of the electronics and the diodes !
If you have not done this before, then you need to get some guidance on AC/DC current.
Regards, BigGrin
Offline Ian555
#5 Posted : 07 March 2012 08:52:19(UTC)
Ian555
Hi Serge,
I hope I'm not the only forum member that looks at it this way........
Go out and buy some M track and a transformer and enjoy those beautiful Loco's for what they are.
And, here's another reason, I do a bit searching on e-bay, when a grand old Loco comes up for sale that has been "converted", then no one hardly bids on it.
Don't get me wrong, I love my smooth running, beautifully detailed digital Loco's, but the older Loco's have just as much charm.
I'll go and get my crash hat on and Flak jacket now. Smile ThumpUp
Ian.
#6 Posted : 07 March 2012 11:30:33(UTC)
We're not talking about particularly old or valuable locos here. I don't think the resale value will be very much affected by a digital conversion.
Anyway, Ian, a loco converted with a 60760 will still run just as well on analogue. In fact it will run better, with better low speed control and no "kangaroo jump" when reversed!
OK, you can take the flak jacket off now! BigGrin
#7 Posted : 07 March 2012 11:34:08(UTC)
From another era !!
Regards, BigGrin
Hi John,
Could you elaborate on this trick of electronics and diodes? A 60760 conversion for these DCM locos needs nothing other than what is included in the kit, unless you want to insulate the lamp from chassis and add a bulb holder, which I don't usually bother with.
#8 Posted : 07 March 2012 12:24:27(UTC)
Serge,
If you join Ian's path, I've got some good news, with an ESU sound decoder you can run your loco under Analog aswell with full sound option.
Here is my answer, say no more.
#9 Posted : 07 March 2012 12:42:47(UTC)
Hi John,
I'm disappointed. The sound should go away when the train goes in the tunnel. ThumbDown
Offline Ian555
#10 Posted : 07 March 2012 12:44:52(UTC)
Ian555
Hi Ray,
On this one, we will have to agree to disagree....Smile ThumpUp
Ian.
#11 Posted : 07 March 2012 13:05:21(UTC)
Hi Ray,
Ian.
Such is our diverse hobby! ThumpUp
#12 Posted : 07 March 2012 15:59:24(UTC)
Hi John,
Well, Well, I just have to make the tunnel air tight and sound proof to suit members from Gibraltar.
It has had a brick wall but having worked in this area for severeal reasons the brick has has somewhat dissapeared, I'll just have to take the castle off again and reconstruct the brick wall.[biggrin
With nearly 20.000 viewers and 3 dissapointments it isn't a bad result.
You always can stick your fingers into your ears when the loco goes into the tunnel.LOL
the whole video was about the BR 41 and what can be done if you are thinking of converting it to digital.
Offline Johnvr
#13 Posted : 07 March 2012 16:18:46(UTC)
Johnvr
From another era !!
Regards, BigGrin
Hi John,
Ray,
I am assuming that the 3082 and 3085 locomotives are flat style commutator motors (and not the more recent drum style DCM).
If so, then the 60760 permanent magnet may not fit into the locomotive frame.
The holes from the locomotive body will not line up with the holes in the magnet, and you may not be able to attach the magnet.
I have found this to be the case with some of my older locomotives.
Therefore you have to keep the original motor parts (or at least the magnet).
The original motor parts and magnet worked on an AC motor, but the 60760 kit pushes out DC current to the motor.
Hence you need to have diodes so that the forward- and reverse- directions are working properly.
Is this making sense to you ?
Regards,BigGrin
Offline Johnvr
#14 Posted : 07 March 2012 16:24:36(UTC)
Johnvr
Serge,
We can probably assist you with your conversion, but it would be very useful if you could possibly open up the chassis and take a close-up picture of the 3-pole armature.
Then we can assess whether you have a flat style commutator or a drum style commutator.
It is important to know this before you go too far in your conversion.
Alternately, can you possibly date the locomotives from your catalogues ?
This could also assist us in this deliberation.
Regards,BigGrin
Offline BrandonVA
#15 Posted : 07 March 2012 17:03:39(UTC)
BrandonVA
John,
This may help:
3082 (BR41) made from 1974-1992
3085 (BR03) made from 1973-2003 (30 years!)
Both use the drum style 3 pole motor.
#16 Posted : 07 March 2012 17:39:36(UTC)
From another era !!
Regards, BigGrin
Hi John,
Ray,
Regards,BigGrin
OK, thanks John.
Actually I have a 3085 myself, and I'd checked up on the 3082, so I knew that they had DCM motors. Now I see that your comment about diodes refers to making an AC field magnet work for DC. This is actually not necessary in this conversion, and you can use the magnet, armature and brush plate contained in the kit.
The only concern in fitting the motor parts, as I recall, is that you have to remember to mount the brush plate upside down, otherwise it fouls the body when you put it back on.
Offline pyxa69
#17 Posted : 07 March 2012 20:12:52(UTC)
pyxa69
BigGrin BigGrin BigGrin
Wow thank you guys for comming back on thisBigGrin
Im may go for a Marklin 60760 since its Markiln.
It will be my first conversion on my own Crying kind of scared but i hope everything will go smooooth.
MaRkLiN rules
Offline BR01097
#18 Posted : 08 March 2012 06:25:10(UTC)
BR01097
Wow, that is one impressive video! Whether the chuffing should fade in a tunnel is a non-starter for me.
Two things about it make me wonder, though: 1) that model of the Class 41 has incredible adhesion to pull a train of that length unassisted, and 2) how can trains of those lengths even start without the first ten cars derailing in a curve? There is no helper in the rear of either of them. You must lubricate generously.
Offline Johnvr
#19 Posted : 08 March 2012 08:04:26(UTC)
Johnvr
From another era !!
Regards, BigGrin
Hi John,
Ray,
Regards,BigGrin
OK, thanks John.
Ray - You are quite correct !
From the detailed parts pictures shown, these are newer drum style motors, so the 60760 kit will work nicely !
For your interest, I can post a separate thread on converting flat style commutator motors where the new magnet does not fit the older loco body, and I have used the diode trick.
Regards, BigGrin
#20 Posted : 09 March 2012 14:12:23(UTC)
That would be great, John. Thanks.
Offline JDennis
#21 Posted : 18 January 2022 23:36:30(UTC)
JDennis
Did I read correctly the first couple posts in this thread? The 60941 is the correct motor kit? I tried to order that one and was told it was wrong, but that's the closest I could find so I just don't know now. Arghhh.
Offline JDennis
#22 Posted : 20 January 2022 04:10:59(UTC)
JDennis
Nevermind. The supplier called Marklin and confirmed that you were right, I was right: 60941.
Guest (4)
This page was generated in 0.615 seconds.
