Offline BrandonVA
#1 Posted : 17 February 2012 14:56:55(UTC)
BrandonVA
Hello all,
I have just received a BR85 3309 and BR41 3082 I purchased on eBay. Both locomotives are in excellent cosmetic condition. When I put them on the track initially, they were running pretty slowly. I took the covers off both, removed the coil from the motor, cleaned the shafts, oiled and reassembled. When I had the coil out, I could turn the gear and the wheels would turn ok...but I am not sure how much resistance I should feel. It was not hard to turn them, but not sure if I should be able to push it and it will spin freely after I stop turning the gear. I also oiled around the wheels where the manual suggests. Afterward, the locomotives run very well on a straight, but they seem to struggle on curves (K track 2221 - which are 30 degree standard). It seems like they are binding when they go around a corner. The motor sounds like it's struggling a bit more and it slows down. The 3309 seems to have no trouble articulating the chassis if I pick it up and move it by hand. Valve gears do not appear to be binding.
Both models have clean wheels and pickup shoes. Lights, reversing, and telex (on the 3309) work perfectly. On a straight they seem to have no trouble getting up to full speed. I don't have problems with any of my other locomotives on these curves, I have a BR41 from the 29625 starter set that goes around no problem as well as a 3085 BR03
Do I just need to do more disassembly and old oil cleanup? Need new traction tires? Initially I thought it may be a problem with these models having big 8 and 10 wheel sets going around the corners, but it just doesn't seem characteristic to Marklin locos - which always run well.
Edited by user 19 November 2012 20:41:43(UTC)  | Reason: Not specified
Offline petestra
#2 Posted : 17 February 2012 15:12:08(UTC)
Hi, I have had the 3309 since I bought it new back in '94. The main wheel set is articulated so there should not be any problems in curves. Look to see that nothing is blocking the movement of the articulation (dust, dirt, particals). In addition always keep the gears/axles well oiled. Mine is a great runner, yours should be too. Peter
Offline arconell
#3 Posted : 18 February 2012 01:07:00(UTC)
arconell
Hi Brandon,
The 3309 indeed has an articulated chassis, the 3084 has not. As for the 3309 I agree with Peter, it should run perfectly thru R1 radius curves. Not so for the 3084, at low power settings. Run it with a long and heavy freight train and you won't notice.
As for the 3309, do check the free movement of the 2 parts of the chassis but also check the 2 parts of the connecting rods where they come together on 3rd axle, they should slide freely. Sometimes one of these rods is slightly bent which obstructs their sliding movement in curves.
Regards, Robert
Offline BrandonVA
#4 Posted : 20 February 2012 14:25:49(UTC)
BrandonVA
I will take a look, the articulation seems fine..but I will check the rods. I suspect the axles may be gummed up as well. When cleaning these, do most people remove the wheels entirely? I'm not sure what is the best way? What's the most common spots for gumming to clean?
I also edited my original post, I put 3084 which is a BR50...I got a 3082, BR41. It's not articulated, but my other Delta BR41 runs fine on the same corners. I got both from the same seller, so I expect the condition to be similar...if one is gummed, the other probably is as well.
Offline petestra
#5 Posted : 20 February 2012 14:58:58(UTC)
Hi Brandon,
I use Q-Tips soaked in Ronson lighter fluid for cleaning gears, axles, armatures (for my older Loks). You should be able to do this without removing wheels. I know that Scott from Helmut's Hobby has a devise that gives the Loks an electronic bath, so to speak. I have sent him many Loks for repairs over the years and they are always returned to me looking like new. Good luck! PeterSmile
Offline BrandonVA
#6 Posted : 08 October 2012 21:55:48(UTC)
BrandonVA
An update on a somewhat old topic for anyone interested.
3309 - The trouble with this engine was just extreme gumming of old oil. I got some Ronsonal lighter fluid as suggested by Peter (thanks Peter!), which works great. However, even after an initial cleaning it was still binding some in corners. I found the problem to be the gears right on the articulated part of the frame that help to carry the drive across the articulation. After cleaning again, I took the rotor out of the motor, re-oiled the axles on the loco and pushed it around the layout a few laps in each direction with another loco. The result of the pushing I think was any oil remaining old was broken up more easily than it was turning the wheels by hand or letting the locos own internal motor struggle with it. I think without the tension of the drive the parts may have been able to move more freely as well. At any rate, the loco runs around corners (R1, and even industrial if I occasionally dare), perfectly now.
3082 - this one is still on the bench, by the same method of ronsonal fluid I have cleaned it, and it pushes freely by hand in one direction around corners, but binds in the other. I havn't spent much time with it, but when I get around to it I will try to post a response.
Both came from the same eBay seller, so I suspect the original collection had been unused for some time. Leads leads me to believe they should have hte same kind of issue.
-Brandon
#7 Posted : 08 October 2012 21:59:48(UTC)
Hi Brandon
While the rotor is out, check the BR 41 for binding rods, that could be caused by one or two drivers being out of quarter...
Check also that on both sides, the cranks are all perfectly aligned ..
Offline Osterthun
#8 Posted : 10 October 2012 13:49:11(UTC)
Osterthun
Hello Brandon,
The 3082 has IN GENERAL pretty bad running qualities where lubrication does NOT help.
It has to do with the axle code and solid frame (4 axles in a sharp curve and the engine sqeels like... (ye know, some dark place down below).
Even the Digital version like 3792 has the similar problem in curves.
Now the Neubaukessel 41/042, that's a real gem.
Frits
Offline BrandonVA
#9 Posted : 10 October 2012 15:30:32(UTC)
BrandonVA
Fritz,
Thanks, I competely agree. I also have a BR41 from the 29625 starter set. It does struggle a bit in R1 corners due to the lack of articulation. Something is up with my 3082 though, it binds almost to the point of stopping. I can feel a high amount of resistance even when pushing by hand. You have helped my expectation though, I should expect it to just run OK and not great (but not terrible).
Of course I can post about it all day long, but what would really help is if I actually worked on the locomotive :)
-Brandon
Offline BrandonVA
#10 Posted : 19 November 2012 20:40:48(UTC)
BrandonVA
I looked at my 3082 for a long time, I tried a few things:
-Extensive de-gumming of axles with Ronsonal and a q-tip (wheels played freely by hand)
-Running with various parts of the valve gear disconnected
In the end, I think that one or more of the axles or perhaps the chassis itself is slightly bent. I came up with with a workaround, which was to replace the whole chassis. It may be a bit of a blunt approach, but it worked. No longer does the locomotive bind to stopping or crawling in R1 corners at a reasonable speed. Here is my thread on replacing the chassis:
https://www.marklin-users.net/fo...Loco-Service-How-to.aspx
As previously mentioned, 3309 was fixed by extensive de-gumming.
-Brandon
Guest (6)
This page was generated in 0.459 seconds.
