Offline wurttemberg
#1 Posted : 14 February 2012 09:02:02(UTC)
wurttemberg
Does anyone know what features the Märklin 60760 decoder has?
- I assume it is simlar to ESU Lokpilot, ( EMF speed regulation, Accelaration / Retardation)?
- How many functions are there - 4? (F1 -F4)
- Does it have the ability to switch off acc/ret? as the "ordinary/full featured" Märklin decoders often provide - I very much appreciate that function.
Does anyone have any experience of decoder? - How is it as compared to for example Lok Pilot?
Any advice is appreciated,
BR/Wurttemberg
Offline Piggy
#2 Posted : 14 February 2012 09:19:44(UTC)
Piggy
It's a very simple decoder, it does not come close to a Lokpilot. You cannot adjust the motor parameters, it fixed for the 5 pole motor kit in the set. You can adjust acceleration/ braking delay. there are only functions headlight in both ends.
Kenneth
#3 Posted : 14 February 2012 09:59:18(UTC)
Originally Posted by: Piggy Go to Quoted Post
....there are only functions headlight in both ends.
Not correct! There are additional functions controllable with F1/F2, etc, on this decoder. The Webmaster recently posted a picture of the 60760 decoder board showing where the solder pads for the extra functions are. The picture came from the x-train.de site.
#4 Posted : 14 February 2012 10:13:53(UTC)
The website is still up but no information can be given, see reasons below.
http://www.x-train.de/
#5 Posted : 14 February 2012 10:16:50(UTC)
Twas discussed here:- https://www.marklin-user...aspx?g=posts&t=13444
And this is the photo that was, but is no longer in villefra's first post in that thread.
But I do know that Juhan has the picture off the x-train site.
Bigdaddynz attached the following image(s):
#6 Posted : 14 February 2012 12:25:45(UTC)
You can adjust acceleration/braking delay.
But not independently as with LokPilot: there is one common setting for both.
#7 Posted : 14 February 2012 12:44:08(UTC)
This decoder set is ideal for converting to digital some of those older analogue models that don't require a lot of functions. I have several locos in my collection which I wanted to convert but I felt did not warrant spending a lot of money on.
With the 5 pole kit included you get a fairly smooth running loco, as long as you set a longish delay on the acceleration/braking. If you set a short delay, or disable it with F4, you will find that the speed steps are quite noticeable.
Best thing about it is that for about 25-30 euro you get a full digital conversion for any DCM loco.
I have used this set also to convert Delta locos to full digital, with a tremendous improvement in running qualities.
#8 Posted : 14 February 2012 20:48:37(UTC)
60760 from x-train.de:
File Attachment(s):
60760.pdf (580kb) downloaded 171 time(s).
Offline wurttemberg
#9 Posted : 14 February 2012 21:52:42(UTC)
wurttemberg
Thank you All!
What a tremendous respons, and I am amazed of all knowledge about "secret features" there is at the forum.
I do appreciate the pdf - quite impressive!
Ray, Does F4 realy switch accelaration/retardation on/off?
BR/Wurttemberg
#10 Posted : 15 February 2012 00:33:37(UTC)
Yes.
Guest (6)
This page was generated in 0.588 seconds.
