Offline bobhunt2
#1 Posted : 02 April 2007 03:22:19(UTC)
bobhunt2
Can anyone tell me what is the best method of cleaning excess glue from plastic models?
Offline Frostie
#2 Posted : 02 April 2007 04:27:35(UTC)
Frostie
Prevention of excess glue is the best method. I use Tamiya bottled glues which come i various consistencies. They come in bottles, and the cap has some good brushes. That way applicatio is very easy tp control.
CS/MS Digital Era 1/2
Offline dntower85
#3 Posted : 02 April 2007 08:54:26(UTC)
dntower85
what kind of glue is it. for super glues (CA) use fingernale polish remover works good in an emergancy. and if your fingers are now stuck to the keys of the key board turn off the computer first.[:p]
DT
#4 Posted : 02 April 2007 10:01:13(UTC)
biggrin
Offline Frostie
#5 Posted : 02 April 2007 13:07:45(UTC)
Frostie
Does fingernail polish remover work on the more common plastic glues ?
#6 Posted : 02 April 2007 14:31:05(UTC)
As I understand it, the glues form Faller, Kibri, Revell, etc. for plastics works by dissolving the plastic (styrene) ad thereby letting pieces "melt" together. There is therefore no glue to remove; it´s all totally absorbed into the plastic.
(Not talking about CA here (aka "crazy-glue")
So the answer must be, that imperfections caused by glue can only be removed mechanically (file, cut, or by painting it over.
(at least my experience confirms this)
#7 Posted : 02 April 2007 22:46:56(UTC)
The Dane in Spain is correct.
The only way with plastic (styrene glues) is to cut, or file over the unsightly glue parts.
You can paint over, using a colour like the plastic, or maybe use a weathering technique on that part.
Using a sharp hobby knife in a scraping motion is quite effective.
I believe most of us modellers accept that minor glue marks are normal on a model.
If you want to use the model for photographic purposes, it is best to remove or cover the glue marks.
This page was generated in 0.427 seconds.
