Offline reindeerdad
#1 Posted : 26 January 2012 22:59:46(UTC)
reindeerdad
I am in the process of upgrading to a mobile station 2(60653), from the infrared Marklin starter set controller. I ordered the 60113 track connector, and a 120V 60VA 60055 transformer for power. I went to the larger transformer, due to not thinking that the starter set 18va transformer would handle my eventual layout. Based on some forum reading, I really haven't seen any posts that indicate whether or not the 60055 transformer is the proper item to use with the mobile station 2. Any opinions out there?? Thanks!
Offline mrmarklin
#2 Posted : 30 January 2012 13:03:20(UTC)
mrmarklin
Blink
I use 60055 with my MS2.
Dave Pryor
Offline reindeerdad
#3 Posted : 30 January 2012 22:28:27(UTC)
reindeerdad
Dave -- thanks for your reply. Do you use the same transformer to power turnouts, lights or other accessories? I would think that the transformer would have sufficient capacity, but most of the forum posts talk about supplying power to the accessories from a separate transformer.
#4 Posted : 30 January 2012 22:42:13(UTC)
A connection between rail and transformer will fry your track connection box.
Therefore the transformer cannot be used to power some accessories (e.g. rail road crossings).
Offline mrmarklin
#5 Posted : 31 January 2012 00:08:09(UTC)
mrmarklin
If you are using C track you can use item # 74460 under the turnouts. There is plenty of power for a small starter layout. I have 4 switches on my test track, and so far have no problems running up to 3 locomotives.Cool
Dave Pryor
Offline reindeerdad
#6 Posted : 31 January 2012 03:59:33(UTC)
reindeerdad
My layout is going to be on a Noch 81710 preform, so there will be limited turnouts, and my goal was to have everything controlled via digital, so I will be using the 74460s on the turnouts. I'll need to do more research (on this site), to make sure I understand the limitations on layout wiring. Thanks...
Offline Loadmaster
#7 Posted : 31 January 2012 07:08:23(UTC)
Loadmaster
Check out the Marklin 74445 item, it includes the switch motor, didital unit and a lantern.
Everything fits under the roadbed and you have 256 codes to choose for your switches.
Rob
This page was generated in 0.528 seconds.
