Offline Kevin Weis
#1 Posted : 26 December 2011 22:04:35(UTC)
Kevin Weis
Has been awhile since I've been on here but I've been thiking of converting some locomotives that have an old c80 decoder with the typical three pole drum motor to the newer 5 pole permanant magnet motor but keeping the old c 80 decoder. Are these compatable? I rarely here of anybody doing this but I don't see where this would be a problem. Just thought they would run a lot smoother. Any thoughts appreciated.
Regards, Kevin
Offline mvd71
#2 Posted : 26 December 2011 22:53:08(UTC)
Hi Kevin,
The mod you a suggesting will not work, because the decoder you have is specifically designed to drive a AC motor. The output characteristics will not work with the DC motor.
You can fit the old style 5 pole armature (610030) from: toottoot to your existing AC motor and it will improve the running, but it will never match the latest generation of kits from marklin.
I would suggest you try a 60760 kit if you want to get a good improvement without too much expenditure.
Cheers....
Mike.
#3 Posted : 26 December 2011 23:16:35(UTC)
The 6080 decoder has three motor connections made for AC/DC motors.
DC motors only have two motor connections.
While the 6080 decoder can be modified to work with DC motors, I don't think it's worth the trouble. You still have a decoder without load regulation, without acceleration and braking delay, without adjustable maximum speed.
Offline Kevin Weis
#4 Posted : 27 December 2011 19:04:45(UTC)
Kevin Weis
Ok, thanks! I'll go with the 60760 kit or equalvent as suggested.
Regards, Kevin
Offline Kevin Weis
#5 Posted : 10 January 2012 02:40:19(UTC)
Kevin Weis
Part of this is another thread but I went ahead and tried a 610030 5 pole armature (AC) with the c80 decoder. Not imprerssed. Ran a little smoother but became twice as sensitive to grade changes both uphill and downhill ( fast downhill - slow uphill, real slow). Can see why this combination was never used. I was warned. Ok the 60760 is next.
Online river6109
#6 Posted : 10 January 2012 03:19:19(UTC)
Kevin,
It is a hard upwards curve learning process and an easy down disaster route.BigGrin
This forum helps to ease and strengthen the learning process and hopefully prevents you from disasters.
All in all you are getting VIP advice here and the story goes like: We've told you so
Happy New Year
Offline mvd71
#7 Posted : 10 January 2012 06:15:06(UTC)
It's not a complete disaster Kevin. You could use a lokpilot and hamo magnet with this to get excellent results.
Cheers...
Mike.
Online river6109
#8 Posted : 10 January 2012 09:42:13(UTC)
Cheers...
Mike.
I'm not so sure about that.
I've tried it for a customer and had no satisfying results compared to a 5 pole conversion set.
Offline Kevin Weis
#9 Posted : 10 January 2012 19:11:23(UTC)
Kevin Weis
Looks like the 60760 is a no-brainer. I'll be putting it in a 3312 that is a partially fried circut board anyways. I don't understand what the circut board was used for in this model as the reverse unit is control by the direct analog voltage???. Looks like maybe for some control of the headlights. Nothing to lose here.
Regards, Kevin
#10 Posted : 10 January 2012 21:43:11(UTC)
The little circuit board with diodes was used to get a silent DC pulse to the relay instead of the noisy AC pulse we had in the the older locos.
The 33xx series of locos had these.
Offline Kevin Weis
#11 Posted : 12 January 2012 21:02:05(UTC)
Kevin Weis
Thanks, Webmaster! Got the 60760 in on the 3312. The two headlights blew out but I had the orange wire connected wrong to ground instead of the headlightsBlushing . Could this have done it? I saw the lightes flash for a second, maybe the volatage got doubled or something from the wrong connection above. Maybe the original bulbs are the wrong voltage required by the 60760?? Anyways otherwise the locomotive performs well with the new dc motor.
Regards, Kevin
#12 Posted : 12 January 2012 21:32:05(UTC)
Hi Kevin,
33xx locos are fitted with low voltage bulbs (about 3V). They need to be changed to appropriate 18 or 20 volt bulbs when the loco is converted to Digital. Of course I always forget when doing the conversion and blow the bulbs just like you did! BigGrin
Offline Kevin Weis
#13 Posted : 13 January 2012 16:38:37(UTC)
Kevin Weis
Ray, thanks! That makes sense. I saw in the manual for the 60760 conversion kit where it identifies two bulbs used, 610080 & 610040. Guess I will need to improvise a holder for these bulbs. I love a challengeBigGrin . Is it better to ground the bulbs directly to the frame or use the orange wire ground return from the decoder?
Regards, Kevin
#14 Posted : 13 January 2012 17:06:56(UTC)
Regards, Kevin
Always better to use the Orange wire if at all possible, as this will reduce flickering of the bulbs.
#15 Posted : 18 January 2012 20:26:38(UTC)
The Orange Wire is a rectified plus (approx 22 Volt) and must never be connected to the locomotive chassis.
Offline Kevin Weis
#16 Posted : 18 January 2012 22:26:46(UTC)
Kevin Weis
Thanks Ray & Svein, I'm waiting for my 610080 bulbs to show up so I can connect to the decoder and see if this all works out. So far the decoder works good with the new dc motor in place. I have sharp grades on my layout (under construction) and the speed is perfectly even up grade and down gradeBigGrin .
Regards, Kevin
This page was generated in 0.661 seconds.
