7 Pages123>»
Offline vilithejou
#1 Posted : 24 December 2011 11:07:23(UTC)
vilithejou
In Märklin Holland appears the first new item for 2012
Märklin.nl
It's a BR 50 with in NS scheme of paint
Joan Vilarrúbia
vilithejou@yahoo.es
Fan of Märklín, Kroko lover
Offline jeehring
#2 Posted : 24 December 2011 11:12:55(UTC)
jeehring
bye bye good old articulated frame...Crying
BTW : what are those "bell shape armature" motors....what is the advantage of "bell shape armature" , is it the rotating part or the fixed part of the motor ?...
#3 Posted : 24 December 2011 12:06:51(UTC)
Because of the whole mechanism, the firebox with all its instruments can be set further back plus it runs quieter.
the articulated frame has been replaced with a solid frame and most probably the wheels will have enough space to move sideways to be able to manage R1 curves (360mm)
Offline I_love_Marklin_37538
#4 Posted : 24 December 2011 13:59:37(UTC)
Anymore new items?
#5 Posted : 24 December 2011 14:54:43(UTC)
Märklin.nl
Delivery to Dutch dealers only.
Offline vilithejou
#6 Posted : 24 December 2011 15:13:45(UTC)
vilithejou
Originally Posted by: I_love_Marklin_37538 Go to Quoted Post
Anymore new items?
I hope on 8 or 9 of January we know a little bit more
Joan Vilarrúbia
vilithejou@yahoo.es
#7 Posted : 24 December 2011 15:39:31(UTC)
Anymore new items?
Not long to wait
Offline TimR
#8 Posted : 24 December 2011 16:03:25(UTC)
TimR
Indonesia
Woohoo!Drool Drool
New tooling BR50 is coming...
no motor in the cab, super fine detailing, also new tooling T26 tender.
I like this one better than the BR50.40.
A new BR44 too please!
Now collecting C-Sine models.
#9 Posted : 24 December 2011 16:04:13(UTC)
Not speaking Dutch, I tried the online Bing translation:
Model: With mfx Digital Decoder and extensive sound features. Regular anchor clock with hoogvermogenaandrijving and flywheel in the boiler. 5 axles powered. Non-Slip Tires. Locomotive and tender mainly of metal. Prepared to non-garnish 7226 afterwards. Tweepuntsfrontsein changes with the direction, with to build non-traditional garnish in afterwards in company, digital switchable. Lighting with LEDs warmwhite poor maintenance. Short link mechanism between loc and tender, adjustable on the basis of the rail radius. Behind the tender and to the loc by mechanics guided short link with NEM-shaft. Ride bare minimum curvature 360 mm. Zuigerstangbeschermhulzen and remslagen included. The length over buffers 26.4 cm
Ouch! My head hurts! BigGrin
#10 Posted : 24 December 2011 18:50:33(UTC)
Originally Posted by: TimR Go to Quoted Post
Woohoo!Drool Drool
Ditto here please!
Offline DV
#11 Posted : 24 December 2011 23:25:38(UTC)
DV
This is the google translation
enjoy
Dutch Big Boy
[12/24/2012] The largest steam locomotives in the Dutch Railways, the locomotives of the series 4900. The model of the NS 4906 as announced on Marklin 2012 novelty Dutch Märklin Stores and Shops.
Highlights:
Completely new development
Extremely fine metal construction
Exploded rod frame and many separately applied details
High power motor with bell-shaped armature and flywheel
Many operating and sound functions
37812 Freight Train steam locomotive with a Tender
Example: Freight train steam locomotive 4900 (ex series 50) of the Dutch Railways (NS) with coal tender 2'2'T26 drawn in the original version. With Wagner smoke deflectors. Road number 4906. Operating status 1945-1946.
Model: With digital decoder mfx sound and comprehensive features. Controlled high-efficiency propulsion with bell-shaped armature and flywheel in the boiler. 5 axles powered. Traction tires. Locomotive and tender mostly of metal. Prepared later in 7226 smoke generator building. The dual headlights change over with the direction, and afterwards in smoke generator to be built in conventional operation and can be controlled digitally. The headlights are maintenance free, warm white LEDs. Close coupling mechanism between the locomotive and tender, adjustable based on the track radius. Rear of the tender and the locomotive mechanics led by NEM close coupling shaft. Negotiable minimum radius 360 mm. Rod sleeves and remslagen included. Length over the buffers 26.4 cm
Price: € 399.95
Delivery : September 2012
One-time series for the Dutch Märklin Stores and Shops.
Dusan V
Offline Western Pacific
#12 Posted : 25 December 2011 09:59:46(UTC)
Western Pacific
I guess to make the translation complete: "... Rod sleeves and remslagen included. ..." - "remslagen" should read "remslangen" which translates into "brake hoses", thus it should read:
"... Rod sleeves and brake hoses included. ..."
The lesson learned here is that Google translate doesn't handle typing errors.
(Due to the fact that I've studied some Dutch, I suspected a typo and looked up the word "slangen" in a Dutch - Dutch dictionary and that confirmed the typo. "Slangen" is plural of "slang" meaning "hose" in English. Then for non Swedish speakers, I can add that hose in Swedish is called "slang (pl. slangar)" which shows the relation between Dutch as a Germanic language and Swedish, which is also Germanic, in this case [whereas the German word "Schlauch" is much more far away]).
Edited by user 25 December 2011 16:02:48(UTC)  | Reason: Correcting typo
Offline NS1200
#13 Posted : 25 December 2011 15:14:14(UTC)
NS1200
Western Pacific,
Thanks for your efforts to master the Dutch language,indeed not a language for the faint hearted!
Note that slang also means snake,plural slangen equals snakes,gifslang means poisonous snake,tuinslang means gardenhose!
On the model itself: nothing special for me,lookes like M took a standard german loco and simply changed the lettering on the drivers cabin,a fairly cheap way of creating a socalled special edition.
Same thing was done with the latest series BR74.
The market of buyers for these locos will be limited indeed,hence the limited productionrun.
A lot of German locos were left behind and/or confiscated after the liberation of Holland in May 1945,and these machines were made of good use,everything which did have wheels was put in action on a railnetwerk which for the most part was destroyed.
The operational life of these machines in Holland was short,already before the war electrification was well on its way in the Netherlands,and after the war was developed at a faster pace.
Electric locos series 1000/1100/1200/1300 were in action in the early fifties,same for electric multiple passager units.
In addition,large numbers of French diesel locos series 2200/2400 were taking care of the freighttraffic.
Check out the Roco model of the NS1000 electric loco,also available in AC version,if M would issue it i would be tempted to buy it.
There is one left in our national railway museum in Utrecht,an impressive machine indeed.
Tack sa mycket!
Paul.
Offline NS1200
#14 Posted : 25 December 2011 17:33:05(UTC)
NS1200
Please compare with a special issue in 1993: Marklin 3419,Dutch BR50 in grey and black,sells currently around Euro 135.- on internet.
This loco also shown in Marklin book 'Wertanlage' (guide for collectors).
Online H0
#15 Posted : 25 December 2011 17:55:33(UTC)
The only point special about this loco: it's the first model announced with this new tooling (but a German version will surely follow).
#16 Posted : 25 December 2011 21:06:57(UTC)
Woohoo!Drool Drool
Ditto here please!
I'm wanting the Br44 as the blue box retro item, i.e. 30470......!!
Beyond that, not sure if I want another Br44, I've got 5 already!
#17 Posted : 25 December 2011 21:18:30(UTC)
Reichsbahn version ASAP, please... BigGrin
#18 Posted : 26 December 2011 08:35:35(UTC)
Western Pacific
Western Pacific,
Tack sa mycket!
Paul.
Thanks Paul,
First on Dutch and Germanic languages. Having Swedish as my mother toungue I understand Danish and Norwegian rather well - both spoken and written - without being capable of speaking or writing it. In school I've studied German and then having travelled to the Netherlands and northern Belgium it was often possible to understand signs and newspaper articles combining my knowledge of German and Enlish as well as Swedish, but I never really understood it spoken. Therefore I took some courses at the Stockholm University sort of just for fun and this means that I now understand relatively well spoken Dutch and as a bonus know some of the words which look similar in Dutch and German without having similar meaning. Getting back to the "slangen" in my dictionary (Wolters Nederlands Koenen) there were many explanantions and among other things the reference to "tuinslang" confirmed to me that remslang means "brake hose". I knew that rem means brake, since my studies and refreshed from driving in NL (most recetly in June this year) where warning signs say something like (I don't remember if this is the exact wording): 'Nieuw wegdek - Langere remweg' or 'New road surface - longer braking distances'.
Second on the Märklin model: Although I probably have more steam lokos than I should a new BR 50 in era III or IV (if they lasted that long) could fit in on my future layout. I would go for a DB version though, since I try to focus on fewer countries now (Sweden, Denmark, Germany, Austria and Italy). (I have a few NS models, but I don't think I'll get any new ones and the same goes for SNCF,SBB/CFF/FFS, NSB and SNCB/NMBS).
Being from Sweden a country without coal mines but lots of rivers suitable for hydro power plants, Sweden started early with electrification of main lines, in part due to the shortages in coal during world war I. This has influenced me and it means that on my earlier layout and on my future, there will be mostly electrified lines and since I'm using models from basically era III through VI, electric and diesel lokos dominate.
Online H0
#19 Posted : 26 December 2011 08:54:15(UTC)
DB had them in regular service until 1975 (using four class numbers after 1968: 050, 051, 052, 053).
There will be versions for era II, III, and IV coming sooner or later.
Offline TimR
#20 Posted : 26 December 2011 16:48:16(UTC)
TimR
Indonesia
I would think the German version will be delivered before the NS version.
Marklin.nl has a habit of late of announcing new models way ahead of Marklin.de
After this year's BR50.40, we can expect Marklin to begin releasing new decapod models.
BR44 and BR52 will surely follow this new BR50.
Some will moan the death of the old articulated decapod models with huge DCM rotor in the cabin,
whose days are now numbered.
But IMO Marklin had been losing ground vs Roco or others in this segment, so the new model is badly needed.
Offline NS1200
#21 Posted : 26 December 2011 17:25:30(UTC)
NS1200
On the website of Marklin.nl it says that release date will be September 2012,surely this means that german versions will be released earlier.
Have no idea why Marklin.nl is allowed to release such information.
Possibly it serves as a teaser in order to digest how many potential buyers are interested in purchasing the model.
Because it will be special production run,M would like to know how many are to be produced,i guess.
The official selling price of Euro 399.95 i find beyond reality in todays economic climate.
For less than Euro 270.- i recently purchased 3 black steamers: Primex BR23 with copper boilerrings,Primex BR01,Primex BR38 with bathtubtender,all factory new in original boxes,but of course spending money is a very personal matter.
#22 Posted : 26 December 2011 17:59:52(UTC)
The three locos you are quoting are all second hand, and toolings from the 1950s or 1960s with primitive detailing and basic motor and eletrical technology. Although they are excellent models they are not likely to fetch the same prices as brand new, state of the art models with digital decoders, sound and other functions. These locos by Roco and Fleischmann are in the same league. Notice that they are in the same price range as the Marklin new loco (more expensive in fact!):
http://www.roco.cc/produ...-der-db-mit-sound-3.html = €404
http://www.fleischmann.d...ive-br-43-der-drg-2.html = €429
Offline vilithejou
#23 Posted : 26 December 2011 18:11:25(UTC)
vilithejou
And preserved versions on era V and VI...
Like 01 150 ref. 39017
Joan Vilarrúbia
vilithejou@yahoo.es
Online H0
#24 Posted : 26 December 2011 18:27:42(UTC)
But the new BR 50.40 has no articulated frame and only two traction tyres (on the fourth powered axle). With a little crease in the track the traction tyres will lift off.
So people might encounter traction problems with this loco on existing layouts where other locos work fine.
#25 Posted : 26 December 2011 20:04:00(UTC)
What strikes me is that plastic loks are nowadays in the same price range as loks which are mainly made of metal... Roco used to be cheaper until 10 years ago or so...
Fleischmann have always made great locos with sturdy plastic bodies (ok I have an old FL all metal lok too...) but Roco have been a bit flimsy regarding the plastic quality over the years... When it comes to model accuracy, both FL and Roco are great - but of the 2 I prefer FL if I can't find a metal one from our favorite German manufacturer...
Offline NS1200
#26 Posted : 26 December 2011 20:23:09(UTC)
NS1200
RayF,
You are fully correct of course about the state of the art technology.
The point i was trying to make is that when you have limited money to spend there are alternative ways of spending it on M trains.
It all depends on your personal interest.
For me,grown up in the late fifties and early sixties,the Primex models are relics of my youth and in actual fact i call them the real Marklin as opposed to the sophisticated models of today with all the added on plastic parts.
For the same reason i prefer the tin plate coaches over the plastic coaches.
The first version of the P8 BR38 in 1967 was a sensation and a must-have,i do recall.
Marklin nearly escaped bankruptcy a year ago and i dear to say that in the current economic climate the average man in the street is not prepared to spend Euro 400.- on a black steamer.
I much more would advocate M to issue more models in the Euro 150.- range,albeit with less detail than the high end models.
I have no insight in Marklin marketing strategies for the years ahead but i consider it likely that the My world budget range will be extended to attract a larger group of buyers,and at the same time a limited release of high end expensive models to satisfy the more wealthy clients.
If it is only going to be locos at Euro 400.- each and starterkits at Euro 1,000.- plus,i foresee a difficult time for the Maerklin shops!
#27 Posted : 26 December 2011 20:57:55(UTC)
RayF,
Actually, I agree with you!
I have all three locos you quoted, plus many more from the 60's, 70's, 80's and 90's. Of the more recent models, I have quite a few of the Hobby models, which I find great value, and I have very few of the high end recent locos.
I was only trying to defend Marklin's pricing of these expensive locos against other manufactures.
#28 Posted : 27 December 2011 10:55:26(UTC)
2012 new items will be on Marklin database before the Nurnberg Toy fair 1-6 Feb 2012.
But some news on 2012 items at middle of Jan 2012.
Offline borntman
#29 Posted : 27 December 2011 16:29:48(UTC)
borntman
Is there any pictures of this sure to be beautiful workhorse?
#30 Posted : 27 December 2011 16:56:11(UTC)
Offline jeehring
#31 Posted : 28 December 2011 16:05:17(UTC)
jeehring
Anymore new items?
....mmmmhhhhh..don't you smell something of "French railways " somewhere ?...a smell of French railways models whose zone of origin is totally unknown...
...mmmhhh...don't you detect a scent of "MHI" ,as well ?
Strange fragrance indeed....Is it me , or are you smelling it , you too ? ...Blink Wink
#32 Posted : 28 December 2011 19:19:43(UTC)
Roland, it sounds like you may know something we don't...BigGrin
Offline mvd71
#33 Posted : 28 December 2011 19:53:17(UTC)
Interesting comment Tom. Thanks for the insightCool I value good running quality and reliability, and the performance you describe is such that I will stick with my outdated BR50's with their articulated frames, noisy motors, and reliability!
It is similar to the comparison between my old tooling E41, and the new tooling E10. I was considering a new version of the E40/41 until my new E10 arrived. What I saw on the new E10 made me decide to stick with my old E41 and maybe just put a new decoder into it.
Cheers....
Mike.
#34 Posted : 28 December 2011 20:25:54(UTC)
Has anyone actually experienced poor traction with these new chassis, or are we just speculating?
I have noticed a tendancy on this forum for speculation to move directly to being "known fact", without the necessary step of anyone actually having run the item in question yet!
I think these new toolings are exiting news, and I'm looking forward to comparing the running characteristics. It might turn out that there is some loss of traction, but the improved smoothness and quite running, as well as the much improved looks and detail accuracy might more than compensate for this.
Online H0
#35 Posted : 28 December 2011 21:43:28(UTC)
I didn't take my loco to the limits yet.
Currently there is a poll on Stummi's forum about the tractive power of the new BR 50.40. 43 % (29 out of 67 voted on "insufficient").
The information about problems with creases in the track comes from this video (German only):
Even though I didn't take it to the limits, I thought the hear-say was worth being reported here.
The old locos are like SUVs, the new ones are like Formula 1 racers. Not all existing layouts may be suitable for Formula 1 racers.
#36 Posted : 28 December 2011 23:10:59(UTC)
Maybe we need to pay a bit more attention to good tracklaying on our layouts to benefit from improved looks and performance!
Offline TimR
#37 Posted : 29 December 2011 08:48:01(UTC)
TimR
Indonesia
From what I gather, the 50.40 also only have 2 traction tires.. which may also be compounding the traction problem.
Not sure as to why they went cheap on rubber bands with a 400 Euro model.
If Marklin fit 4 rubbers on the new BR50, traction may improve over 50.40,
but then again it may never match the older models with articulated frame.
Like many new models, they are most certainly be more sensitive to track laying.
So also like many newer models, beauty has its price.
Obviously Marklin can't go on relying on their older models to carry the day,
especially if what customers are demanding are details and quieter motor.
Online H0
#38 Posted : 29 December 2011 09:22:48(UTC)
Rumours say fewer traction tyres reduce problems with contact and radio interference.
They'd have to do all radio interference tests again if they make such a fundamental design change.
It seems that tractive effort of the new BR 50.40 is not bad if you have smooth transitions between inclines. I still have to make my own tests to find if it's good or just OK (for me).
Only 2 traction tyres could be a problem on C track R1 and R2 turnouts where wheels run on the flanges an traction tyres are lifted off the rail.
At the last club meeting, we had a crease in the track (layout across several tables). BR 50.40 had no problems (even though the fourth power axle with the traction tyres was lifted off at that spot) - but it was pulling a short train (15 cars, 30 axles, all cars running lightly).
Märklin's BR 05 (streamlined) came to a stand-still at that spot (presumably with all powered axles hanging in the air). Two pieces of cardboard fixed the problem for the BR 05.
Offline NS1200
#39 Posted : 31 December 2011 18:07:37(UTC)
NS1200
According to shopkeepers on Ebay.de presentation of 2012 new items for invited guests is on 28th January 2012.
#40 Posted : 02 January 2012 16:37:39(UTC)
First new items 2012 detail (still yet to confirm.)
37436 Electric locomotive BR 143 DB AG.
36426 Diesel locomotive BR 232 PCC rail.
37318 BR 111, DB AG.
37462 Series re 460, SBB.
39895 BR 189.
And possible all new BR94.
Maybe BR45 (75 years of class).
Offline Armando
#41 Posted : 02 January 2012 23:19:21(UTC)
Armando
39895 BR 189.
Where did you get this information from? Or is this pure speculation?
Cheers!
Armando García
Online H0
#42 Posted : 02 January 2012 23:22:32(UTC)
The information is from Stummi's forum. The 37318 was already reported in earlier years.
Some enthusiasts play trial and error to find explosion diagrams or other evidence for unknown locomotives.
The PDF file for 39895 was created in March 2008. Whatever that may mean ...
Offline TimR
#43 Posted : 03 January 2012 04:07:09(UTC)
TimR
Indonesia
I think 39895 was one of the "special edition" models not released to general public, similar to ICE-1 39712.
If I wasn't mistaken, I saw one on eBay a couple years back with sky-high sticker price.
It'd be lovely to see some SDS models this year, but I don't think it will happen.
37436, 37318, and 37462?
... more new releases of models with obsolete DCM motor, complete with super noisy drivetrain to drawn out any sound effect, and such imprecise engineering that rarely I got one running perfectly straight from the box...
ThumbDown Yawn!
#44 Posted : 03 January 2012 04:55:03(UTC)
39895 BR 189.
Steventrain,any confirmed steam locos?
Online H0
#45 Posted : 03 January 2012 09:26:00(UTC)
All confirmed Märklin locos are steam locos (see first post: BR 50, Dutch version).
Everything else is rumour, speculation, wishful thinking, ...
Offline RMW
#46 Posted : 03 January 2012 12:09:41(UTC)
RMW
Hello all,
You can find the first new items now in a PDF-document on my website: RMW - Märklin News 2012.
Maikel (RMW)
Rensen Modelbaan Wereld - Since 1963
RMW - Website
RMW - YouTube
Offline monster134
#47 Posted : 03 January 2012 12:14:37(UTC)
monster134
Hi guys.
Just so that we are clear. I doubt the non-articulated frame of the new 50.40 is the problem. I have run it around Monsterville, and solo, she is fine. Never saw it lift a wheel.
However, it cant pull skin of a rice pudding. the ONLY problem with this loco, and the BR42 for that matter, is the single axle with traction tyres. WTF were they thinking?
As to the tracklaying problem.... i dont buy it. If i build a layout without a single level, and all one dimensional, my trains will run. Bullshit, i built a layout and all my older decapods ran nicely. Now i sit with a very expensive loco, but Marklin saved some money on rubberbands.... and i have to redo the whole layout.Confused
The ROCO tender driven Decapods pull better.
Offline Ratatouille
#48 Posted : 03 January 2012 13:13:25(UTC)
Ratatouille
#49 Posted : 03 January 2012 13:14:47(UTC)
Looking forward to seing pictures of the Br94! ThumpUp
Offline Frankenbahner
#50 Posted : 03 January 2012 13:46:56(UTC)
Frankenbahner
It seems as like the VT 75 could be an improved re-edition of the model made by Trix years ago. I think I'm going to order it, as it served on many branch lines in this region.
The BR 94, on the other hand, does not thrill me very much, because I already own the excellent Fleischmann model, a DB version as well as the KPEV Länderbahn version.
Florian
H0 3-rail AC with DCC, MM and mfx, 2-rail DC streetcars, and N gauge
7 Pages123>»
This page was generated in 1.382 seconds.
