Offline GSRR
#1 Posted : 23 November 2011 06:32:09(UTC)
GSRR
ESU SwitchPilot (k83) + M* 74490 motor
Has anyone been using the SwitchPilot on their layout to control the 74490 C track motor? Good or bad?
r/Thomas
Offline Sander van Wijk
#2 Posted : 23 November 2011 14:35:39(UTC)
Sander van Wijk
Hi Thomas,
Several of my friends have used these items combined succesfully. Given that the 74490 / 74491 are regular electric turnout mechanisms triggered / driven by a single pulse, I would not see any reason why it should not work. Most of ESU's stuff is simply very functional, and I do not see any reason to believe the SwitchPilot be an exception to my positive experience. Particularly not with the ECoS you are already using.
Sander
Offline efel
#3 Posted : 23 November 2011 14:43:09(UTC)
efel
I agree with Sander.
Just be aware that switchpilot delivers negative pulses instead of positive.
That doesn't matter for turnouts, but some special uses may give problems, as already related on this forum
fred
Offline GSRR
#4 Posted : 23 November 2011 15:15:14(UTC)
GSRR
Thank you Sander and Fred.
The plan is to use my ECoS with the new M* 74491 motors and some new ESU SwP. I am also getting some Viessmann signals, which I believe follow the M* protocol, is that the positive pulse?
I do have some VS k83 for the VS signals if the ESU SwP is not compatible.
r/Thomas
Offline NZMarklinist
#5 Posted : 23 November 2011 15:39:16(UTC)
NZMarklinist
Hello Thomas,
Lets know how they work out, I ordered an "ESU Swp" by mistake Blushing instead of a "Switch Pilot Servo" to operate four Servos I intend to use on my K track layout where a series of curved turnouts with the standard K track turnout motors look a bit ugly. I now have a "Switch Pilot Servo" decoder but was hoping the "Switch Pilot" would work the other M turnout motors properly. If I like the Servos, I will probably use more of them. That will be in my layout thread when I start it !!Blink
Glen
Auckland NZ
Offline GSRR
#6 Posted : 23 November 2011 16:02:28(UTC)
GSRR
Originally Posted by: Sander van Wijk Go to Quoted Post
Hi Thomas,
Sander,
I wonder if when able you could ask your friends what pulse time they favor? I think the SwP defaults at 500ms?
r/Thomas
Offline GSRR
#7 Posted : 23 November 2011 16:04:45(UTC)
GSRR
Hello Thomas,
Glen,
will do, it will be a while. These should ship from Germany next week, waiting for some other pieces also.
r/Thomas
#8 Posted : 23 November 2011 21:56:28(UTC)
Thomas,
I am using the Viessmann version of the K83 and M turnout motors. No problems.
Ne
Offline GSRR
#9 Posted : 23 November 2011 22:00:58(UTC)
GSRR
Thomas,
Ne
Hi Nev.
I have a couple of the VS k83 in a box unused, likely I will hook them up to the VS signals. I went with the ESU SwP, we will see.
r/Thomas
Offline nmarques
#10 Posted : 23 August 2012 12:07:04(UTC)
nmarques
Hello!
Is it possible to use M74490 with switch pilot and have slow switching speed of the turnout with the proper configuration on the Switch pilot?
Offline efel
#11 Posted : 23 August 2012 12:50:39(UTC)
efel
Originally Posted by: nmarques Go to Quoted Post
Hello!
No.
To get a slow switching speed you have to use the "servo" output of the switch pilot AND a servo motor INSTEAD of the 74490.
74490 only gives quick switching speed .
Special motors like tortoise gives also slow speed but with a special control (i.e. not directly drivable by SP.)
Fred
This page was generated in 0.336 seconds.
