#1 Posted : 31 October 2011 22:11:17(UTC)
My one digital signal so far, would work 20% of the times my layout was operating. The other 80%, it just showed both red and green lights together, and I could not switch between aspects using the CS1.
Anyway, my electrician rebuilt our household switchbox (it was 50 years old), and installed safety cut-offs on all circuits. Surprise to find that the layout shed circuit just kept tripping the switch. On investigation, a slow leak to ground was found in one of my appliance sockets. This was due to little lizards called Geckos inhabiting said box.
Now my digital signal works perfectly.
What happened to the Geckos? Well we covered the hole they were using as access, and I believe they moved house.
Offline ak_marklineer
#2 Posted : 31 October 2011 22:32:15(UTC)
ak_marklineer
hahahahaha Quite fascinating though it must be said, good work from the Sparky to find the leak (yes I know it's his job)was the earth leakage in the wall socket you were using? Where I live the house is always blowing light bulbs and is at least 50 Years Old, though I do have reliability of circuit through the wall sockets, here in NZ we use 230 Volts as opposed to 240 Volts in Aus
Steve
German DRG ERA II
MSIG of The Auckland Marklin Club Inc
www.marklin.org.nz
CS1 with WiFi
TouchCab with iPhone
#3 Posted : 31 October 2011 23:04:28(UTC)
Originally Posted by: ak_marklineer Go to Quoted Post
hahahahaha .....
was the earth leakage in the wall socket you were using? Where I live the house is always blowing light bulbs and is at least 50 Years Old, ....
Hi Steve,
The offending 3 pin socket is used permanently by a small lamp for ambient lighting when dark.
That is so I can make my way through the shed to the light switch.
That is metres away from the train transformer sockets, but was enough to cause problems in that whole circuit. The household is divided up into 7 different circuits, now there are 4 circuits with individual safety switches, and another 3 circuits share one safety switch.
#4 Posted : 01 November 2011 00:01:54(UTC)
Well I bet you're pleased that's finally sorted.
Brings to mind a similar story...
It's common practice in England to ring a telephone by signaling extra voltage across one side of the two-wire circuit and the ground (earth in England). When the subscriber answers the phone, it switches to the two-wire circuit for the conversation. This method allows two parties on the same line to be signaled without disturbing each other.
Anyway, an elderly lady with several pets called to say that her telephone failed to ring when her friends called; and that on the few occasions when it did ring her dog always barked first. The telephone repairman proceeded to the scene, curious to see this psychic dog.
He climbed a nearby telephone pole, hooked in his test set, and dialed the subscriber's house. The phone didn't ring. He tried again. The dog barked loudly, followed by a ringing telephone.
Climbing down from the pole, the puzzled but intrigued telephone repairman found:
A dog was tied to the telephone system's ground post via an iron chain and collar, but the post was loose and poorly connected
The dog was receiving 90 volts of signaling current.
After several such jolts, the dog would start barking and urinating on the ground.
The wet ground now completed the circuit and the phone would ring.
Which shows that some problems can be fixed by just pissing on them !
#5 Posted : 01 November 2011 00:37:27(UTC)
Which shows that some problems can be fixed by just pissing on them ![/i][/size]
Yes, electricity is a bit of a mystery. That story rings? true. BigGrin
The one wire telephone circuits (SWIRE single wire earth return) were very common in rural Australia till the late 70s.
My digital signal worked perfectly for at least 6 months and gradually developed the strange intermiitant fault, as described above. It got to the point where it hardly worked at all. The reasons are now clear.
I phoned my dealer, and I phoned Marklin service, and the only suggestion was to return it to the factory. It was out of warranty so I figured the cost of this routine would be better spent on a brand new one. I had not got around to it, as some home renovation interceded, and that solved the problem!
#6 Posted : 01 November 2011 04:52:33(UTC)
I wouldn't recommend it with 240 volt electricty
Offline Hoover007
#7 Posted : 04 November 2011 03:14:03(UTC)
Hoover007
Just to chime in on this conversation, here in Phuket, Thailand the power is VERY unstable. It varies by as much as 10 volts! As rule of thumb the power should be 230 volts, but I have seen it as high as 234V and as low as 222 V. To protect my digital equipment I purchased a computer power backup with a voltage stabilizer. I did not really care about the power backup I wanted the stabilizer to minimize the fluctuations. Fingers crossed everything is working fine so far. Cursing
thanks 1 user liked this useful post by Hoover007
Offline Jon11
#8 Posted : 04 November 2011 07:47:17(UTC)
Jon11
I have a high quality UPS with sine wave output. The voltage is all over the place. Here is a graph over a 24 hour period.
Jon11 attached the following image(s):
Z Gauge, Black Forest layout
How dare you have clear arteries after all the cheese & wine you’ve had!
#9 Posted : 04 November 2011 08:00:05(UTC)
In Germany the specification allows +/- 10 % (that makes a span of 46 V at 230 V). I wouldn't worry if the voltage varies by 10 V.
Should be no problem for devices with switch-mode power supplies.
Short voltage drops or peaks could be a problem.
I don't have a UPS yet.
This page was generated in 0.430 seconds.
