General topics
H0-scale
C-track knock-offs (chinese?).. [edit] no.. problem solved.. it was Alpha Track
Joined: 16/10/2001(UTC) Posts: 793 Location: Pittsburgh,
I got some C-tracks on e-bay. I had them under my desk here at work for a while since I was not planning on using them. I got 12 x 24172 and 12 x 24130 Upon detailed inspection, I can see that the two elements are different. The 24172 appears original while the others are clearly knock-offs, probably made in China. Some tell tale signs: - ballast color and size slightly different - rail size slightly different - the metal connectors underneath are copper color and not "silver" color - connection between the tracks does not work well as the little "tab" at the end under one rail is missing (the tab secures under the opposing rail and ensures perfect alignement If you want, I will follow-up later with pictures. I wonder if you have experienced chinese knock-offs for C track as mine. I will most likely trash the knock-offs. If they were straight I could have used them for static displays but as they are curves I will not be able to use them there either. Edited by user 28 October 2011 15:01:50(UTC)
| Reason: Not specified |
Joined: 01/02/2004(UTC) Posts: 7,460 Location: Scotland
Not much help but never had any bother with C track since I started buying it years ago. The only thing I would say is dont buy from ebay. Can you send it back for refund.
dave |
Take care I like Marklin and will defend the worlds greatest model rail manufacturer. |
Joined: 05/12/2004(UTC) Posts: 2,990 Location: CA, USA
I don't have a piece to look at, nor have I seen yours, but those may actually be real- just from the very early production. I know for sure the ballast was a different shade of grey and the tabs broke on the plastic.
Can you post an image? |
SBB Era 2-5 |
Could the different ones maybe be Alpha tracks? |
Juhan - "Webmaster", at your service... He who asks a question is a fool for five minutes. He who does not ask a question remains a fool forever. [Old Chinese Proverb] |
I will take some pictures a bit later at home.
Underneath both say Marklin buth while the 24172 says 'Made in Germany' the 24130 says 'made in W Germany' which may indicate a very early model. |
Joined: 15/02/2008(UTC) Posts: 693 Location: Bournemouth, Dorset
Yes, I would be interested to see the photographs, like Juhan I wonder if they maybe Alpha Tracks.
Though there have certainly been instances of fake counterfeit Märklin Trains in the past. If I remember correctly I think one such case centred around the Northlander Train Pack, but others here may have more information.
Joined: 15/03/2003(UTC) Posts: 9,597 Location: Australia
You don't get any of this nonsense with m-track.. |
Adrian Australia flag by abFlags.com |
It may well be alpha track. I found this e-bay link http://www.ebay.com/itm/Marklin...2ea8f11f15#ht_500wt_1413Underneath it is stamped with the number 2031 so I guess it is this track I was not aware of this product as I started with Marklin in 2000 and based on C track. Was this a predecessor? |
Yes the Alpha-Track was a sort of predecessor to C-Track.
The 2031 is the "outer radius" curve and thus 456.4 mm radius. Inner radius would have been 2021, and 2001 is the straight (180 mm) piece (a few more types were available). The Alpha-Track also had a different rail-profile (I think it was slightly higer than C-Track).
The Alpha-Track was issued with the "futuristic" Alpha-line of trains could it have been in the early 90's? Not sure of exactly when, but they didn't last long. Then came C-Track with the same "style" yet different gemoetry, color and the mentioned rail-profile. |
Fredrik.
WWW: MJ-fjärren |
 1 user liked this useful post by Fredrik
Originally Posted by: Fredrik  Yes the Alpha-Track was a sort of predecessor to C-Track.
The Alpha-Track was issued with the "futuristic" Alpha-line of trains could it have been in the early 90's? Not sure of exactly when, but they didn't last long. Then came C-Track with the same "style" yet different gemoetry, color and the mentioned rail-profile. Thanks for the info. Can i then use alpha with C track? I guess so but what would I do with the 2031? Is it comparable to a R2 in C track? |
Originally Posted by: MarioFabro  Originally Posted by: Fredrik  Yes the Alpha-Track was a sort of predecessor to C-Track.
The Alpha-Track was issued with the "futuristic" Alpha-line of trains could it have been in the early 90's? Not sure of exactly when, but they didn't last long. Then came C-Track with the same "style" yet different gemoetry, color and the mentioned rail-profile. Thanks for the info. Can i then use alpha with C track? I guess so but what would I do with the 2031? Is it comparable to a R2 in C track? I would say "can" - but I wouldn't use it myself, nor recommend it...! You will have to either live with the difference in height of the rail profile, or you will have to smoothen it out. And the (straight) lengths doesn't match the C-Track. And finally the 2031 do not match a C-track R2 yet will be an "exotic" radius curve. |
Fredrik.
WWW: MJ-fjärren |
Joined: 31/12/2010(UTC) Posts: 3,999 Location: Paremata, Wellington
The Alpha-Track was issued with the "futuristic" Alpha-line of trains could it have been in the early 90's? Not sure of exactly when, but they didn't last long. Then came C-Track with the same "style" yet different gemoetry, color and the mentioned rail-profile. Here's some info re the Alpha track Cheers Cookee Melbourne cookee_nz attached the following image(s): |
Cookee Wellington  |
General topics
H0-scale
