2 Pages12>
Offline kariosls37
#1 Posted : 23 May 2011 11:40:23(UTC)
kariosls37
In my layout thread, I have introduced my next project.
I have had this 3005 BR 23 for a while now. I bought it for a very good price as a repair job.
Part of the left hand valvegear was broken, and the housing was not in top condition. It was in good electrical and mechanical order, and runs pretty quietly.
This is how it looks now:
I have already touched it with a paintbrush, to keep it reasonably presentable. However, this is the plan:
-Strip as many metal parts as possible. I may or may not strip the chassis, depending on how easy the wheels are able to be removed and reassembled.
-Repair any blemishes in the metal. There is a little bit of rust and some chips that need work
-Add lighting and coal to the tender
-Paint loco and tender
-Weather the loco
-Add a decoder
My intent is not to bring it back to a factory new condition, but to improve some points to reflect how I think it should look and function.
This should be a straightforward job for me after building locos and kitsets, and like always, I hope it will be a fun little project.
Rick
#2 Posted : 23 May 2011 11:57:45(UTC)
Views messages in topic : 31,704
Good luck on your project.
Keep posted soon.
Offline Ian555
#3 Posted : 23 May 2011 12:02:41(UTC)
Ian555
Hi Rick,
Will be following your project closely, lots of photo's please.
I've got 2 BR23's that need some work done to them, so this will be very interesting.
Ian.
Offline kariosls37
#4 Posted : 23 May 2011 12:11:52(UTC)
kariosls37
Thanks Steven and Ian
I will try and go into some detail as to how I will go about this. If you have any questions during the build, fire away ThumpUp
Happy modelling
Rick
Offline Darren W
#5 Posted : 23 May 2011 17:46:00(UTC)
Darren W
Please let us know how you make out with any paint stripping and what kind of paint you use. I also have a 3005 BR23 that needs a little cleanup. A previous owner has done some paint matching that doesn't match well and I would like to tear it down and build it back up. Great topic that will be followed by many.BigGrin
Darren
Offline TrainIride
#6 Posted : 23 May 2011 18:03:10(UTC)
TrainIride
Hi Rick,
I'm impatient to see more pics of your works.
I'm sure you will succeed and I will learn lots of things on how to refresh our old steam ladies.
I just have found a 3005 dated 1962, (with a fragile paint, I'd also like to learn how to renew it.)
Joël
Offline kariosls37
#7 Posted : 24 May 2011 11:40:09(UTC)
kariosls37
Thanks for the encouragementThumpUp
Today I made a start by disassembling the engine. I took off all the parts that could be screwed off, but as there are a few bits attached to the chassis I decided to leave the electrics on the chassis as they are.
The first bits to go into two way thinner. A gas mask should be worn because this is nasty stuff.
Once the thinner had time to soak in, I scrubbed off the soft paint with an old stiff paintbrush. The black paint Marklin used was reasonably sturdy, but dizzolved nicely after a while. The red paint was a bit harder to get off, but it came off eventually.
here are the loose parts:
You will notice only the right hand valvegear is there, this is because the left hand set needs replacing.
Next to swim was the housing
The same process was used, scrubbing, soaking and more scrubbing until it was clean.
While it was soaking, I started work on the tender. To begin, some burrs left over from the moulding process were filed smooth. The lights were drilled out next. I did this by hand, in three steps. First, a small pilot hole was drilled, makeing sure it was dead centre. Then the hole was opened out to 1.5mm, and to finish off, a hole just smaller than the light housing was drilled about 1mm deep.
Here one light is done, and the pilot hole is being drilled out in the other.
One thing I noticed on photos was the handrails extending above the tender. These are are not on the model, so I added them. In real life these are extensions to the handrails with steps on the back of the tender. The ladder on the tender is moulded on the model, but there is a gap around the lights, as you can see from the previous photo. Two 0.5mm holes were drilled in the top of the tender, and a suitable length of 0.5mm wire was bent to shape. I guessed the length and adjusted it until it looked right. There are plenty of other discrepancies on the model, so I figured one more slightly incorrect length would not make a diffrenceSmile The gaps around the lights were also filled with some 0.5mm wire cut to length.
On a few photos of ther real thing, one or two of the handrails were bent, so I did the same.
In the meantime, the housing was scrubbed clean. It looks a bit nude now...
Happy modelling
Rick
#8 Posted : 26 May 2011 14:22:04(UTC)
Rick,
Good process.
What I'm waiting for are painted boiler rings and the loco numbering, need some advise on this which I assume will come in due course.
#9 Posted : 26 May 2011 15:55:05(UTC)
Good process.
Offline kariosls37
#10 Posted : 27 May 2011 12:46:57(UTC)
kariosls37
Thanks John and Steven
I'm afraid there will be no boiler bands on this one John, but I have done it before and it's not hard. I will make some photos tomorrow.
Work has continued on the tender and the housing.
After stripping, the housing was cleaned with cream cleanser, the type you clean bathrooms withCool While it can remove the last traces of paint, I found a few spots that were not clean enough, so into the tinner it went again.
Another scrub with a toothbrush and cream cleanser folllowed, and the whole thing was thouroughly cleaned. You don't want any of the cleanser left on the model, as it wreaks havoc with the paint finish.
While the housing was soaking in thinner, I did some work on the tender. The rear lights will be lit by small incandescent bulbs, which throw light in all directions. In order to prevent any light leaks, The bulbs will be mounted in brass tubes. The tubes were cut to length and one side was filed flat so they would fit close to the tender sides. The tubes were glued in place with Araldite, a two part epoxy glue.
On the left is one of the bulb holders. Once painting is done, bulbs will be slid in from the front, with the rear ends of the bulbs painted black to stop light leakage.
That's all for now,
Rick
Offline kariosls37
#11 Posted : 29 May 2011 11:26:18(UTC)
kariosls37
With the housing thouroghly clean, it was primed. I use Tamiya primer. you should aim for a coat that is as thin as posssible, while still covering everything. I tend to err on the thin side, as more can always be added.
Once it had some time to cure, I filed down all the spots that had become raised due to zinc pest. Rough spots are much easier to see whith the primer on than without. I also discovered that there were some rough spots on the top of the boiler, including file and grind marks. Seeing as the origional paint was still on it, It must have been done in the factoryScared I guess even then Marklin didn't always get it right. A coat of light coloured paint can be very revealing, I noticed the housing and tender both read DA 800. She's an old galCool Purists have been warnedTongue I actually quite like just how much detail is on the loco. In black you notice this much less, but there's a fair bit, considering the age of the tooling.
Anyway, back to the overhaul.
With the first bit of filing out of the way, Tamiya putty was applied, and it was left overnight to cure.
As I'm not giving the boiler bands any special treatment, I thought I would show how I would paint them.
There are two ways to do it: Either do the band colour first or second. If you can get strips of masking tape cut to the right width evenly, you can paint the band colour, then apply the tape strips and paint the cladding colour. The major downside to this is that it is extremely hard to cut strips of tape that have an even width across their lrngth, and it is very hard to get the tape dead straight.
I prefer to use method number two: cut strips of tape that are slightly wider than half the space between two boiler bands. The width is not critical, as long as one side is dead straight. Now cut the tape to length. it may be easier to cover one side of a boiler band with multiple pieces, especially if you have a lot of piping to mask around.
I cut all my tape on a clean pane of glass(I use a broken one from the fireplace) Which ensures that the tape will still stick and the cuts are perfectly clean.
Start by pulling the tape under any handrails or other pipes by poking one corner through first and then pulling the rest through with tweezers. Be careful not to let it stick to the boiler. Now bring the tape to where you want to start taping, and pull the tape tight and sligtly against the edge of the boiler band. Use the ridge of the band to your advantage. As you work around the model, work slowly and push down on the tape with the back edge of a hobby knife or a piece off wood to make the tape stick. If you make a mistake, pull the tape back and try again.
When a moulded on obstace is reached, I push the tape into the corner before going over the pipe, beng careful not pull the tape out of the corner.
Once the sides of the bands are done, I go over any other spots with small bits of tape.
Then we are ready to paint:
Rick
thanks 1 user liked this useful post by kariosls37
Offline FMS
#12 Posted : 29 May 2011 13:57:41(UTC)
FMS
It seems that it's going to be just great!Wink
FMS
#13 Posted : 29 May 2011 19:58:38(UTC)
Hello Rick.
This looks great.
I have a Primex 33005, which is a newer model based on the 3005.
As it was new when I bought it, I have only converted it to digital and installed rear light in the tender and interior light. A smoke unit will be installed later.
If you like, see 33005 rebuild
Offline kariosls37
#14 Posted : 01 June 2011 11:44:05(UTC)
kariosls37
Thanks Fred and Svein
Your rebuild looks very good as well Svein, especially as your's is a few decades younger than mine and a bit more detailed. Aftre seeing your model I now have to install windows in mine as wellThumpUp
#15 Posted : 01 June 2011 13:06:17(UTC)
Our in house restorer,
looks very professional.
let me know where you get the windows from.
Edited by user 01 June 2011 17:25:56(UTC)  | Reason: Not specified
Offline kbvrod
#16 Posted : 01 June 2011 14:13:43(UTC)
kbvrod
Rick,excellent job!I think a *sticky* when done, is in order here as will help many in repairs/restorations!
John,I use the clear plastic inserts from a variety of sources.
Dr D
Our in house renovator,
#17 Posted : 01 June 2011 17:27:55(UTC)
Dr.D.
thanks for the tip
Had the same idea and I've already inserted them into the BR 23, the only difference is they don't have recesses.
Offline Johnvr
#18 Posted : 02 June 2011 08:21:39(UTC)
Johnvr
Rick,
I am watching this thread with interest.
Because the DA800 is one of my favourite engines.
I received my first one in 1969 as a birthday present from my parents.
I have 2 x DA800 and 1 x 3005, all of them with decoders installed.
But without tail lights and smoke unit, as John has done.
Regards,BigGrin
Offline kbvrod
#19 Posted : 03 June 2011 20:31:02(UTC)
kbvrod
Maybe -off topic- and I don't want to take away from Rick's fantastic work/thread,...
John,I have used clear inserts from Piko/Lilliput wagens and even some tools and etc., that use clear plastic for packaging.
Simply measure the 'frame',cut,clean,place and glue.Much more to scale than factory windows.
Dr Dirt
Dr.D.
thanks for the tip
Offline kariosls37
#20 Posted : 04 June 2011 12:44:12(UTC)
kariosls37
Thanks for the flattery everyoneBlushing
I will do the windows as follows:
-Take some clear plastc sheet and cut slightly oversize
-File to exact size
-insert with Krystal Klear
More detail will follow as I get around to it.
As I live far away from the civilised world(at least Marklin seems to think so) I try to be as self sufficient as possible as obtaining parts slows down projects way too much, so you will see a bit of improvisation along the way. That, and I am of the opinion that I can do some things better than MarklinFlapper
I have been a little quiet this week as other things have kept me too busy to do any modelling. Hopefully progress will start again over the next few weeks.
Rick
#21 Posted : 04 June 2011 15:51:07(UTC)
Dr Dirt
Dr.D.
look under black beauties
thanks for the tip
Offline Ian555
#22 Posted : 04 June 2011 16:04:45(UTC)
Ian555
Hi Rick,
Coming along very nicely. ThumpUp
Ian.
Offline Brakepad
#23 Posted : 05 June 2011 01:51:24(UTC)
Brakepad
France, Metropolitan
Here's a link for a tip (thanks to Intruder) if you want to get glazed windows like the ones in old Märklin models.
https://www.marklin-user...ranslucent-material.aspx
Offline kariosls37
#24 Posted : 27 June 2011 12:13:52(UTC)
kariosls37
More progress at last
I finally decided to bite the bullet and get the wheels off so I could strip the frame. The way went about this is quite crude, but it has worked. Once everything that could be screwed or soldered off was removed, the area around the wheel to be removed was supported as best as it could. The axle was then carefully tapped out with a hammer and nail. This was repeated for each wheelset. The plastic gear between the motor and the rest of the gear train was also removed as I didn't fancy it's chances against the paint thinner I use. The usual stripping routine was then followed.
Here are the bits before final cleaning up
Ooh, shiny!
Fortunately, the frame does not need any other work done to it.You can see some red left, but I'm leaving it because where it is. In the corners, strength will not be as inportant. What's left is thin, so it won't be seen over the final coat anyway. On the leading and trailing pony truck wheels, the paint was so strong that it didn't budge, so I will leave it be and just paint over it.
The engine housing is still being fillered. Filler holds on very poorly to zincpest, so it either has to be removed, or alternative methods have to be used. On the back of the cab roof, a rectangular slot was filed into the affected portion. A bit of styrene was then superglued into place, and this was then filed to the right shape. in another place pure superglue was used by itself as filler.
Primer should arrive by the end of the week, so hopefully things will move faster soonWoot
Rick
Offline kariosls37
#25 Posted : 27 July 2011 11:18:54(UTC)
kariosls37
Due to supply problems, I still dont have plastic primer. This is the primer I have used until now, as it is especially made for modelling purposes. However, I have done something I have wanted to give a go for some time.
Elsewhere I have heard of automotive etch primer being used. Etch primer is a special primer that bonds very well to metals, so it is ideal for models that get a lot of (ab)use. The catch is, it usually comes in spray cans that will inevitably drown out details on models. There is a way around this. First I spray the paint into the jar of my airbrush, and then I apply the primer with the airbrush.
All the bits that have to remain metal were masked and the remaining gears were removed before I fired up the airbrush. All the metal bits are now ready for some colour.
Proof:
The result looks slightly blotchy, this is because I prefer to have my coats as thin as possible, to minimise the loss of detail. The darker bits just have a little of the bare metal showing through. This should have no effect on any top coats.
As for the etch primer, The jury is still undecided. It was a bit hesitiant to come out of the aibrush, but the finish looks reasonably good at first sight. A great advantage over the usual method is the control that the airbrush gives in applying the paint.
As soon as I can prime the plastic bits, I will paint the loco. I want to do all the bits at the same time because it is very easy to get colour mismatches if the painting is done in two sessions.
Offline kariosls37
#26 Posted : 05 August 2011 13:02:39(UTC)
kariosls37
In between the NZR stuff, I've found time to airbrush a coat of red onto all the bits of the BR 23.
I have used Humbrol no. 19, gloss red with a few drops of white. Gloss paint is tougher than the same paint, which is a good thing especially if you will be handling the model much. The drawback is that the paint dries a lot slower.
I've also given the tender wheels a coat of black. My reasoning is: It is logical that these parts would be painted black. If they ware not painted black, they would very quickly become black in serviceBigGrin
All the parts
And the chassis
As you can see, I have painted the tender bogie frames as well. Even though they are red already, the bare plastic just doesn't look right.
Offline ac jacko
#27 Posted : 05 August 2011 13:47:18(UTC)
ac jacko
Looking great sir Cool
Offline kariosls37
#28 Posted : 07 August 2011 11:26:18(UTC)
kariosls37
Thanks DaleThumpUp
Offline Chris6382chris
#29 Posted : 07 August 2011 19:09:14(UTC)
Chris6382chris
Great work. I can't wait for the finished product.
Chris
#30 Posted : 07 August 2011 19:49:56(UTC)
Excellent work.
Offline kariosls37
#31 Posted : 08 August 2011 11:57:32(UTC)
kariosls37
Thanks Steven and ChrisThumpUp
The next step is a round of masking before I can do the black, which is the last really big job.
Rick
Offline kariosls37
#32 Posted : 22 August 2011 12:23:45(UTC)
kariosls37
I've been able to find some time to mask and paint the loco. It was not so much the painting that took a lot of time, but the masking. This has to be done well, else you are left with a heap of touch ups.
Masking may look daunting when you start, but you have to start somewhere, and once you have, the difficult spots will not look nearly as daunting.
And once everything is masked, it can be painted, with this result:
Note that I have taken some photos with flash and some without, the colours are the same shade throughout the model.
When masking models, don't use normal painter's tape, as the paint will stay on the tape, and not the model. Use proper modelling tape instead. Also, the longer the tape is on the model, the more chance the tape has to attach itself to the paint below, so in order to prevent paint from pulling off, I try to remove the tape as soon as the fresh paint allows.
I still have a fair bit of touching up to do, which will be done with a paintbrush and a steady hand.
If you have any quiestions, don't be shy.
Rick
#33 Posted : 22 August 2011 12:56:58(UTC)
I'm astonished ThumpUp ThumpUp
#34 Posted : 22 August 2011 13:19:55(UTC)
Great job Rick!
Offline Johnvr
#35 Posted : 22 August 2011 17:01:26(UTC)
Johnvr
Rick,
Agreed, great job, the finishing colours on the body look excellent !
Regards, BigGrin
Offline Ian555
#36 Posted : 22 August 2011 18:22:53(UTC)
Ian555
Hi Rick,
Great looking job. ThumpUp
Ian.
#37 Posted : 22 August 2011 18:47:06(UTC)
Great job.ThumpUp
#38 Posted : 22 August 2011 22:27:05(UTC)
I agree with all of the above.
Great job, Rick!
#39 Posted : 23 August 2011 01:04:43(UTC)
Psssst, Hey Rick, you wanna restore my 3005 next........??? WinkWink
Offline kariosls37
#40 Posted : 23 August 2011 10:39:19(UTC)
kariosls37
Thanks everyone for your kind commentsThumpUp
I'd like to point out that this stuff is not nearly as hard as some people think. This is my first full strip down and repaint, and I'm constantly learning. With a bit of confidence, care and patience almost anyone can do this.
BDNZ, maybe, depending on condition and time availability. PM me with some photos of the loco if you are serious about a decent repaint. I'm not going to offer my 'services' to anyone and everyone, my time is limited and these jobs can take a fair bit of time(though the BR 23 project is a 'back burner' project for me). This is my leisure time after all, but I'm happy to do the odd job here and there for the good of the hobby.
Rick
#41 Posted : 23 August 2011 14:10:30(UTC)
Rick
Looks like you did a super job here.ThumpUp
Did you remove the hand rails before painting?Confused
I hesitated a long time before doing it myself for these type of repaint: while dissasembling many little fixtures would break...Cursing
But after I figured Ritter had the parts to replace broken/ bent fixtures, I did it systematically, and carry a supply of these parts systematically!Wink
This also gives an opportunity to remove little blemishes on handrail and repolish them properly.(Keeps you busy as you listen to the paint drying...LOL )
Only then did I get a real *factory fresh* look.ThumpUp
#42 Posted : 23 August 2011 17:05:32(UTC)
Unless some one has done it before, most train model enthusiasts don't realize how long it takes to do these things.
We do enjoy doing it but there is a great time factor involved in it, which you cannot convert into dollars.
regards.,
#43 Posted : 23 August 2011 22:26:14(UTC)
regards.,
No kiddin'!
Labor of love is what's it's called.
My display shelves are full of them...
#44 Posted : 23 August 2011 22:29:24(UTC)
regards.,
No kiddin'!
Offline kariosls37
#45 Posted : 24 August 2011 12:17:26(UTC)
kariosls37
Merci Jaques
I didn't remove the handrails, I just painted over them. Why? because in real life they were black. On my model, the wire was so hard that the wire is already partially fractured from when the model was made, so I would have to get new ones if I were to remove them. Mine had lost most of the shiny plating anyway, so they would have to be replaced if I were to restore the model to original condition, but I'm not doing that. A good bet for replacement wire would be stainless steel wire, if you can get it. Then you will never have to worry about rusty handrails again.
John, you are absolutely right. If I were to be paid minimum wage for this restoration, I would probably earn three or four times the value of the restored loco. I do it more for fun than anything else. It is quite a good feeling to see the finished model knowing you (re)built itThumpUp
Live workshop update:
Today I did some touch ups between working on A 300. Nothing exiting, but it is another step closer to the goal.
Rick
#46 Posted : 24 August 2011 12:22:40(UTC)
Rick, I wasn't serious about getting you to restore my Br23, it was just a 'WOW' reaction to the quality of your work.
A former colleague repainted mine a few years ago, he used a Tamiya flat black paint. It looks reasonably OK, but I also have the new 30050 Br23 if I want a new example.
Offline Brakepad
#47 Posted : 24 August 2011 13:58:44(UTC)
Brakepad
Rick,
I had the same issue about handrails in the past. I found a quick, easy, cheap and rust-free solution.
And the results is very good in my opinion. See:
https://www.marklin-user...aspx?g=posts&m=96727
Regards.
Offline kariosls37
#48 Posted : 25 August 2011 12:39:26(UTC)
kariosls37
Thanks for the flattery anyway, BDNZThumpUp If you are not satisfied with the look, but the paint is good, you should be able to give it a coat of varnish to give it the look that you are after. Alternatively, give it a good coat of weatheringThumpUp ThumpUp
Thanks for the link brakepad, Those locos will be running in tune with the others.
Offline FMS
#49 Posted : 27 August 2011 17:15:06(UTC)
FMS
Great jobSmile
FMS
Offline GlennM
#50 Posted : 03 September 2011 18:52:17(UTC)
GlennM
With the black coat on it is really taking shape, I cannot wait to see the finished article.......great job.
BR
Glenn
2 Pages12>
This page was generated in 1.174 seconds.
