Offline gachar001
#1 Posted : 01 August 2011 03:40:05(UTC)
gachar001
India
I would like to know which smoke generator I need to use for my Big Boy (37993). I bought the one recommended in the M* database (Seuthe 11) and it hardly puts out any smoke. I remember reading somewhere that M* recommended the wrong one. I would like to buy the correct one. Thanks.
Gautham
Atlanta, GA USA
Offline Dave Banks
#2 Posted : 01 August 2011 09:26:53(UTC)
Dave Banks
Gautham Achar, you need the Marklin #7226 smoke unit if you want more smoke as listed in the catalog. This is same as Seuthe No.10 I believe & that uses 10-16 Volts. This can be used on digital locos & puts out heaps of smoke. The Seuthe No.11 used on 16-22v systems. I am sure the other members will gladly give you the technical details as regards what power it draws ETC.I have Fitted a relay to my Big Boy & that enables me to use two smoke units at once via direct track power. For this I use the Seuthe No.11. Looks great but messy. Tracks get contaminated as well as you have an oily loco.
Try looking at this link: http://www.seuthe-dampf.de/start.htm & go to technical section. The Seuthe No.10 has a red bottom & the Seuthe No.11 a green bottom as far as I am aware of. Personally I like the smoke to burn longer & less intensely & hence most of my outputs on my Loksound/lokpilot decoders have their power greatly reduced for this purpose. It will be interesting to hear the opinions of others & we may all learn something new.
D.A.Banks
Offline gachar001
#3 Posted : 03 August 2011 15:42:01(UTC)
gachar001
India
Thanks Dave. I would rather have more smoke than what I have today. I just get a few wisps of smoke from one and barely any from the other. I think I will buy a couple of Seuthe 10s.
Gautham
Atlanta, GA USA
Offline klarinettmeister
#4 Posted : 03 August 2011 22:33:09(UTC)
klarinettmeister
I haven´t tested smoke generators on my 37993, but I do have 2*7226 on my 37990. It works great and I think it should be the same on 37993. I have 37991 also, but the smoke generator contacts are connected directly to the tracks! Stupid!
thanks 1 user liked this useful post by klarinettmeister
Which smoke generator is right ? (Digital)
by wurttemberg 23/12/2008 23:42:56(UTC)
This page was generated in 0.231 seconds.
