Offline Dimi194
#1 Posted : 18 July 2011 02:22:38(UTC)
Dimi194
Hey all,
I have a problem. My Digitally converted 3099 steam loco is running oddly. At low speeds it runs fine, but once it passes about halfway it get jerky. This has been happening for a while, but just today the engine makes a screeching noise when it is run over about half speed. The engine sounds like it is slipping or something, but I don't see how this is possible. I can't see anything that looks damaged and I checked the motor brushes, they are okay. Any ideas?? Thankyou, Dimi
Offline Dimi194
#2 Posted : 18 July 2011 02:54:36(UTC)
Dimi194
This is a video of it happening...
Offline mvd71
#3 Posted : 18 July 2011 05:43:01(UTC)
Hi Dimi,
Your loco needs servicing! It needs a drop of oil on the gears and each end of the motor armature, as per the marklin instructions.
Once you do this the problem should go awayCool
Mike.
#4 Posted : 18 July 2011 09:07:24(UTC)
Mike is absolutely right. This is classic behaviour from a Marklin DCM motor. A drop of oil on each of the motor bearings is all that is needed.
#5 Posted : 18 July 2011 09:19:17(UTC)
-and if that doesnt help; change the motor-brushes.
#6 Posted : 18 July 2011 10:32:47(UTC)
.. and if this doesn't help clean the whole motor and gears.
regards.,
Offline Dimi194
#7 Posted : 18 July 2011 12:11:35(UTC)
Dimi194
Thanks, I think all it need was an oil but it's still on probation...
#8 Posted : 19 July 2011 00:28:25(UTC)
I excperienced some of the same symptoms on one of my locos after conversion.
I used the conversion set Märklin 60901. Oil did not help. I had to replace the motor cover, or brush holder if you like.
It seems like the rotor was not perfectly centered, or the bearing "hole" was too big, so the rotor started to vibrate at certain speeds.
Photo, for illustration only:
This page was generated in 0.337 seconds.
