Offline ratman15
#1 Posted : 03 July 2011 10:30:05(UTC)
ratman15
Hi All,
First got into Marklins in 1997. Had 2 delta starters and delta controller along with other stuff. Never really got down to building a full layout and then space meant they all went into a box. Just moved into a new place and designed a loft just for the trains. Have a 10 foot by 6 foot table and recently bought two digital starters and a Noch layout. decided to go withm C track for ease of set up.
Am quite clueless about the wrirng for signals and lights.
Any help will be much appreciated.
Offline Ian555
#2 Posted : 03 July 2011 10:32:34(UTC)
Ian555
Hi ratman15,
Welcome to the forum. ThumpUp
Ian.
Offline Fredrik
#3 Posted : 03 July 2011 11:12:22(UTC)
Fredrik
Hi ratman15,
and welcome!
Out of curiosity: -Which digital starters did you buy? And what Noch layout? About how to wire signals and lights - actually depends on how your layout will look alike... Can't give you any real answers until I know (signalling that is). As for lights, they're usually much more simple to install. Normally only 2 wires, yet you might want to add some on-/off- switches for them.
Fredrik.
WWW: MJ-fjärren
Offline ratman15
#4 Posted : 03 July 2011 11:34:01(UTC)
ratman15
Hi Fredrik,
Thanks for the quick response.
I have a 29858 and a 29470 with the Noch 81610 layout. the 29470 comes with MS1 which I have been using to run 4 trains on my make-do layout.
Have been told that I'm better off powering with the old trafo from 29858. Any opinions?
#5 Posted : 03 July 2011 11:36:55(UTC)
Hi Ratman15,
Welcome to the forum.Smile
Offline Renato
#6 Posted : 03 July 2011 12:00:57(UTC)
Renato
Hi Ratman15,
And welcome to the forum
Renato
thanks 1 user liked this useful post by Renato
#7 Posted : 03 July 2011 14:42:30(UTC)
What's the mains voltage in Malaysia?
The transformer from the 29858 set is for 120 Volts, the cheapo 18 VA power supply from the 29470 set is for 230 Volts (with 1 A max. output).
There are two versions of the Mobile Station: the "little" one with 1.2 A max. output and the "big" one with 1.9 A max. output. So with the 18 VA power supply, you won't get the maximum out of either.
The transformers used for your Delta setup should also be suitable for the MS (16 V AC or 18 through 22 V DC will do).
Offline ratman15
#8 Posted : 04 July 2011 11:53:39(UTC)
ratman15
Hey Tom,
Malaysia's on 240V>
#9 Posted : 04 July 2011 12:09:08(UTC)
So if you got a 120 V transformer with your #29858, then don't use it! Output voltage would be doubled, probably frying everything connected to it.
Equipment for 230 Volts must handle 207 through 253 Volts (+/-10%), so it will be used within its specification as long as your power supplier delivers 240 V +6%/-10%.
This page was generated in 0.515 seconds.
