Offline Dave Banks
#1 Posted : 26 June 2011 10:51:24(UTC)
Dave Banks
I Wonder if someone can shed some light on a problem I have with with a BR52 condenser tender. I recently converted this loco to have sound with all the bells & whistles. I have used a Loksound M4 decoder. To operate the three fans on the tender I have hooked up a FRT2-S DC12v relay to switch the fans on via Aux 2. This works really good when using a central station or mobile station. Fans turn at a moderate speed taking is power directly from the track. Now comes the issue, when this same loco is placed on the track with a an Ecos 2 all other functions operate just dandy except for the fan. It stutters & tries to turn but will not spin. Is it because the relay is 12V or is there too much track power or too little or is there a setting on the Ecos 2 that I have not ticked correctly? The track runs in Motorola mode & all but this loco has no problems. Can I maybe discard the relay & let the Aux 2 outlet drive the motor or will that exceed its output limit. I am open to all suggestions.
D.A.Banks
Offline Lollo
#2 Posted : 26 June 2011 11:15:25(UTC)
Lollo
Hi Dave,
Is your transformer set to the 21 volt setting. Refer to page 11 of your Ecos manual.
Brian.
Brian
Yaasan's Desktop Station/Railuino & Marklin MS2, DB Era III/IV Diesel & Steam, ESU Loksound/Lokpilot & Lokprogrammer, Marklin mSD, Tam Valley Depot Octopus III Servo Controller.
Offline Dave Banks
#3 Posted : 26 June 2011 11:20:33(UTC)
Dave Banks
Brian, I am giving the owner of the Ecos 2 a call now & let him check this this setting. Thanks.
D.A.Banks
#4 Posted : 26 June 2011 11:54:58(UTC)
Hi, Dave!
With the original decoder, the fans are connected to the decoder output. So they are fed with rectified current. I presume a DC motor is used for the fans.
Now you feed them with a relay. Do they get rectified current (from the decoder) or unrectified current (directly from the track)?
A DC motor connected to the track power will do three steps forward and one step back with a Märklin controller and two steps forward and two steps back with an ECoS (using default settings).
Offline Dave Banks
#5 Posted : 26 June 2011 12:10:58(UTC)
Dave Banks
Brian, turning voltage 14V or 21V makes no difference.
D.A.Banks
Offline Dave Banks
#6 Posted : 26 June 2011 12:19:20(UTC)
Dave Banks
Tom, many thanks for your reply. Yes the relay allows direct power from the track (unrectified current). So if I remove the relay & use the Aux 2 output to power the motor we should solve the problem then? I believe the motor is DC.
D.A.Banks
#7 Posted : 26 June 2011 19:17:30(UTC)
I think so - unless the motor draws too much current for AUX 2 (in this case the overload protection of the decoder should keep the blue smoke in the decoder).
This would allow you to set AUX 2 to "Smoke" so the fans will run faster while the loco is driving. You can use AUX 2 to adjust the speed if it's too fast.
That's what I would try.
Offline Dave Banks
#8 Posted : 26 June 2011 23:26:41(UTC)
Dave Banks
Tom, I think the decoder would have too much load on the Aux 2 output running that motor. I will have to think of something else. Cannot afford to loose that MFX decoder. I rather play it safe. Any other suggestions on this one?
Edited by user 27 June 2011 05:17:00(UTC)  | Reason: Not specified
D.A.Banks
This page was generated in 0.314 seconds.
