Offline Brian Sprowell
#1 Posted : 26 June 2011 07:57:17(UTC)
Brian Sprowell
Any suggestions about my central station going into overload. I have a new layout and when I turn on the central station it comes up with "Overload" any suggestions welcome, I am new to all this... Brian
Offline mvd71
#2 Posted : 26 June 2011 08:05:53(UTC)
Sounds like you have a short circuit somewhere on the layout. Check for derailed trains or any mislaid track first.
Mike.
#3 Posted : 26 June 2011 08:30:40(UTC)
And check for any metal bits such as screws laying across the track, which might be shorting the centre studded rail to one or both outside rails.
Which track type are you using?
#4 Posted : 26 June 2011 09:24:47(UTC)
Brian Sprowell
I'm using C track. I have checked the track for derailed trains etc and anything that might be lying across the track.
I will check again. Thanks for the help.
#5 Posted : 26 June 2011 10:21:06(UTC)
Check your wiring as well to make sure there are no shorts. If your layout is large, you might need to break it up into sections, and test each section for a short with a multimeter, in order to isolate where the short is.
#6 Posted : 26 June 2011 10:27:19(UTC)
Hi, Brian!
Did it ever work? If so, what have you changed since the last run?
If not, do you use more than 1 feeder track? Check if brown and red are consistent on all feeder tracks.
How many locos, trains, decoders (k83, k84 etc.) are connected? Every decoder will consume some current and a large number of decoders (50 through 100) could be enough to trigger the overload.
Disconnect all tracks from CS2 and turn it on.
Then connect a small section of straight track and test a single loco.
Then add more and more until the overload comes back.
#7 Posted : 26 June 2011 12:05:15(UTC)
Hi Brian,
Welcome to the forum.
#8 Posted : 26 June 2011 13:59:17(UTC)
Tom has it right. Disconnect C track and work your way from the first feeder round the layout to see where the problem lies. It has been known that a faulty C track part has been the cause of a short.
dave
#9 Posted : 26 June 2011 16:26:07(UTC)
Welcome to the forum Brian.
As Dave has mentioned c-track can be the cause, have a look at the connection track and see if the 2 connection tips are bent., they may touch each other
Offline Renato
#10 Posted : 28 June 2011 16:51:06(UTC)
Renato
Hi Brian,
And welcome to the Forum.
Renato
thanks 1 user liked this useful post by Renato
#11 Posted : 28 June 2011 21:53:03(UTC)
Brian Sprowell
Thanks everbody, problem all solved, Regards, Brian
Offline Drongo
#12 Posted : 30 June 2011 13:40:10(UTC)
Drongo
Hi Brian,
I'm curious to know what the problem was - so could you give me a quick description of how you found and rectified the problem.
Greg
This page was generated in 0.425 seconds.
