Offline mancsaint
#1 Posted : 27 May 2011 15:39:10(UTC)
mancsaint
I have two of these 18va transformers and just wish to confirm it is OK to cut the plug off that goes into a 24088 and use the transformer for accessories such as lights, signals or turnouts on a small practice layout?
Offline Renato
#2 Posted : 27 May 2011 17:01:40(UTC)
Renato
Hi Sean,
yes (of course) you can.
Only my personal suggestion: buy the suitable socket for the original M* plug (it is a standard electronical component you can easily find in the electronics shops): you can later eventually sell or use it again with the 24088 track.
Bye
Renato
Offline mancsaint
#3 Posted : 28 May 2011 12:43:08(UTC)
mancsaint
Thank you for the confirmation. I'm just setting up a desktop layout to find out how to automate a layout using a PC to control everything including accessories etc.
Sean
Offline efel
#4 Posted : 28 May 2011 14:02:37(UTC)
efel
Keep in mind that they are not real 16V AC transformers, but DC supplies.
The DC value is 23V (unloaded).
They could shorten the lifetime of bulbs. No problems for pulse driven electromechanical accessories .
Fred
Offline mancsaint
#5 Posted : 28 May 2011 15:18:39(UTC)
mancsaint
As I have two, one I cut the plug off & the other I will use with a socket as you suggest.
The two wires in the cable, one has dashes printed on it and the other has writing, which was the equivalent of red and which was brown, or does it not matter connection wise?
Cheers again for a very informative website.
Sean
This page was generated in 0.227 seconds.
