Offline Krokodileman
#1 Posted : 24 May 2011 04:52:23(UTC)
Krokodileman
If anyone in Marklin Digital land can tell me how to operate my Weathered Danish BR50 with the use of a Mobil station 2 (Loco Number 37834 or 37831 Non Weathered version). I thought I would ask rather than throw both the loco and the mobil station out of the window. I tried so far asking the MS 2 to FIND the engine Response no loco
I tried to enter manually with MM2 coding swithes turned the knob to 50 which is factory default and viola it runs but no control over loco and functions.
Manual in english is a joke. Am I supposed to go to MIT to learn how to program this loco so my mobil station will properly run the loco or shall I just buy a newer version every time I buy a new locomotive.
Please help.
Krokodileman
#2 Posted : 24 May 2011 04:59:37(UTC)
Sal, I'm assuming this is not an mfx loco, so as such it will not register itself with the MS2.
You should be able to create a new loco entry 'from the database', then scroll through all the entries until you find either 37834 or 37831. The MS2 should then create an entry with all the functions for those locos pre-populated.
Offline snnbanen
#3 Posted : 24 May 2011 06:46:15(UTC)
snnbanen
Probably a decoder problem, 37834 have (according to this) http://www.ajckids.com/products/Marklin/37834 a MFX decoder. And half/half responding like it's in analogue mode.
Could be that a decoder reset would solve your problems. Think that you have to write 08 to register 08. Dont know your options on a MS2.
Bruno
#4 Posted : 24 May 2011 14:31:04(UTC)
Krokodileman
The loco is definitely MFX,w/c sine propulsion. I tried 30 times to do what the manual said to enter manually. I guess it is too new to enter into the data base.
Help.
Krokodileman
#5 Posted : 24 May 2011 15:46:25(UTC)
MFX locos are never added to the database and you cannot create an entry for any MFX loco from database.
Automatic registration is the biggest benefit of MFX. (And the biggest flaw of MFX: automatic registration cannot be disabled.)
If the controller supports MFX, you cannot enter an MFX loco manually.
No c-sine I presume, should have 5 pole HEP (HLA).
Offline Nielsenr
#6 Posted : 24 May 2011 18:43:59(UTC)
Nielsenr
I don't have a MS2, I have a CS2. I have had a couple of MFX locos that wouldn't register. I ended up feeding them from a normal analog AC transformer to make sure they ran in analog mode and they did. Lo and behold, I put them back on the digital track and they registered. It is worth a try if you have an analog transformer.
Robert
#7 Posted : 25 May 2011 02:50:43(UTC)
Krokodileman
I just tried 3 other locos with MFX on it and the same thing happened. I will stick with my old MS 1 which never gave me any heartache and wait for a replacement unit from my dealer.
Thanks for you help
Krokodileman
This page was generated in 0.493 seconds.
