Offline Farnorth
#1 Posted : 19 May 2011 02:41:12(UTC)
Farnorth
Maybe someone can enlighten me?
I understand the need for electrically isolated wheels on 2 track systems, and fact that non-isolated wheels are required for some track detection methods on 3 rail layouts.
Are there other not obvious reasons why both options exist?
Offline KeithL4Marklin
#2 Posted : 19 May 2011 03:36:44(UTC)
KeithL4Marklin
Hi there.
The only reasons I can think of is that electrically-isolated wheels were developed for 2-rail DC system, and non-isolated wheels were developed for either the Lionel or Marklin 3-rail AC systems. Most modellers prefer to go with the 2-rail DC system, partly because it looks more prototypically accurate which could be thought of as an advantage.
But the 2-rail DC system has got disadvandtages which outweigh the advantages. First of all, it might be looked at as a system which is more prototypically-accurate. It sounds or looks simple, but in actual fact it is not. With the 2-rail DC system, all you need is one reverse loop and your entire layout is short-circuited, and if you were to have a large layout you would have to have a lot more careful planning. Secondly, locomotives developed for the 2-rail DC system is more senstive to dirty track.
The Marklin 3-rail AC system is by far, even to this day, the most simple and most reliable system. You can have as many reverse loops as you want on your layout and you still would not have single short circuit. You know why? Because the centre contact studs which is the third rail is both electrically and physically-isolated from the two outer rails, even at the switch tracks or turnouts. It's that simple - just connect or lay out the tracks any way you want and you're ready to go. The same advantages apply to the 3-rail Lionel system, except the Marklin 3-rail system looks more prototypically true to life because the centre contact studs which forms part of the 3rd rail are in the middle of the railway ties.
I have a friend who collected a number of 2-rail system Fleischmann and Roco locomotives, and he said that as soon as there is dirt on the track, the locomotives' performance is affected. Dirty spots on the rails would obviously interfere with the current flow causing the locomotive to have a "jerky" movement or an intermittent electrical pickup. With the Marklin 3-rail system, you are a lot less likely to have this problem. My Marklin tracks are dirty and I have not cleaned them for over a year, yet my locomotives still run smoothly.
Keith Lailann.
thanks 1 user liked this useful post by KeithL4Marklin
#3 Posted : 19 May 2011 03:39:28(UTC)
The 3 rail system gives a much more reliable electrical system, and also prevents the need to have reversing loop isolators.
Offline Dimi194
#4 Posted : 19 May 2011 03:54:03(UTC)
Dimi194
It's very suprising but...
The flanges on AC and DC wheels are slightly different. This means a carriage with DC wheels is more likely to derail on AC track because the measurment on the swtiches is minutly different, and visa-versa. So that is on other, usally not noticable reason why their are DC and AC wheel sets.
#5 Posted: : 19 May 2011 05:00:40(UTC)
True, but wagons and coaches with NEM DC wheelsets are more likely to run on Marklin C track (and even M track) than an RP25 DC wheelset (European v's American standards). I have had no trouble running Trix wagons with NEM DC wheels on my Marklin M track.
Offline Dimi194
#6 Posted : 19 May 2011 09:24:09(UTC)
Dimi194
Yea, I find that most of my DC carriages run well, but I have one that doesn't survive turnouts...
#7 Posted : 19 May 2011 16:01:28(UTC)
Yes, the AC are more "rounded" and the DC is more "flat".
Also distance between flanges are different. Around 13.9mm for AC and 14.1mm for DC. This small difference is all that separates a de-railing on every turnout from a clean run!
Usually, if I dont need the electrical connection between wheels, I just squeeze the DC-wheels together to get the right distance. Some brands even have two tiny-small grooves on the axle, which marks the right settings for each system .
Edited by moderator 06 June 2011 21:24:00(UTC)  | Reason: Not specified
Offline jeehring
#8 Posted : 19 May 2011 16:03:10(UTC)
jeehring
......in fact 3 rails system prevents the need of having isolators or polarity commutators at almost every track junction....
With the 3 rails system when trains are coming from any of the two branches (of the "Y"), the moving part of turnouts can be activated by wheels without damages....which is not always possible without specific installation in 2 rails...
#9 Posted : 19 May 2011 18:12:23(UTC)
In the 2 rail DC system, each rail has one pole (+ or -) for power transmission and isolated wheelsets are required to avoid a short circuit. Loks, coaches and cars historically had power pickup from one rail on one wheelset/bogie and from the other rail and the opposing wheelset/bogie. More recently, companies have started to use wheel contacts that enable power pickup from both rails on the same wheelset/bogie.
3 Rail AC originally involved metal track sections, with the main being transmitted along the middle rail, with the outer rails being used as return. This meant that there was an optimal connection between rolling stock and the tracks. The more modern K and C Track have plastic bases. The rails on C Track are still connected to each other via contacts on the underside of each track section. K Track is essentially the same as DC Track, except that the center rail studs are present. The contact between rails exists only on power connection tracks, contact tracks and perhaps on switchtracks. K Track can be used for 2 Rail DC operation if properly wired.
Using a unisolated wheelset on 2 Rail DC will result in a short circuit. isolated wheelsets (DC) can be used on both DC and AC layouts.
Maerklin developed H0 and established the spacing between rails. Other companies later developed a new profile that was a little more exact and that profile was adopted by most of the American companies and later by the Asian and many European companies. This is currently the DC standard.
It is important to remember that 3 Rail was also used initially by Trix (Trix Express), so Maerklin was not the only company having a different standard. Fleischmann also had it's own rail profile which was not fully compatible with other DC makes until the 1970s.
Today's technologies offer companies the possibility to manufacture loks and rolling stock where the wheel spacing and contacts can be easily adapted for AC or DC operation and in the future, it is likely that models could easily be switched from operation on one system to operation on the other. RailTop announced a few models with this in mind, but none have yet been commercially released. Bemo currently offers it's models in switchable H0m to H0e (narrow gauge) so that shops no longer have to stock two versions of each item.
Offline kbvrod
#10 Posted : 19 May 2011 22:11:49(UTC)
kbvrod
As Dr. Eisenbahn has explained before there are slight differences in AC/DC wheel sets.Not only the 'tolerances' between rails.One has to order wheel sets for all manufactures.FL/M/R all require different wheel sets,why? Axle length,same applies for RP-25 or fine scale wheel sets to fit each model.
Dr D
Offline mattj70
#11 Posted : 22 May 2011 13:02:16(UTC)
mattj70
Just buy AC, the system you set up will run, if you use C track you will be up and running fast, enjoying your trains. Plus you can run both AC & DC cars behind your engines without a care in the world. AC engines cost more however they perform much better.
Matt
Offline rrf
#12 Posted : 04 June 2011 14:53:19(UTC)
rrf
I have a question about converting DC rolling stock to AC. I'm really interested in the red "Donnerbüchse" coaches in the 26577 Commuter Train set. I'm not so much interested in the V36.2 diesel lok that's part of the set (Want to run them with my red E69). I noticed yesterday that the same coaches are available from Trix (23476).
I know that I can change to AC wheels on the Trix coaches. But I'm concerned about the cab control car. It's powered with head and tail lights that change depending upon the direction of the train.
I'm sure I can add the center rail pickup shoe. But what about the circuitry that detects directional change? In DC it's looking polarity. In AC it's looking a voltage spike. In AC and DC digital who knows what it's looking for!
Any thoughts/recommendations are appreciated. Reasons to acquire the V36 diesel are also valid here Wink
Rob
Mackenrode Wende Bahn
#13 Posted : 04 June 2011 15:26:24(UTC)
Märklin's AC versions normally have mechanical switches. Those will work with AC or DC, analogue or digital.
So the Trix version could have such a mechanical switch - or simply diodes that can be replaced with a decoder for digital operation.
The description in the Trix catalogue doesn't allow conclusions to be drawn what the train will have.
Explosion diagram not yet available.
I've never heard of control cars that detect voltage spikes for analogue AC operation.
Offline rrf
#14 Posted : 04 June 2011 16:36:35(UTC)
rrf
Thanks for the reply Tom. I actually have an Era IV double-decker commuter control car that changes lights based upon direction ... in both digital and analog. I've never opened it up to see how it works.
Bye,
Rob
Offline Insomnia
#15 Posted : 06 June 2011 21:16:11(UTC)
Insomnia
I had some issues with DC wheelsets on C-tracks. I bought the Pacific Fruit Express set (45680) which derailed almost every time when crossing the turnouts. For a newbie like me, I had to do a lot of research before I noticed the difference in the sizes of the flanges. Then I also noticed the insulation. When I pushed the boxcar manually over a turnout, I noticed that the wheel hit the centre piece of the turnout and derailed.
I think it is a bit weird that Märklin ships sets with dc-wheelsets, if they run this bad on C-tracks.
I have attached a comparison between the NYC boxcar from the US starter set and one of the PFE-boxcars.
Insomnia attached the following image(s):
Tor Inge
#16 Posted : 06 June 2011 21:59:33(UTC)
I don't think M* shipped that set with RP25 DC wheel sets. Maybe they were swapped by the dealer or the previous owner.
The catalogue lists two kinds of DC wheel sets for this car set: NEM and RP25.
NEM wheel sets should be no problem on C track.
Offline Insomnia
#17 Posted : 06 June 2011 22:23:50(UTC)
Insomnia
You are correct on the wheel sets. On the box it says NEM: 320 552 and RP 25: 320 389. I googled the part numbers and found out that both are DC wheels. Though to get the right wheels, I've ordered the 320 551 wheel sets from the dealer (on which I got a nice deal). I didn't notice this on any of the other car sets I bought from the same dealer: There were large flanges on the UP Hopper set (45800), 3x Tank car set (45580) and the UP Caboose (45702).
Tor Inge
Offline Insomnia
#18 Posted : 08 June 2011 10:02:08(UTC)
Insomnia
I talked to my local store yesterday, and I understand now that the wheelsets must have been changed in this set. Because the number on the package is what you need if you are going to use it on DC-tracks. I thought it was the current wheels in the package. So yes, I have probably been had by the other store. I will contact owner again and get the whole story about this package.
Thanks for clarifying this!
Tor Inge
This page was generated in 1.059 seconds.
