Offline Bob
#1 Posted : 08 May 2011 11:50:38(UTC)
Bob
I am looking for help in sourcing a very small cheese head screw and nut. The screw I am looking for is to fasten the round bakalite current transfer base which is between the track platform and the metal base of a 7186 TT. If my measurements are correct it is a M1.4 x 4mm and matching nut. Not sure what the screw pitch is, guess its not important as long as the small nut fits. The turntable works ok with just the 2 screws, but it would be better if all 3 where present. I did not lose the screw, when I got the turntable it only had 2.
So if anyone could help me source the tiny screw, I would be very grateful.
thanks
Bob.
Running Mtrack analogue and Ctrack digital. Collector of V200s.
Offline Markus Schild
#2 Posted : 08 May 2011 12:53:50(UTC)
Markus Schild
Hi Bob,
Both, the screw and the nut are still available from Marklin:
757020 - SECHSKANTMUTTER 0,79 €
785040 - ZYLINDERSCHRAUBE 0,79 €
(Sechskantmutter= nut, Zylinderschraube= screw).
Markus
#3 Posted : 08 May 2011 13:47:05(UTC)
thanks
Bob.
Hi Bob,
Take a look at the spare parts sheets in my webpage, I have scans of sheets showing many of Marklin's different screws and part numbers up to 1974 along with the specifications of each.
https://www.marklin-user...partsinfo/infobegin.html
There's also a parts sheet for the 7186 Turntable with separate parts listing and although it does not show the individual screws, it does show what I presume to be the contact plate you refer to along with a couple of related numbers listed in the second page.
If you do find or confirm the screw and details by cross-referencing to the screw listing, I'll be happy to mark them onto the sheet showing exact location, description and part number for better clarity. Perhaps someone else may have a later dated scan for reference?
With the correct number, if no one else can help you from perhaps a scrapped turntable etc you should at least be able to order them. Hope this helps
Melbourne
#4 Posted : 08 May 2011 13:48:58(UTC)
Hi Bob,
Markus
Oops, sorry Markus, I see you already answered with the info.
I started my reply then went away for something and didn't refresh before posting.
Offline Bob
#5 Posted : 09 May 2011 12:20:20(UTC)
Bob
Hi Markus and Cookee,
Thank you very much for the fast and response to my dilema. Now that I have the part numbers I should be able to order them from one of the Marklin suppliers, I will have a quick look on ebay as well, one can get lucky.
Once again many thanks to you both.
Bob.
Offline Bob
#6 Posted : 09 May 2011 12:32:29(UTC)
Bob
Hi Cookee, just had a quick look at the link you provided. The contact plate which is depicted in Fig 1a -Schleifringplatte- is the part which requires 3 screws and nuts to fix to the base. The screws and nut list unfortunately does not list the tiny M1.4 screws.
Bob.
#7 Posted : 09 May 2011 14:40:30(UTC)
Bob.
Cheers Bob, yeah I wasn't sure if they would be listed but it was a starting point, but if the numbers that Markus gave are the ones referred to, I can easily add them to the image and the screw list for future reference.
Steve
Melbourne
Offline Bob
#8 Posted : 10 May 2011 02:58:42(UTC)
Bob
G'day Steve, I am still following up with the numbers Markus gave me. I have not yet found a place from where I can order them. I could not find them on the Marklin.de site.
hang in there I will get back to you once I have got hold of some.
Bob.
This page was generated in 0.411 seconds.
