Offline Drongo
#1 Posted : 25 April 2011 03:30:48(UTC)
Drongo
Hi Everyone,
I guess this is a dumb question, however, I have to ask it. What is the difference between a Lokpilot & a Loksound?" Blushing
Greg
#2 Posted : 25 April 2011 04:09:17(UTC)
Lokpilot no sound,
Loksound has sound.
NN
Offline Drongo
#3 Posted : 25 April 2011 04:18:03(UTC)
Drongo
Thanks Nev. BigGrin
#4 Posted : 25 April 2011 10:18:50(UTC)
And the Loksound is more expensive....Wink
#5 Posted : 25 April 2011 11:55:39(UTC)
Greg,
ESU decoders are multi protocol, which means they are suitable for different model train locos, e.g. Analog: AC DC,, Digital: DC DCC AC,
they are programmable, free updates with loc programmer, and if anything goes wrong, you don't have to send the whole loco in for service or replacement, just the decoder.
Offline dntower85
#6 Posted : 25 April 2011 16:10:35(UTC)
dntower85
Greg,
Some Lokpilots do not have the motorola protocol, there DCC only.
DT
Offline Chris6382chris
#7 Posted : 25 April 2011 16:20:55(UTC)
Chris6382chris
I have a follow up question concerning the decoders being programmable. To do the programming what do you need? I am running everything off of a MS1 can I use that or do I need one of the more elaborate controllers?
Chris
Offline gachar001
#8 Posted : 25 April 2011 16:45:29(UTC)
gachar001
India
Chris
You need to use a lokprogrammer
http://www.esu.eu/en/products/lokprogrammer/
This connects to your PC and to a test track on which you place a loco. Then you can read the settings, change whatever you want to change and then write it back to the loco. You can also completely change the sound of the loco if you like.
Gautham
Atlanta, GA USA
#9 Posted : 25 April 2011 17:33:42(UTC)
Chris
Regarding the Lokprogrammer it only programmes ESU decoders.
You can change the first 5 or 6 CV's , e.g. address, acceleration & braking delay etc. etc.
To change lights or digital uncouplers a lokprogrammer makes it very easy.
the same goes for setting long addresses.
Offline dntower85
#10 Posted : 25 April 2011 17:37:15(UTC)
dntower85
Chris
With a MS1 you can only change the address, max speed, acceleration, and deceleration, and maybe max volume. this might be enough to get you by.
DT
Offline efel
#11 Posted : 25 April 2011 22:55:02(UTC)
efel
Chris
With a MS, you can program the 79 first CVs of a lokpilot.
The value you can enter is limited to 80.
Fred
#12 Posted : 26 April 2011 02:54:00(UTC)
Besides the Lokprogrammer, you can also program the ESU decoders with an Ecos or CS1 Reloaded (v3.x.x) The only limitation AFAIK is that you have to have a Lokprogrammer to be able to upload sound files to an ESU Loksound decoder. The Ecos/CS1R can do everything else.
And as others have mentioned you can perform some limited programming with a 6021 or MS1.
Offline Drongo
#13 Posted : 26 April 2011 07:02:46(UTC)
Drongo
Chris
AFAIK you can't change "whatever you like" with a mfx decoder - it's been locked by Marklin. Am I correct? Confused
#14 Posted : 26 April 2011 07:11:06(UTC)
COrrect.
there are only a few Parameters that can be changed on an MFX Decoder. Sound is totally locked.
Speed Curve, Min and Max accelleration, Braking spreed etc.
NN
Offline Drongo
#15 Posted : 26 April 2011 07:15:13(UTC)
Drongo
COrrect.
NN
Thanks Nev.
Offline Rinus
#16 Posted : 26 April 2011 07:52:44(UTC)
Rinus
Lokpilot no sound,
Loksound has sound.
NN
You are a very wise man! LOL Drool BigGrin Wink
#17 Posted : 26 April 2011 10:32:31(UTC)
Originally Posted by: Rinus Go to Quoted Post
Lokpilot no sound,
Loksound has sound.
NN
I agree. This is the most precise, accurate and to the point answer to the question posted.
#18 Posted : 26 April 2011 10:59:05(UTC)
Thankyou,
I thought that that was the propper answer without any waffle.
NN
Offline dntower85
#19 Posted : 26 April 2011 14:50:52(UTC)
dntower85
Lokpilot no sound,
Loksound has sound.
NN
But by that logic
Lokpilot: has Pilot.
Loksound: no Pilot.
Now that's a waffle answer.
LOL LOL LOL LOL Wink
sorry I feel punnyWink today.
DT
Guest (5)
This page was generated in 0.736 seconds.
