Offline Joseph Meiring
#1 Posted : 13 April 2011 22:54:56(UTC)
Joseph Meiring
Hi all
Is it possible/feasible? to change the close couplers on the newer locos (37097, 37453, 39643, 39392) with relex couplers? I am able to get a pack of 10 relex coupler heads (72060).
Thanx as always, Joe
Offline kbvrod
#2 Posted : 13 April 2011 23:00:03(UTC)
kbvrod
Hi all
Originally Posted by: Joe Meiring Go to Quoted Post
Hi all
Is it possible/feasible? to change the close couplers on the newer locos (37097, 37453, 39643, 39392) with relex couplers? I am able to get a pack of 10 relex coupler heads (72060).Thanx as always, Joe
Those models should(?) all have NEM coupler pockets,so switching them out should not be problem.
Dr D
thanks 1 user liked this useful post by kbvrod
#3 Posted : 13 April 2011 23:04:35(UTC)
Just pull out the coupler and insert the new one. Why do you want to change them Joe.
dave
#4 Posted : 14 April 2011 14:24:51(UTC)
I´m myself using Kadee coupler which works fine.
Kadee has NEM couple too.
Offline kbvrod
#5 Posted : 14 April 2011 14:42:07(UTC)
kbvrod
I have been experimenting with them also,although not true close coupling,they couple/uncouple gently.Great for shunting.
A friend who has and runs a lot of trains swears by them,very reliable.
Dr D
#6 Posted : 14 April 2011 23:27:16(UTC)
dave
I have a few older locos without NEM Pockets and Relex Couplers. I am going to change the front Carriage Close Couplers with Releax couplers as currently I have frequent uncouplings.
The change eliminated the uncouplings.
NN
#7 Posted : 15 April 2011 21:48:15(UTC)
Joseph Meiring
dave
Thanx Dave....all my wagons and locos have the old relex fitted, so I was wondering, as I build up my stock of new digital locos, if it was feasible to fit the relex on to them....
Joe
Offline Writhdar
#8 Posted : 15 April 2011 23:56:29(UTC)
Writhdar
the coupler height on many of the new locos - particularly if they have telex uncouplers - is lower than the relex couplers on cars. For non-telex, if you replace them with relex, you may have to trim the downwards hanging "lever" to avoid hangups & shorts. You will probably also have to make some height adjustments.
I don't think you can do anything with the telex ones (e.g., BR 50's) if you still want to maintain telex functionality.
Even though I think the close couplers are a "giant step backwards" from relex couplers, I've put them on most of my freight cars so that the newer locos can couple with them.
thanks 1 user liked this useful post by Writhdar
Offline kbvrod
#9 Posted : 16 April 2011 00:09:47(UTC)
kbvrod
....all my wagons and locos have the old relex fitted, so I was wondering, as I build up my stock of new digital locos, if it was feasible to fit the relex on to them....Joe
You adjust them.
Dr Dirt.
thanks 2 users liked this useful post by kbvrod
Offline BenP
#10 Posted : 10 May 2025 23:41:57(UTC)
BenP
Old thread, but running into this problem with close-relex coupling, getting relex low lever on old style wagon stuck on raised pukos of M switches. Problem does not occurr relex-relex coupled.
Either trim the lever of relex coupler or replace close coupler with relex coupler on loco. Latter preferred, but which relex coupler? Pocket insert or replace entire pocket?
Ben
Ben van der Pluijm--
thanks 2 users liked this useful post by BenP
#11 Posted : 11 May 2025 03:11:17(UTC)
I replaced the couplers on some of my Hobby models with a simple hook coupling from Hag: https://troll.web24shop....pic.php/479/1/b?20240112
Offline Drongo
#12 Posted : 11 May 2025 09:26:45(UTC)
Drongo
I replaced a lot of my couplers with the Hornby magnetic couplers R7400 and they work very well. Easy to couple and easy to uncouple.
thanks 2 users liked this useful post by Drongo
This page was generated in 0.463 seconds.
