Offline Chris6382chris
#1 Posted : 27 March 2011 22:46:26(UTC)
Chris6382chris
All:
I have noticed that after running my engine for a while I can smell a faint electrical odor. After looking closely I am sure the smell is coming from the engine portion of the locomotive. I am wondering if I should be worried about this? I have checked everything and everything is moving correctly and everything is lubricated properly and the engine itself runs fine. Is this smell normal and perhaps part of the normal break in period? My guess is the engine has been sitting for a couple years or so.
I would appreciate any feedback or thoughts.
Chris
Online H0
#2 Posted : 27 March 2011 23:52:49(UTC)
It could be the smell that is known as Eau de Märklin.
The smell of my not so old BR 78 recently turned from "Eau de Märklin" to a dangerous odour (while it was running on the club layout).
At home I found that the power consumption was much too high (can be measured with CS1, CS2, and recent MS1).
I cleaned it and found that the brushes were over-oiled ex works, with oil and carbon dust messing up the collector.
I cleaned everything: power consumption was down to normal, smell was back to Eau de Märklin.
Some sparks (and a smell of ozone) are normal, but when the motor gets really hot and smells burnt then there is something wrong.
Offline gerardo960
#3 Posted : 28 March 2011 14:40:08(UTC)
gerardo960
Argentina
Hi I also I have an engine and would like to know if the sound of squeaking brakes if it is because I have not been able to hear and if I listened to all sounds other than this let me know if you have and how I can run with the MS1 and I can not get this sound anything but arises locomotive has somido very low compared to other models and have put out loud let me know if so.
Edited by moderator 06 August 2011 19:15:11(UTC)  | Reason: Spam removed
Offline Writhdar
#4 Posted : 28 March 2011 15:24:16(UTC)
Writhdar
If the engine does have the "squealing brakes" sound, I think it works when the function button is off - that is, do not select it. The sound will then come when you stop the train abruptly.
Online H0
#5 Posted : 28 March 2011 15:35:35(UTC)
To hear the squealing brakes sound, activate the operating sounds, do not activate the function "squealing brakes" (coz it actually is "squealing brakes off") - and then run the train fast and brake abruptly to a standstill.
Offline gerardo960
#6 Posted : 28 March 2011 17:56:16(UTC)
gerardo960
Argentina
ok thanks guys and I'll put into practice the advice to see if it works this function squeaking brakes.
#7 Posted : 28 March 2011 18:01:53(UTC)
Chris6382chris
Good news, based on Tom's feed back I took the motor cover off and found a bit of oil that had gotten on the brushes. I cleaned everything up and it is running cooler with no real smell.
Chris
This page was generated in 0.288 seconds.
