Offline elsleuth
#1 Posted : 01 March 2011 18:15:43(UTC)
elsleuth
Hi, Is it possible to run a 7051 crane digitally? Kent in Ca
Offline Nielsenr
#2 Posted : 01 March 2011 20:25:20(UTC)
Nielsenr
I don't have one but I looked in my 07421 Electrical manual. They show how to hook up the crane in analog but no diagrams for how to hook up digitally. The newer 76500 Gantry Crane and the 76510 Coaling Station have decoders built into them. My guess is you could acquire a decoder and "kit bash" digital control of the 7051. Maybe someone here on the forum has done that. Good Luck!!
Robert
#3 Posted : 01 March 2011 20:27:56(UTC)
Didn't they make a special digital module for controling the crane?
#4 Posted : 01 March 2011 20:43:19(UTC)
Yes, it is the 7651 module. Since the 2 motors on the crane look like they are SFCM motors, I hear it is also possible to drive them with delta decoders, or even lokpilots.
Svein gave some details on how he did this in the following thread:
https://www.marklin-user...px#post161293#post161293
Offline sprogger
#5 Posted : 01 March 2011 22:32:19(UTC)
sprogger
The 7651 is actually the digital version of the 7051 crane...
Marklin did produce a digital conversion kit Item 7652 that could be fitted to the 7051 (screws into the base) ..
I had a quick look on ebay.de and could not see any .. might be worth checking with some of the german dealers
Sprogger
Offline oz_train
#6 Posted : 01 March 2011 23:53:28(UTC)
oz_train
Hi Kent, All,
I used an old delta decoder. What I did was to control a relay with the "function" output (f0) of the decoder. The relay switches the motor output of the decoder to either the slew or hook drive motor. In that way, you only have to enter 1 address for the crane, and control either of the 2 axes by using the f0 output. I also added a small (blue) LED which is activated when the hook motor is selected, so that there can be no doubt about which axis is about to move! The slight downside of this approach is that only 1 axis can be driven at a time, but the upside is that you don't need to punch in 2 different addresses to alternately control slew and hook. And the variable speed is a delight!
regards,
John.
Offline sudibarba
#7 Posted : 02 March 2011 00:10:18(UTC)
sudibarba
I see all the responses and am sure you can do something fairly easily.
My question is why do you want to do it? Are you planning to set up some kind of automatic operation with a CS2 or a computer?
Eric
Offline elsleuth
#8 Posted : 02 March 2011 15:36:54(UTC)
elsleuth
Yes I am planning on running my set from a computer. This is a very low priority in the overall plan but I knew someone out there would have the answer. Thanks for all the ideas. Kent
#9 Posted : 02 March 2011 16:14:13(UTC)
The digital version of the crane is plain silly. It only allows one action at a time. To make it work as one would expect one needs to add a second decoder, and if we can add one we can just as easily add two....
I added a second decoder to the crane and I show the changes here: http://layout.mixmox.com/1/digital-crane
I am now able to control the crane from the computer, slewing and raising the hook at the same time...
If you use an Intellibox to drive your digital layout - you can download and use my software for controlling the crane too...
see http://bw.mixmox.com
#10 Posted : 02 March 2011 23:07:08(UTC)
Pure genius.... Cool
This will be a neat project when I am retired at the end of this year... I have a few (actually lots) of delta decoders..
Slightly off topic.. Do you have a solution for wiring a delta decoder into coaches so that I can switch lights on and off?
Offline oz_train
#11 Posted : 02 March 2011 23:15:03(UTC)
oz_train
Actually Dale, I beg to differ... maybe if you control your crane via computer (and where's the fun in that?Confused) it makes sense to have 2 decoders, but if you have a humble 6021 and constantly need to punch in 2 addresses to control the 2 axes "simultaneously" (and in reality still only one at a time!), then it soon loses its appeal.
regards,
John.
#12 Posted : 02 March 2011 23:55:41(UTC)
Apart from Delta decoders, you could probably also use some PD101 decoders, which can directly drive an AC motor, but also have switchable function outputs.
http://www.pd101.com/e/pages/index.asp
Offline Ross
#13 Posted : 03 March 2011 02:03:39(UTC)
Ross
Hi elseuth,
Yes it is possible to control the crane digitally. I have copied pages 172-173 from the "0308 Getting started with Marklin Digital"
Please note that you should use a 6083 decoder and not a 60830 as the switching transistors have better power specifications.
Ross
#14 Posted : 03 March 2011 02:50:48(UTC)
Since I have 2 7051 cranes, I guess I can use the other set of K83/K84 outputs to control the 2nd crane.
BTW, there's a complete English version of the 0308 book??? That's something I did not know. I have a PDF scan of it in German, and a Word document with a partial English translation, but pages 172/173 in the Word doco are still in German.
Thanks Ross.
#15 Posted : 03 March 2011 03:27:35(UTC)
regards,
John.
well sure differ if you like... but here is my reasoning...
the way they configured the crane you had to select different functions to make it slew or raise the hook. So any type of manual operation needed continual stopping, punching numbers, trying to remember which way the motor is going for the 'other axis' etc. completely unfriendly. Plus the fact that only one axis could be active at any time. Very boring.
Now, had they used two addresses they could have allowed you to use two controllers and have something which is usable manually.
Where is the fun in computer control...? perhaps you assume that the computer does everything - no, what I have is a powerful/richer control interface allowing the manual operation of the crane in a clear and predictable manner... E.g. you want it to move up and to the right, move up and right., just down, move down and keep it in the middle. One can use a joystick or keyboard arrow keys too...
Using a 6021 is using a computer, it is just a crappy interface to a 2-axis movement.
#16 Posted : 03 March 2011 03:33:32(UTC)
just wire up the function outputs to the lights - oh wait delta decoders dont all have switchable functions... in that case use the motor output and then you can set the speed to control the intensity. This is exactly what I did for the light at the end of the tunnel...
http://layout.mixmox.com/1/tunnel
If you have an old 6080 decoder with one output - you can create a stationary decoder... I used this to power some signal LEDs in my S-Bahn tunnel
http://layout.mixmox.com/1/stationary-decoder
#17 Posted : 03 March 2011 04:54:30(UTC)
Thanks Dale.. The coaches currently on the layout have LED lighting so it sounds like a better option is to find a cheap decoder that can switch the lights on and off..
#18 Posted : 03 March 2011 16:48:37(UTC)
if they already use LEDs also consider simply letting them stay on, they are not consuming much digital power and no heat...
Offline oz_train
#19 Posted : 04 March 2011 00:04:01(UTC)
oz_train
Whatever. I like my 6021. I don't think it is "crappy"Angry .
#20 Posted : 04 March 2011 16:18:40(UTC)
John,
I did not say the 6021 is crappy.
I said that it is a crappy interface to a 2 axis system. You have one knob to drive two axes.
It is like saying a screwdriver is a crappy tool to remove hex nuts - does not means that screwdrivers are bad tools.
I am quite happy for you to control you 2 axis crane with a single axis controller. Have fun.
Offline elsleuth
#21 Posted : 23 April 2011 01:02:25(UTC)
elsleuth
Thanks everyone, very helpful. Elsleuth
Offline rodLinar
#22 Posted : 20 October 2014 00:17:40(UTC)
rodLinar
Hi all ,
To connect a Crane digitaly to a MS1 MS2 CS1 CS2 or 6021, you can use a RLT1410 manufactured by Trenes Digitales.
www.trenesdigitales.com
this is the ebay link
http://www.ebay.com/itm/...&hash=item2591944f13
Rodrigo
thanks 1 user liked this useful post by rodLinar
This page was generated in 0.714 seconds.
