Offline dlarson
#1 Posted : 23 January 2011 21:18:40(UTC)
dlarson
Have any of you tried these manufacturers? Do they come with different colors? Is there a hobbyshop in the United states or Canada that sells these direct? I found Artitec but none of the others.
Thanks in advance
Dave
Offline glight1
#2 Posted : 19 April 2011 18:31:39(UTC)
glight1
I think that Artitec uses resin and does not come in colors. Reynaulds carries that line here in the USA. I don't know about the others.
Offline kbvrod
#3 Posted : 19 April 2011 23:38:54(UTC)
kbvrod
Hi Dave,all,
Originally Posted by: dlarson Go to Quoted Post
Have any of you tried these manufacturers? Do they come with different colors? Is there a hobbyshop in the United states or Canada that sells these direct? I found Artitec but none of the others.Thanks in advance Dave
I don't have direct experience with these maunfacuters,yet.BigGrin Yet,from your post,it is NOT difficult to change colors.Either with a very cheap airbrush or a brush.
Dr Dirt
Offline tank_brd
#4 Posted : 20 April 2011 17:08:17(UTC)
tank_brd
A few Jouef model buildings were packaged as Bachmann brand.
M-track - Era III-IV with 6021, Billerbahn.
Offline TrainIride
#5 Posted : 21 April 2011 10:00:44(UTC)
TrainIride
Thanks in advance
Dave
Hi Dave,
I have a lot of Jouef and Mkd buildings on my layout.
Because I've bought these kits years ago, I don't know if this evaluation is still valid.
Both Jouef and Mkd are French-style.
The parts are coloured with different colors, but I think that if you don't want your buildings
look like a Playmobil area, you have to repaint yourself the parts with different colors, and then add some weathering.
The Jouef sawmill is great, for example.
The Mkd houses have a lot of charm.
I also was surprised to find that some (a few) Jouef houses I've bought were scaled 1/100!!
Again, this is an old judgment, from ten years ago.
I was also obliged to add cardboard behind the walls to avoid the lighting going through.
I am not sure, but I'd swear I saw recently some Jouef kits now labeled "Mkd"...
Joël
This page was generated in 0.247 seconds.
