Offline wolfk88
#1 Posted : 04 December 2010 20:06:25(UTC)
wolfk88
Greetings, I've lostCrying the tiny cylinder that slides inside the smoke generator of my old locomotive 3048. Does anyone know where I can get a replacement. Thanks.
Grusse, ich habe den kleinen zilinder vom rauchsatz meiner lokomotief 3048 verlorenCrying . Wie kann mann ersatz dampfrohr(e) in USA besorgen? Vielen dank.
Offline spitzenklasse
#2 Posted : 04 December 2010 21:16:15(UTC)
spitzenklasse
Yes Wolf, the Walthers catalogue/website has them. I think they are by Suethe. Sometimes, they are included with the generator kits.
Offline Lollo
#3 Posted : 04 December 2010 22:12:30(UTC)
Lollo
The replacement Seuthe part is, No.200. They come in a pack of five needles. Should cost under $10.00 US dollars.
Available here, Eurobahntrains sells them individually as No.200EA
http://www.eurobahntrain...and=Seuthe&gauge=All
Or just contact any dealer selling Seuthe & they should be able to order them for you.
Brian.
Brian
Yaasan's Desktop Station/Railuino & Marklin MS2, DB Era III/IV Diesel & Steam, ESU Loksound/Lokpilot & Lokprogrammer, Marklin mSD, Tam Valley Depot Octopus III Servo Controller.
Offline Joseph Meiring
#4 Posted : 04 December 2010 22:41:46(UTC)
Joseph Meiring
Brian.
Hi Brian...Excuse the ignorance....what do the "needles"do?/what are they for?
M track Joe
Offline wolfk88
#5 Posted : 05 December 2010 02:38:36(UTC)
wolfk88
Thank you spitz, I checked Walthers and indeed they have the kit, but it is pricey if I only need the tube.
Offline wolfk88
#6 Posted : 05 December 2010 02:44:06(UTC)
wolfk88
Brian.
Thank you Brian, your link led me exactly to the part I want. It is a tough website to navigate as I would also like to get tires for the same engine. If you could send a link I would appreciate it. Thanks.
Offline Lollo
#7 Posted : 05 December 2010 06:55:22(UTC)
Lollo
Brian.
M track Joe
Hi Joe,
The needle is where the smoke oil is vapourised through. The tube in the smoke unit is only to house the needle and is part of the heating element. With out the needle, you get hardly any smoke at all.
I hope that's accurate enough.
Brian.
Brian
Offline BR01097
#8 Posted : 05 December 2010 07:16:04(UTC)
BR01097
Brian.
M track Joe
Hi Joe,
Brian.
I have similar confusion here: is there a filament inside the needle? From the outside, visibly is the smoke unit housing and a hollow tube, which is presumably being referred to as "the needle". But the smoke unit kit contains a pin for cleaning the tube and some kind of long, thin wire for an unknown purpose. Please explain in greater detail.
#9 Posted : 05 December 2010 10:11:59(UTC)
The kits contain a long thin wire for cleaning the tube and a spare tube for replacements.
The Märklin kits include a pin that could be used to open and close the small plastic thingy with smoke fluid that used to come with the Märklin kits; they took the smoke fluid out, but still include a pin.
Kits from Seuthe are more expensive, but they include smoke fluid and a syringe to apply it. No obsolete pins included here.
Here's a picture of the kit with the smoke fluid plastic thingy:
http://www.reynaulds.com/images/Marklin/7226.jpg
#10 Posted : 05 December 2010 18:43:50(UTC)
Hi Brian,
Welcome to the forum.
#11 Posted : 06 December 2010 22:29:06(UTC)
Joseph Meiring
Brian.
M track Joe
Hi Joe,
Brian.
Thanx Brian.....that explains why I'm not getting smoke - I have no needle in the "chimney" - it does smoke when I operate the reverse unit a few times vigorously, but not when the engine is running normally. So is the needle actually a very small "hollow tube" thru which the smoke comes out?
Thanks for the trouble taken to reply! M track Joe
This page was generated in 0.488 seconds.
