Offline ride1058
#1 Posted : 27 November 2010 18:46:32(UTC)
ride1058
I'm a beginner in the train modeling business. Trying to look for locos with digital coupling build in like the roco 68825 (http://www.roco.com/products/Roco/68825.aspx)
Any help will be appreciated
Offline Ian555
#2 Posted : 27 November 2010 19:12:32(UTC)
Ian555
Hi ride1058,
Welcome to the forum. ThumpUp
Ian.
#3 Posted : 27 November 2010 21:46:26(UTC)
I have 2 locos with digital coupling (Telex)
37650 V60
37885 Br 043
Offline ride1058
#4 Posted : 27 November 2010 22:38:37(UTC)
ride1058
RayPayas,
The Br 043 looks amazing !
Online H0
#5 Posted : 27 November 2010 22:55:36(UTC)
Märklin has different types of Telex couplers.
The old-style Telex couplers can be found with BR V 60, BR 86, BR 81. They work better with Relex couplers than with close couplers.
The new-style Telex couplers can be found with BR V 90 (#37903) and various steamers (BR 03 (#37953), BR 41 (#37921) , BR 44, BR 50). They work fine with close couplers (not tested with Relex couplers) and are much like the digital couplers used by Roco.
Roco makes models of BR V 100 West (your link) and BR V 100 East with those digital couplers. You can also by a pair of digital couplers with a "special" decoder from Roco (the "special" decoder is just an uncrippled ESU V3.0 decoder while other Roco locos used to have crippled ESU OEM decoders).
Offline Drongo
#6 Posted : 28 November 2010 06:22:29(UTC)
Drongo
This might sound a bit stupid, but what is exactly a digital coupler.? Does it mean that you can couple and uncouple carriages from the CS2?
Sorry for asking an obvious question to most of you. Blink Mellow
Greg
#7 Posted : 28 November 2010 06:35:19(UTC)
Yes. Telex can be triggered Open. Not all Locos have it.
N
Offline ride1058
#8 Posted : 28 November 2010 07:54:26(UTC)
ride1058
Thanks for the detailed answer mate. A follow up question, on what locos and wagons does uncoupling track work ?
#9 Posted : 28 November 2010 07:58:45(UTC)
The main difference between Marklin electrical Telex uncoupling device and Roco is: Roco can be attached to any loco having NEM coupling shafts whereas Märklin is a fixed un-coupler.
Digital uncoupler means the voltage has been set for digital operation and with ESU lokpilot or sound decoders you can also set the time for the un-coupling device to be activated by a pulse action timer.
Roco suppose to have a re-run on these un-couplers but so far I haven't been able to order them (over a 6 month period).
Offline Ian555
#10 Posted : 28 November 2010 10:12:56(UTC)
Ian555
I have a few Loco's from the 1960's that have Telex uncoupling.
Works from the red speed contol on your old transformers, worked well if I remember.
The end function is very similair to the digital system, it disconnects the Loco from the wagons.
Ian.
#11 Posted : 28 November 2010 10:37:06(UTC)
I have many locos with telex such as BR03, BR41, BR43, BR44, BR50, Diesel shunter, etc.
Also welcome to the forum.
#12 Posted : 28 November 2010 11:12:03(UTC)
Even Krois coupling can been using at Marklin locomotiv without digitalcoupling.
See here:
www.krois-modell.at
Online H0
#13 Posted : 28 November 2010 11:16:29(UTC)
It seems the coupler used with the V 90 (#37903) can be used with any loco with NEM pockets - so it's the same principle as with Roco.
Before the insolvency, they announced a 150 (#39502) with these couplers which never came.
Märklin calls it "Telex", Roco calls it "Digital Coupler" - that are just names.
Märklin Telex also works in analog operation - if the loco is analog or has a Delta decoder.
Uncoupler tracks should work with all "normal" couplers (including Märklin, Roco universal coupler, Roco close coupler, Fleischmann, ...). This principle is used by many MRR companies, not just by Märklin.
The new power conducting couplers do not work easily, so expect trouble with them; you can use normal couplers at the end of the train so you can still uncouple the loco from the train.
Don't mix close couplers with bow and hook couplers, this can lead to problems.
Fixed coupling bar and special power conducting couplers won't work.
Roco universal couplers normally close more easy than Märklin couplers, so if you want to use uncoupler tracks give those Roco couplers a try (unless you live in Italy).
#14 Posted : 28 November 2010 11:17:00(UTC)
See here:
www.krois-modell.at
interesting link.
Just found this http://shop.krois-modell...iversal-Coupler::43.html
#15 Posted : 28 November 2010 12:03:45(UTC)
HO wrote:
it seems the coupler used with the V 90 (#37903) can be used with any loco with NEM pockets - so it's the same principle as with Roco,
take into consideration: except Märklin costs twice as much.
Offline JKJ
#16 Posted : 28 November 2010 14:56:55(UTC)
JKJ
Ian.
How do you operate the Telex coupler from your trafo? Do you turn the dial left like you do when you change direction?
Will the Telex coupler open every time you change direction?
JKJ
Online H0
#17 Posted : 28 November 2010 20:21:34(UTC)
I paid Euro 90 for one Roco V 100 with digital couplers.
The other Roco V 100 with digital couplers cost me Euro 185 together with eight four-axled freight cars.
So yes: the V 60 from Märklin (with those old-fashioned Telex couplers) will normally cost twice as much as my Roco locos ...
Offline Joseph Meiring
#18 Posted : 28 November 2010 22:40:04(UTC)
Joseph Meiring
Ian.
JKJ
Hi JKJ
I have a 3309 with telex (Analog);turn left twice to change direction, or once to uncouple and keep on going in same direction;nice to be able to uncouple anywhere on track!
M track Joe
Offline JKJ
#19 Posted : 28 November 2010 23:34:04(UTC)
JKJ
Thanks Joe.
JKJ
#20 Posted : 28 November 2010 23:59:33(UTC)
Tom,
My quote was for the uncoupling unit only.
Online H0
#21 Posted : 29 November 2010 01:41:44(UTC)
John,
The Telex coupler from Märklin #37921 is listed as Euro 25 (spare part price) and it's available.
The Telex coupler from Märklin #37903 is listed as Euro 15 (spare part price), but is not available.
A pair of Roco uncouplers plus ESU V3.0 decoder is available for Euro 60 (street price; their site is down so I can't check the RRP).
Krois couplers are listed as Euro 17.
So prices appear to be similar IMHO.
Offline Tex
#22 Posted : 30 November 2010 05:14:35(UTC)
Tex
I have three tank type steam locos , Cl 81 , Cl 85 and Cl 86 with the older style Telex coupler plus a Marklin 37649, Cl 360 diesel switcher with the newer Telex coupler. I find the newer Telex to be better in remote coupling and uncoupling, meaning it works at least half the time.
Tex
Online H0
#23 Posted : 30 November 2010 16:51:47(UTC)
But that's not the new Telex coupler used with the big steamers (BR 03, BR 41, BR 44, BR 50) or the V 90.
#24 Posted : 06 December 2010 22:48:32(UTC)
Joseph Meiring
Tex
I have the cl 85, with the old telex - over time i found the "secret" to getting it to work ALL the time!
Always ensure the couplings are not under "tension" when trying to uncouple, they must be "slack"; so what I do: stop the engine, say from going forward, double click to reverse, (only ever so slightly to release the coupling tension),then 3 clicks, which will move the engine forward, and uncouple at the same time - works every time..thats the "fun" working with the old analogue system!!
M track Joe
This page was generated in 1.050 seconds.
