Offline Ranjit
#1 Posted : 08 November 2010 05:17:09(UTC)
Ranjit
Hi All,
Can telex coupling be fitted to locomotives, such as the 3000, 3003, 3141, etc.?
John, would the telex couplers that you have fit these locomotive? If so, how can this be done?
Ranjit
#Get Vaccinated
#2 Posted : 08 November 2010 08:10:37(UTC)
Ranjit,
Adding a Roco digital coupling
Unless you change the coupling itself or leave the coupling (3003) and cut of the end part and superglue a coupling shaft to it.
Loco 3000 has coupling hooks, same as 3001,3002,
What I have than here, removed the coupling hook modified the coupler with drilling a hole and than creating a thread for a screw to be inserted.
3141 shouldn't be a problem with the standard Märklin telex coupling.
The history of the Telex coupling(?) (H0-scale)
by aclassifier 21/06/2021 18:58:36(UTC)
3065 Telex Coupling Bushing - confirmation? (Collector's Corner general)
by cookee_nz 30/11/2017 04:38:05(UTC)
New Digital Telex Couplings BR 150 [Märklin item 37851] (H0-scale)
by GlennM 05/01/2014 15:25:49(UTC)
Telex Coupling (H0-scale)
by Ranjit 21/08/2004 19:37:17(UTC)
This page was generated in 0.258 seconds.
