3 Pages123>
#1 Posted : 29 October 2010 21:08:57(UTC)
http://www.suter-meggen....ortiment/frame_26557.htm
Roger Suter (Suter Meggen) is announcing that the 26557 is in store as of today.
Looking at the photo of the SBB WRm, the windows seem to be a little small to me. It seems that they should be a little lower and a little higher than on the model pictured.
http://www.railfaneurope...ant/CFF_WR-RIC-TEE_1.jpg
http://www.hrgehri.ch/archiv/liliput/L388014.JPG
http://www.seak.ch/rm_si...88-70%20000-70%20009.htm
When Maerklin released the 42991 Set, the ARDmz Bar coach had windows that were similarly smaller than those of the Avmz and Apmz coaches. This was corrected on the more recent 1:93 versions.
This discrepancy is not really visible on the Sample model used to photograph the Set in the New Items Flyer. Based on the original photos, I had no reason to contact Maerklin regarding this issue. I did express some concerns via email regarding the tapering of the ends of the roof of the coach, which seemed a little excessive compared to the prototype
#2 Posted : 29 October 2010 23:03:34(UTC)
The latest German TEE bar cars and dining cars by Märklin were in length scale 1:97.5 (prototype length 27.5 m, model length 28.2 cm; ref. no. 00776 "Blauer Enzian").
Märklin only write "The cars have the new, longer length."
Most German dining and bar cars are longer (27.5 m vs. 26.2 m of passenger coaches).
Maybe the difference in height of windows is related to this different length scale (to maintain proportions of the windows).
The dining car of the era III Rheingold was an exception (26.4 m).
The SBB dining car has the same length, so this is no excuse here.
Since the new mould of the SBB dining coach was announced as one of the highlights of this set, it's a pity they messed it up a little bit.
I ordered this set to get the loco and the dining car. The car on the Suter pictures is acceptable for me.
#3 Posted : 29 October 2010 23:24:09(UTC)
Tom,
I ordered the Set principally for the lok. From the photos I have seen of the model (and of the green Re 4/4I 37044), this looks like a very nice model. I am disappointed by the Restaurant coach. The sample (Handmuster) model featured in the New Items Flyer and at various Shows did not have this issue or the appearance was much less acute. I presume that LS Models will eventually come out with a 1:87 model of the SBB WRm, so I will likely be using that coach with Roco (or maybe LSM) DB Avmz and Apmz TEE Coaches.
It is interesting to note that Maerklin did a better job in this regard with the original 4068 (24cm) diner in the 1960s.
As far as the scale of the DB Wrmz 132 and WRmz 135 model, I realize that the original coach is slightly longer than the corresponding compartment and open seating coaches. I did not specify the difference in scale of the restaurant coaches because I was generally referring to the set of coaches in the scale of 1:93 (or with a length of 282mm).
Thanks for the precise information regarding the differing length of restaurant coaches and the resulting difference in scale.
I will be contacting Maerklin regarding this issue so that it can be corrected for future models, as it is likely that Maerklin will at some point release a model of this coach in either the original red or Eurofima livery.
Offline mvd71
#4 Posted : 30 October 2010 11:03:26(UTC)
Hi Mike,
I don't have your knowledge of the prototype, but looking at the photo's in the links you provided it appears about right to me. Maybe when it arrives and you run it the look may be ok?
Cheers....
Mike.
#5 Posted : 30 October 2010 11:47:41(UTC)
There is already some on ebay.de as well.
Offline jeehring
#6 Posted : 30 October 2010 17:17:47(UTC)
jeehring
mvd71 wrote:
Hi Mike,
...(....)... Maybe when it arrives and you run it the look may be ok?
Cheers....
Mike.
....Don't ask them to use their eyes , it seems that they spend their life with a calliper in their hands. Even in front of the "VENUS DE MILO" those guys will be abble to take a rule or any tool to measure it...LOL ..they don't make MRR, they are working in a design office..!Laugh
...add a bit of a gentle neurosis probably due to the age.....It's entirely imaginary. Don't ask them to have a strong artistic streak, they don't have any.
( do you believe we are abble to say at a glance wether this object is 283 mm long or 294 mm (11mm difference = about 3% ) In a real train station, do you think that we are able to notice at a glance the exact lenght in meters..... or wether one coach is 1.3 meter longer or shorter than another coach ?)
Measuring is entering into an abstraction device...only. Sad
Actually it's just a game involving catalogue announcements & forums on the net....
I agree with you , MRR is visual & tangible.
#7 Posted : 30 October 2010 17:54:55(UTC)
If you see them arranged like this and you know that the dining car (top left) and bar car (bottom right) should be 12.6 mm longer than the other two, then you can see that they are not longer.
We're able to see that a BR 151 loco is almost as long as a passenger coach on a Märklin layout (and we know it's much shorter in real life).
You can also find Umbauwagen (1:87) and Silberlinge (length scale 1:98) in the same train set. It looks as if the Silberling is not much longer (but 33 mm are missing).
With the "new, longer length" coaches at least the number of windows is correct (with 27 cm coaches they often dropped two compartments in order to have the correct proportions ).
If you compare the distance between the windows of the SBB dining car and the red ribbon on the model and on the prototype pictures then it doesn't look correct.
I do notice that - but I don't really care about it.
#8 Posted : 30 October 2010 19:14:32(UTC)
I'm sorry, but I'm bored with the subject of rivet counting. You like it, you buy it. You don't like it, don't buy it!
By all means tell us about the model, but there's no need to be pedantic about absolute dimensions. In this topic, even the rivet counters can't agree about the right length for a coach...
#9 Posted : 30 October 2010 19:50:19(UTC)
I've been using Roco coaches 1:87 for this reason, I still have Märklin freight carriages without short couplings.
I'm doing some conversions for a member and noticed all the details on the undercarriage, I thought to myself, who in the world will ever see this.
the moment a model train is in motion most of the details are out the window and there are so many other shortcomings, we seem to forget or deliberately avoid to tell,
I have a layout which can accommodate 1:87 coaches and therefore don't buy any Märklin coaches except shorter earlier Period coaches which have been made to an 1:87 scale.
As Ray said: don't buy it if you don't like it and don't watch or read it if you don't like it.
I switch off, commercials, TV programs and all other junk I don't like.
Offline Armando
#10 Posted : 30 October 2010 21:00:08(UTC)
Armando
In defense of Mike C.
Instead of attacking and "killing the messenger", I believe that some people on this thread should at least be thankful to Mike for his keen knowledge of the prototypes which he so willingly shares with us. Who else, aside "H0", does this on this forum?
I also have ordered this Bavaria model, especially for the locomotive, because otherwise, I would not have wanted the curtailed cars.
Thank you, Mike, for your enlightening contributions, and please continue to keep us informed about all of the "botch jobs" that you may be able to spot in the new releases! There is plenty of competition out there. Luckily, we have other makes from which to choose for modeling our trains (LS Models, Roco, Rivarossi, etc.).
Armando García
#11 Posted : 30 October 2010 21:23:00(UTC)
I would like to point out that I am not attacking Mike, who is indeed very knowledgeable about Swiss trains.
I am grateful for any knowledge shared on this forum, and I have no problem with Mike pointing out that the windows on the restaurant car are a tad too small.
What gets up my nose is the endless bickering about scale length, whther you should buy models that have minor detail deficiencies, and the horrors of Marklin design. We are all aware that Marklin makes compromises, perhaps more so than some other manufacturers, so why is it such a great surprise when someone measures something to be a few millimetres short of exact scale? Being pedantic about everything is extremely tiresome to the majority who don't care about these things so much.
Along with millions of others around the world, I hold Marklin products in high regard for their many qualities. Accuracy in exact scale measurements is not one of these qualities, but we all know that, don't we?
#12 Posted : 30 October 2010 23:30:24(UTC)
Märklin have a good reputation for the quality of printing.
This year they produced new printing errors (VT 08.5 and Hertha BSC class 101 loco).
The Re 10/10 was critized for misplaced prints.
It doesn't take a ruler to compare the positions of markings between prototype and model, checking the positions relative to e. g. window frames, door handles, or other "landmarks". Wouldn't really cost more to print at the correct position.
This thread is about the new TEE Bavaria set. All three coaches have the same length scale, the "new, longer scale" which is 1:93.6 for most (and for these) coaches.
Märklin have a reputation of making models that look correct. The new dining car looks good, but the windows look too small.
This deviation was not visible on the "handmade sample" (but we all (should) know that these "handmade samples" sometimes are bought from a competitor).
Switzerland is an important market for Märklin. This year they partially wrecked their reputation.
Many customers were disappointed by blackened pantographs, "incorrect" colours of wires on the roof or footsteps.
Disappointed customers are less likely to pre-order 2011 new items.
The good news: the set in question doesn't have blackened pantographs.
#13 Posted : 31 October 2010 02:32:42(UTC)
Watch the video before reading my comment
As Tom stated above, this thread is about the 26557 TEE Bavaria Set. It is not about whether 1:87 is better than 1:93 or 1:100.
I thanked Tom for his initial reply to my post, where he reminded us that DB Restaurant coaches are slightly longer than the compartment and open seating coaches and thus, when Maerklin rendered the models with 282mm length, the scale was different than that for the other coaches. This is not an argument about scale, but a post that should be of interest to most members, with information about the prototype and about the model.
I don't think that any of the discussion makes anybody involved here a "rivet counter"
This thread was to inform members that the Set was available, and to inform them, that in my opinion, the windows on the SBB WRm included with the set were rendered too small on the final model. This was simply an observation compared to other models (Liliput/Liliput/Bachmann/Maerklin's own 4068 window size comparison/and also N scale models by Kato/Hobbytrain and Wabu) and to photos of the original prototype restaurant coach.
The fact remains that the windows on the SBB Restaurant coach should have been rendered a little taller, and thus, should have started closer to the red section of the coach and extended closer to the roof line.
It does appear that the sample model displayed by Maerklin in the 2010 Flyer, at the Messe and other Shows and, incidentally, in the photo on the packaging show larger windows.
The fact remains that Maerklin has made a number of minor mistakes in the design or rendition of various Swiss models over the past few years, and many of us who collect or model Swiss railways are disturbed by the frequency of this minor shortcomings that could easily have been avoided with a little extra care in the process. Look how little effort it took Maerklin to correct the 37360 Ae 610 by changing the pantographs to gray (thanks Lutz) and fully painting the blue section to the roof line, which I advocated this summer. Things like this or the size of the windows should be detected and corrected by quality control during the design and production phases. Maerklin CH seems like little more than a distribution company, as they don't seem to be proactive with continuity and quality control at all.
Point final c'est tout. (or basta!) as one member would put it.
If you want to comment, we would be interested to hear a) what your thoughts about this issue are? b) would this affect your decision to buy this item?
If you have information to contribute about details (like the fact that DB Restaurant coaches are longer than other coaches), please feel free to share that info.
If you have nothing to say but to criticize or attack members for alleged model RR beliefs, please refrain from posting in this thread.
Respectfully yours,
Offline Piggy
#14 Posted : 31 October 2010 03:22:30(UTC)
Piggy
Thank for the infomation, Mike and Tom. I like the set, and if I can find the money I will buy it. I bought the BR210 (39189) some time ago, so it would make sense to me withg this set (I guess my wife thinks otherwise).
Kenneth
Offline Unholz
#15 Posted : 31 October 2010 08:50:11(UTC)
Unholz
It increasingly seems that Switzerland WAS an important market for Marklin. ThumbDown The wrecking or at least crumbling of their reputation didn't only start this year - or are the following more or less recent incidents already forgotten?
- the catastrophy with the truck skirting and the interconnectors on the RAe TEE II (39540)?
- the originally blue tinted cab windows on the Ae 6/6?
- the catastrophy with the rounded, ship-style windows and the general appearance of the light steel baggage van?
- the zinc pest heavily affecting the De 6/6 (37521)?
- the scale deficiencies on the Eb 3/5 steamer (37131/37136) and the amateurishly concealed motor in the cab of this model?
- the wrong cab handrails on the set with one green and one red Re 4/4 II (37342)?
- the grotesquely bent handrails on almost the entire series of brown Ee 3/3 (36331)?
- the policy of putting together strange sets which virtually can't be sold in Switzerland (37346 Crossrail)?
- etc. etc. etc.
All this adds to the simple fact that Marklin is no longer regarded as a serious "player" on the Swiss model train market (but simply as a toy manufacturer) and that all the so-called "issues" regularly listed here are more or less taken for granted by the remaining Swiss customers. Hardly anybody cares about all these "issues" because they have become the STANDARD on Marklin products. Thus, if you like the brand or a specific model, then please buy it - if not, then just buy something else and stop the constant whining. Ray Payas hits the nail on its head by saying above:
Regrettably, the "Swiss" threads in this forum are beginning to become really boring because they always follow the same line Crying . Frankly speaking, I presume that Marklin now maintains an individual trash folder for e-mails originating from a certain person who appears to be determined to find at least one "issue" in EVERY single model LOL . However, model railroading should be FUN and remain a pleasant hobby. If you go at it with the attitude of searching for as many "issues" as possible, then you will certainly find flaws everywhere - with Roco, Fleischmann, HAG, Lemaco, Liliput etc. etc. But is this really life and enjoyment? Blink
And now - like in approx. 67 previous threads - we can once again look forward to the regular, VERY long justification by our member who will try to tell us the difference between himself and a rivet counter or a nitpicker. Sad Bored Thanks for listening - over to Montreal... Wink
#16 Posted : 31 October 2010 08:54:06(UTC)
no comment
#17 Posted : 31 October 2010 09:26:49(UTC)
Hi, John!
river6109 wrote:
the other scenario would be to leave the restaurant car at 1:93 and shorten the other coaches.
German restaurant cars are 1:97.
Märklin makes new coaches with a maximum length of 28.2 cm. This allows 1:87 for Hecht coaches, 1:93 for passenger coaches and 1:97 for some German dining cars.
river6109 wrote:
This would mean a different mould, for an item that has a selling capacity of approx. 1:6.
Roco dining cars are 316 mm, Roco passenger coaches are 303 mm.
river6109 wrote:
to design such a shortened coach, the height, presumable would also be reduced, hence smaller windows.
Height is 1:87, width is 1:87, length is between 1:110 and 1:87 - therefore windows should have the correct height.
The Swiss dining car in question is length scale 1:93, therefore the Windows should have the same height as the passenger coaches..
Märklin decided not to lose the R1 market.
Thus they lost the "I don't buy shortened coaches" customers.
river6109 wrote:
todays coaches: 1:93 = all different type of coaches same length
Todays coaches: 28.2 cm max. (scale between 1:87 and 1:97)
#18 Posted : 31 October 2010 10:19:59(UTC)
no comment
#19 Posted : 31 October 2010 10:41:22(UTC)
river6109 wrote:
regarding TEE carriages, they are 1:93 and are the same length right through their different coaches including dining car.
Model dining cars are the same length - but some dining cars with a length of 28.2 cm have a scale of 1:97.
The definition is not "1:93", it's "28.2cm"
Märklin documents "28.2cm", they don't document "1:93".
Märklin calls it "28.2cm", customers call it "1:93".
The Rheingold dining car 43870 is 1:93, the TEE dining car 00776 is 1:97 - and the windows look alright.
The 26557 dining car is 1:93 and the windows appear too small.
#20 Posted : 31 October 2010 11:40:29(UTC)
Reading one of Mike's posts above made me realise I hadn't actually given my opinion on the model, which I fully intended to do. Sorry!
This was a set which I had down from the beginning of the year as one of my purchases for this year. Unfortunately, coming right at the end of the year and being quite expensive compared to a single loco, I could not find money in my budget for it, so it might have to wait for another time.
I think the set is beautiful! The Re 4/4 I looks very nice in the TEE colours, and seems to be well done, though I'm no expert (for that I rely on people like Mike and Stephan). The coaches look good, and I was not aware they should be a different length, and would have been quite happy with them anyway. I would have been a bit worried about running them on my R1 curves, so longer coaches would not have been acceptable for me.
The issue with the size of the windows would not deter me from buying it, though I do concede it looks a bit unusual.
Offline Unholz
#21 Posted : 31 October 2010 11:41:41(UTC)
Unholz
...and for all those whose purchase decision doesn't depend on measurements or scales but simply on the visual appearance/acceptability of a typical Marklin model, here is a comparison picture of the prototype (only in a newer livery) and the model:
#22 Posted : 31 October 2010 19:51:07(UTC)
Thanks to Stefan for posting the photo, and once again, thanks to Mr. Roder at Bahnorama for posting the detailed photo(s) on his website. The Restaurant coach, on it's own, does not look too bad. The problem does, however, become much more noticeable when the Restaurant coach is next to other coaches which have a better rendition of the window heights.
My intent has never been to find something wrong with every model. This thread was to inform members that the item had been released. At the same time, I made a basic observation based on the first photos of the actual production model (as shown on eBay and Swiss dealer Suter-Meggen).
The complete 26557 Set (Photo taken from Bahnorama.ch):
Original SBB WRm coach:
This thread did not go the way that many of these threads have been going until one member decided to throw a wrench into the gears (originally said "monkey into a wrench" (a poor pun)) and attack "rivet counters".
I stand by the original post and my initial assessment of the model. The final production model of the WRm is not as well rendered as was the "Handmuster". That is the basis for my disappointment with this item.
I am, however, looking forward to the Set because the Lok looks very nice. As far as I know, this is the first model to accurately represent the Lok with one SBB and one DB pantograph. Neither the Hag, Metropolitan, nor Lima models have had this detail in production. I might have preferred to have a model with the same motorization as the 39421, but will wait to see how the new model performs in person.
I cannot ask Maerklin to change the appearance of the WRm model, as the Set has already been delivered. I will likely contact them and ask them to correct the model mould so that it is correct if they ever do release it in either it's original red or more recent Eurofima (C1) livery. Whether my emails are sent to a special "trash" folder or not, what I do is for the benefit of all modellers and not just for myself, and it surprises me how frequently I am attacked for trying to make the effort.
I look forward to a few nice Swiss models every year (if that). I would hope that the companies would make the effort to make those models as prototypically as possible, accepting the need for the occasional compromise. A detail like the appearance of the windows of a coach, the paint on a lok, the handrails on another lok are minor and could have been avoided with a few minutes more attention to detail. I guess my main criticism is with the lack of proper continuity and follow through in the development and production of models that I hold close to my heart.
Yes, model railroading is fun. I enjoy looking at my models. I love running them from time to time, especially when I set up a multi room "teppichbahn" and can enjoy watching long trains run all over the basement. Each year, I anticipate the release (and reception) of these new additions to my collection. Not all have faults or if they do, most are still completely acceptable. Unfortunately, many of them do have shortcomings and I should be able to discuss those details in a forum where I am one of a number of equal members. The main difference is that I am attacked for making a statement, something that does not happen when other members post topics. That is what makes these topics tiresome, and it is my opinion that this is started by certain individuals who wish to distract the general membership from any critical discussion of Maerklin products. I note that in similar threads in other forums, the models have been criticized for motorization (SDS vs Buehler), for digital (ESU vs other/Maerklin) and those criticisms have not been attacked in the same way that my comments about the external visual appearance have been.
As far as this topic, I think that I have said all that needs to be said. The only thing that I could possibly add would be photos of the actual model once I have received it as well as photos of the Maerklin Lok with corresponding 1:87 coaches from other companies.
#23 Posted : 31 October 2010 20:14:57(UTC)
Mike, I didn't decide to "throw a monkey into the wrench" (whatever that means?), but I did express my opinion about the constant squabbling about minor details. I am not the only member who thinks this way,and if you read this thread you realise that there are several others who also get irritated when you have to find some fault in every new model that comes out.
It is of course your right to express your opinion, and I apologise now for having reacted to it. I'll try to keep my irritation in check in the future.
#24 Posted : 31 October 2010 20:17:21(UTC)
Ray,
I was not referring to you. Your post came later and was partially in response to the one that I was referring to.
"Throwing the monkey into the wrench" was a silly word play on "throwing the wrench (or the shoe (sabot)) into the gears"
#25 Posted : 31 October 2010 20:30:36(UTC)
mike c wrote:
Ray,
Thanks for that, Mike. I was going to take you to task for cruelty to monkeys! BigGrin
Offline TimR
#26 Posted : 31 October 2010 22:44:44(UTC)
TimR
Indonesia
Thanks for pointing this out, it escapes my mind that this is how M* calculate their math.
I would have thought "new, longer length" means closer-to-actual scale eg. 1/93,5 instead of the previous 1/100. Seems the length of 28.2 cm maximum is the key instead of the scale.
No, I don't mind shortened coaches made to a smaller scale length - but the inconsistency on how this was applied baffles me - particularly when applied within the same consist set (of coaches).
I know that the Hecht cars and Umbauwagens are closer to their true scale length - being shorter in length compared to modern passenger cars, so I don't mind those despite looking probably a bit long compared to the latter but...
I would have thought up to now, that the German restaurant car (such as in TEE example) is of exactly the same length as the passenger coaches.
Now, knowing it's not true, I feel that I had been misled and disappointed somewhat...
OTOH I do realize that M* did this to simplify their tooling.. easier just to make them all to the same maximum length.
Since the current "new, longer length" toolings are considerably new and Marklin is yet to make enough money out of them - I'm afraid we're stuck with them for now.
With the SBB restaurant car in this set, very, very unlikely that they'll do something to correct it... The mould is simply too new - even if they are plastic, it'll be too costly for them to modify.
Now collecting C-Sine models.
#27 Posted : 31 October 2010 23:54:07(UTC)
Tim,
I agree with you that the whole issue of differences in scale can be rather confusing.
The real (1:1) coaches have different lengths. The restaurant coaches (DB) are longer than the 26.4m compartment and open seating TEE/IC/EC coaches of the UIC-X or UIC-Z standards.
I am not sure if this applies only to the Wrmz132 and Wrmz135 or whether it also applies to the ARmz (mixed restaurant/1st class) and other similar coaches too.
The Swiss diner was built to UIC-X standards and conforms to the SBB Am, ABm, Bm and Bcm coaches in terms of length and design.
This is not a new issue. The older 270mm models of the DB TEE and IC Restaurant coaches also had the same issue vis a vis the respective passenger coaches.
But I digress... Back to the issue of scale...
My biggest issue with the decision to go with 1:87 for some coaches, 1:93 for others (282mm coaches) and 1:97 (for these restaurant coaches when made with a length of 282mm) is the fact that although one can easily overlook the fact that the restaurant coach is not longer than the other coaches, it does look a little unusual when combining 282mm UIC coaches with say a SBB lightsteel diner and a couple of lightsteel coaches which are exact 1:87. The same would apply for mixing blue and green DB UIC coaches (282mm) with earlier shorter (also 1:87) DB coaches of the type that could be found together in the 1950s/early 1960s.
At least with the older (1980s) 264-270mm coaches, they could be combined with the 4066 SBB EWII A which had the correct aspect ratio of 240mm to the 264mm of the UIC-X/Y coaches.
The 4068 (restaurant) did look a little unusual in that consist because it was a 240mm rendition of a model that should have been 264mm in 1:100.
As far as the SBB Restaurant coach mould. It would not require too much work to enlarge the holes for the windows in the master. All subsequent productions would then have the correct aspect.
They would have to redo the moulds for the window pane inserts, which would be a whole new part. I would never expect them to take back the current models and fix them. We will have to live with it as is.
The length of the Restaurant coach is an issue that I have no problem accepting as a compromise. The fact that the windows are smaller than those on the other coaches in the Set and are resultingly noticeable when you look at the set is something that did not need to occur and could have been corrected with a little more effort. For the price that they charge, I think that we deserve to have stuff like this corrected before the models come out.
#28 Posted : 01 November 2010 00:24:14(UTC)
Trying to keep on topic what I dont like about the coaches (as shown above in the pic)are the corridor ends and the roofs.
Both look cheap and plasticky (if there is such a word) and I would need to do some weathering or re painting. The Loco does look nice however. So I would not buy this set but not because of the length of the coaches or the windows but just that I dont think they are worth the cash. The loco (as said) I would however buy.
I agree with Ray in that it is all a matter of personal taste and I appreciate Mikes comments on everything Swiss.
dave
#29 Posted : 01 November 2010 01:25:57(UTC)
I withdrew my comments after reading Mike's original post, which said nothing about the length.
I think it is too often one reads along the replies and answers and doesn't realize the topic has slightly shifted from one observation to another.
the only other observation I've made from Mike's first post pictures is, the SBB Restaurant car has a length of 26.4m which equals 303mm and for Märklin standards, a length of 282mm (1:93) and not 1:97
Stefan wrote:
This is the restaurant car in question and the length is: 26.4m, which indicates Märklin hasn't shortened the model of a shorter model.
Another observation: Having said the SBB restaurant car is 26.4m and has a different roof and therefore has been manufactured (Donauwörth, Germany), possible for SBB standards, the other TEE cars may have been manufactured for German standards, hence the different window height ? or as Mike said in his original post, the windows hight seem to be smaller.
When you have a close up look of the original with its white line and the destination plate sitting just on the top edge of the white line and this is repeated on the Märklin model except the white line is now a TEE colour line, one can also observe the white line matches up with the door handle in the middle whereas the Märklin model the TEE colour top line matches up at the bottom of the door handle and thus suggesting the windows sills are higher up than they should be.
Offline TimR
#30 Posted : 01 November 2010 01:58:04(UTC)
TimR
Indonesia
I guess my issue was that I read too much into the marketing hype of the "new, longer length" concept.
Whether or not I'm buying this set is still a big IF, not because the issue with the window size, but more with the pricing, timing delivery and stock availability.
If I missed this one, I think I'd be happy to just settle with 37044. Or otherwise wait a couple years until they decided to release another TEE Re4/4 I.
#31 Posted : 01 November 2010 03:24:34(UTC)
This thread mentioned the SBB WRm diner in the 26557 Set. I compared the problem with the size of the windows to the situation with the ARDm Bar coach in the 42991 Set (also 42972). I referred to those coaches as 1:93, with a length of 282mm. Tom replied to my thread, referring to my mention of 1:93 to mention that the DB Diner coaches were in fact 1:97 as the real DB diner coaches were longer than the regular passenger coaches and the Swiss diner.
Here's a photo of the production model (Bahnorama) to compare to the original protoype as shown in the New Items Flyer (Maerklin)
26557 Production Version:
26557 Prototype Version (Maerklin 2010 Flyer) (with lower mounted taller windows):
As I stated above, the SBB WRm does not look bad on it's own. The undersized windows are much more noticeable when the diner is next to the other coaches.
In the end, this is a minor issue that would not be as irritating if Maerklin did not have a track record of letting such flaws slip through the quality control department.
Offline jeehring
#32 Posted : 03 November 2010 05:03:47(UTC)
jeehring
1/ You don't have the model....how can you deal with photos (bad photo)....instead of the real model ! (blurred photo...on which we cannot even distinguish the window frame....window frames are different from one type of coach to another...)
2/ you say : "The undersized windows are much more noticeable when the diner is next to the other coaches"....pffff......are you sure that have the same size of wondows ? Since you are critizing....I suppose you are....RollEyes .
BTW did you know the exact prototypical size in centimeters of the windows...on restau coach...on each kind of coach....I suppose not...otherwise you had mentionned it already...
#33 Posted : 03 November 2010 05:42:53(UTC)
@Roland (Jeehring),
here is a photo of the SBB WRm (the actual coach in TEE livery) next to SBB Am (Eurofima) and Bpm coaches.
http://www.bahnbilder.de...Wagen~Personenwagen.html
The Am and Bpm have the same window height as the Avmz111, so you can see that the windows have the same height as those on the passenger coaches. This is not the same as on the Maerklin model. Incidentally, if you have the set and place the WRm on the box next to the image on the box, you can see that the original handmuster that was used to make the image had taller windows.
Offline kurtjr
#34 Posted : 04 November 2010 20:11:48(UTC)
kurtjr
Hi gents
I got mine today and it looks great! The restaurant car fits in perfectly with the paint scheme of the german cars.
the locomotive is also really nice.
i'll enjoy this set. Too bad the car signs are Munich to Zurich and not the other way around. Could of done a switch around with the other earlier Bavaria set on my layout.
I'm sure you will all enjoy this set too!
Kurt
All SBB's, SNCF and US/CDN model's.
Offline TomB
#35 Posted : 04 November 2010 20:50:42(UTC)
TomB
Hi folks.
I will fly to Munich tomorrow where among others a 26557 is waiting for me. BigGrin BigGrin
My german dealer got it 2 days ago, just in time for my visit.
I have a big suitcase, almost empty.
Tom Blikstad
HO, german/swiss trains, Märklin K+C, ECoS I+II,
Viessmann, Kühn, MBTronik, WinDigipet 2012, WinTrack 11
#36 Posted : 05 November 2010 03:11:24(UTC)
You have been a member since:: 17/09/2006(UTC)
I have deleted a certain post from this thread that threatened to derail it, and the responses to it. The Moderators are not going to stand for topics being derailed, wrecked or otherwise hijacked just to suit one person's ego. Any more will be dealt with harshly!
Offline Unholz
#37 Posted : 05 November 2010 18:44:11(UTC)
Unholz
For those who are more or less fluent in German: A guy in the Stummi forum has taken the trouble of measuring the windows of the dining car in this set. He has come to the conclusion that the deviance is a gigantic 0,08 millimeters...Tongue
http://www.stummiforum.d...pic.php?p=556299#p556299
Offline MarioFabro
#38 Posted : 05 November 2010 19:12:35(UTC)
MarioFabro
My set is in the mail from Lokshop. Looking forward to it. With all due respect, I am not interested in the window size etc. etc. I like trains for a more primitive type of passion. I believe that the Marklin ones are better designed and built than any other. I have HAG, Roco, Rivarossi, Piko, Fleischmann, Brawa, Lima, Acme and ViTrains in my collection and Marklin sits on top, for my personal opinion.
The scale issue has been covered in dozen of other threads and we should leave it out definitively: you like 1:87? fine. you like 1:100? fine. To everyone each own.
I appreciate Mike C knowledge and comments but for me such small details will never be the ones determining if I buy or not a model: that decision is for my soon-to-be wife only! Now.. let's hope when the set shows up she is still at work and I have time to "hide" it in between my other trains :)
#39 Posted : 05 November 2010 19:52:56(UTC)
These are the theoretic sizes:
1.200 x 900 in 1:93,5 sind 12,83 x 9,63
1.200 x 900 in 1:87 sind 13,79 x 10,34
These are the measured dimensions:
12,75mm x 9,55mm
So with a general scale of 1:87 and a length scale of 1:93.5, one would expect the windows to be 12.83 x 10.34.
This gives a deviation of 0.8 mm in height, not just 0.08 mm.
Maybe they used scale 1:87 for the height of the coach (and the red and cream ribbons) and 1:93.5 for the height of the window - so that would explain the difference.
Here are four windows of my Aüm coaches:
from left to right: Roco 1:87, Märklin 1:93.5, Märklin 1:100, Märklin 1:110
All pictures have been taken with a tripod from the same location with the same camera settings.
The height of Märklin's 1:93.5 window matches the height of Roco's 1:87 window.
So the problem with this Swiss set could simply be: Märklin kept the aspect ratio for the windows of the Swiss dining car while using the correct height for the windows of the German coaches.
Offline grnwtrs
#40 Posted : 05 November 2010 21:18:44(UTC)
grnwtrs
Armando
Thank you for the very eloquent comments regarding Mike C's reports on this site. Whether it be
about Swiss trains/models, or whatever, his views are straight from the shoulder. Something
the "other critics" on this board can't stand. There seems to be an epidemic of who can shout the loudest is the winner. NOT!
Thanks again Armando BigGrin Now I can go back to read the rest of this topic.
gene
#41 Posted : 05 November 2010 23:34:05(UTC)
There has been a lot of discussion about whether the windows should have been rendered in 1:87, which is the scale used for the height of the coach or in 1:93, which is the scale for the length of the coach. Here is where the issue of compromise in design comes into play. I would have preferred if the windows had the correct height aspect, but were rendered a little less wide. In my opinion, this would have been the less visible of the available options. By rendering the windows in what may be 1:93, the windows have the correct width for the length of the coach, but do not have the right height. It then also becomes an issue of whether the windows should start at the point where scale windows would start, or are placed a little higher, to make the lack in height a little less evident at the top. I think that the deciding factor in this issue should have been be examining how this coach looks alongside the rest of the coaches in the set and also to consider how this coach will compare to possible future models of similar SBB coaches (Am, ABm, Bm, Bcm, Bpm) that Maerklin may make in the future. Given that the coach should have the same aspect used for the remainder of the coaches in the train, they should have decided to use 1:87 for the height and 1:93 for the width, which would have rendered windows with a width of 12,83mm and a height of 10,34mm. The actual model has window sizes of 12,75mm by 9,55mm according to Mulliba in Stummi. I think that if the would have opted for windows with a width of 12.75-12.8mm and a height of at least 10mm, the model would look much better and closer to the prototype.
I am not a rivet counter, but given the last few posts above, I wanted to clarify that the discrepancy is at least a half millimetre and not the 0,08 mentioned above.
It is also true that the door handle on the restaurant coach appears to be at a different height in regards to the red band on the coach side. It was suggested in Stummi that the red band may be a little too low, but I cannot confirm this. Here is another photo of the prototype (actual) train where you can see how the WRm windows compare to the adjacent Avmz (as posted in Stummi):
http://www.abload.de/ima...p?img=205924sbo3vfaz.jpg
What would help us make a conclusive determination would be if somebody would post a photo of the three coaches of the set coupled together, and maybe also for reference, the WRm coupled to a Liliput WRm and to the classic 4068 for comparison. My ordered set is in transit and will probably arrive in three to five weeks.
For anybody who wants a similar issue to compare, look at the original Liliput SBB WRm and Am/Bm/Bcm. The passenger coaches had windows that were too small (not high enough) whereas in that case it was the WRm that had the correct window aspect for the prototype. I guess that if it were not for the difference in scale length, the new Maerklin WRm would probably match the 1970s Liliput coaches to a T. The newer Bachmann-Liliput and LSM SBB coaches have the correct window aspect.
The Stummi thread also mentions that on some Sets, the footstep of the driver's cab on the side of the box facing down into the styrofoam packing may be damaged either in transit or during removal of the lok from the packaging. Please use care when removing the lok from the box to ensure that it is not damaged.
#42 Posted : 06 November 2010 00:20:42(UTC)
I find these comparisons between model and prototype very enlightening, kind of gives a perspective on what compromises model makers have to do and what compromises can pass scrutiny or not for those who are really interested in getting an exact model of the prototype.
However, I believe the majority of model railroaders can accept compromises as long as it "looks ok" in a consist or such and the extreme detail discussions are very educational but will maybe not be a final decider of getting a model or not for the majority of hobbyists. It's all in the eyes of the beholder.
As usual, sometimes it seems that criticism towards details of a model is misunderstood as brand-bashing, which can arouse some excessive brand loyalty feelings at times... But I don't see it that way, I want to learn and am interested in what the necessary compromises made between a produced model and its prototype are...
#43 Posted : 06 November 2010 01:01:46(UTC)
Thanks Juhan for a good explanation.
Being thousands of Miles/kilometres for the real thing and most likely will never see the real thing, I buy what I like and sometimes I may see something that I must have because it looks good and has no obvious , to me, flaws in its construction.
SO if it looks good I may buy it. I will have no idea how close it is to the real thing. I suppose I am an impulse buyer. If the price is right and I like the looks I would buy it.
Currently it will have to be really good and a very low price for me to buy. I got a shock yesterday. I was asked how many locos that I had. through my impulse buying and Must haves and some presents I discovered I had 52. Scared
I still have a wish list which I may get or may not.
A bit off topic but along the lines of Juhans Post.
NN
#44 Posted : 06 November 2010 01:47:50(UTC)
Here is a photo of my Liliput WRm (bought 1984) next to a Roco Avmz (2008). The Liliput WRm had the correct aspect ratio for the windows. You can see that the height is similar to that of the Roco Avmz, which also has the correct aspect ratio for the window. The Roco does have one flaw, the dark gray/black skirt is a little small and the beige stripe is too thin.
Here is a photo of the same Liliput WRm, this time next to a Liliput Bcm coach. The Liliput SBB Coaches (Am, Bm, Bcm) all had incorrect window aspect ratios. The window bottom is at the correct height, but the window height should extend to about 1-1.5mm below the roofline.
It doesn't take much deviance before such a feature becomes noticeable and the more frequent this type of flaw occurs, the more irritating it gets. I don't expect perfection, but I expect more than what they have been delivering in these instances. It all comes down to the difference between "it's a nice model" and "it's an amazing model". Personally, I would take amazing over nice any day, especially at the prices that they charge today.
Offline mvd71
#45 Posted : 06 November 2010 05:33:29(UTC)
Hi Mike,
Perhaps Marklin has made the windows shorter on this coach to try and give a longer more stretched look to it in a effort to compensate for the fact that it too short in overall length when compared to the other coaches?
What do you think? I know it still doesn't give the result that you would ultimately like, but it might be the reasoning behind the proportions?
Cheers...
Mike.
Offline jeehring
#46 Posted : 06 November 2010 06:01:08(UTC)
jeehring
Some people probably like to row in the air BigGrin... We can make a photo telling anything we want...
Dealing with photo must be done in a VERY VERY rigorous way....(like TOM HO has tried to do...without picture of the real prototype....unfortunately)
There are so many optical effects, lense abberations, etc.........
we don't see the window on real prototype photo in a same way than on a model photo....On the photo of a prototype we tend to see the whole window/the whole gap, on the photo of the model we tend to see the glass surface only...
On models , window frames cannot be at scale , they often are oversized (excepted if you pay 400 E for one handycraft metal model of coach), sometimes not to depict the window frame may be even better ...( a matter of taste)
Edited by user 07 November 2010 09:20:17(UTC)  | Reason: Not specified
#47 Posted : 06 November 2010 12:24:05(UTC)
mvd71 wrote:
Hi Mike,
Cheers...
Mike.
Mike,
The restaurant is in the same scale length as the other coaches in the set, so there would be no need to compensate for length. The issue strictly concerns the height of the windows on the SBB restaurant coach. I am not going to speculate on how or why Maerklin made this mistake.
All that I can ask is that the windows be modified if they eventually release a similar coach in either the original red or Eurofima C1 colours.
#48 Posted : 06 November 2010 12:45:42(UTC)
jeehring wrote:
Some people probably like to row in the air BigGrin we can make a photo telling anything we want...
we don't see the window on real prototype photo in a same way than on a model photo....On the photo of a prototype we "see" the whole window/the whole gap, on the photo of the model we mainly "see" the glass surface only...On models , window frames cannot be at scale , they often are oversized (excepted if you pay 400 E for one handycraft metal model of coach), sometimes it may be even better not to represent it...( a matter of taste)
There are those who continue to deny the fact that the windows are too short... Even though it was reported and has been discussed in at least two international forums. It must be because of optical effects or lense abberations. Yes, the windows are too small because the frames are oversized... Ok, you lost me there...
I did not pay 400 EUR for my Liliput or Bachmann-Liliput WRm. Neither will I pay that price for the announced model of the same coach from LS Models (due out early next year). Yet, all three of those manufacturers managed to get the aspect right.
I challenge you to explain the "Bullseye" windows on the Lightsteel baggage car or the windows on the ARDm bar coach from the 42991 Set using your theories.
A simple solution. Post photos of the restaurant coach next to the other coaches of the set.
As soon as I receive my Set (in about 4 to 6 weeks), I will post the following photos:
1) Maerklin WRm in consist with the other coaches
2) Maerklin WRm on box to compare with image of prototype handmuster used for photo
3) Maerklin WRm alongside Liliput or Liliput-Bachmann WRm
4) Maerklin WRm alongside classic 4068
In the interim, here is a photo taken from an eBay listing which shows the WRm coupled to one of the other coaches in the set:
http://ebay.hhost.de/showpicture.php?id=265571
Auction: http://cgi.ebay.de/Markl...1961c883c#ht_1660wt_1141
If anybody wants to see a schema of how the WRm coach should appear, check the www.lsmodels.com website. I think that the WRm diagram has been shifted to the second page due to recent additions to the new announcements.
You cannot change or deny the fact that the model, like the earlier bar coach, has windows with the incorrect aspect ratio. But I gotta give you props for trying.
Respectfully,
Offline 7gauges
#49 Posted : 06 November 2010 15:14:52(UTC)
7gauges
I don't know but it seems to me that if folks don't like the set they shouldn't buy it. I quite like y set - but then I don't use an electron microscope in examining the details. It looks great running as a consist and thats all that matters.
If people want absolutely 100% true to proportional scale models - they should build their own, or spend the big bucks on the limited hand built production runs.
Bottom line - its a toy and you have to make sacrifices for effective running.
Just look at Maerklin's Grey mouse and Gottardo - the trucks are ridiculous the way they cut out of the body on corners - but it works just fine running on a layout.
#50 Posted : 06 November 2010 16:05:18(UTC)
Mike,
What do you think of putting posts under the "review section" when we talk about a model's appearance.
Your post states: Maerklin 26557 TEE Bavaria Set Delivered in Switzerland, you than go on about the appearance of the coach.
Hopefully this will greatly reduce the criticism you get every time you're posting a topic.
I'm just trying to help.
Guest (5)
3 Pages123>
This page was generated in 2.109 seconds.
