#1 Posted : 27 October 2010 21:53:17(UTC)
In another topic it was advised to use car batteries as power supply for your controllers,
due to their ability to hold a constant voltage.
Trying to keep topics separated, I've started this topic about the dangers of using car batteries indoors or as power supply for MRR controllers.
1: Car batteries can explode if accidentally shorted with a strong enough wire or tool.
My friend Arne Petersen has a glass eye because of dropping a spanner on a car battery, it exploded.
2: When charged, a car battery produces an explosive gas mixture of hydrogen and oxygen, which under normal conditions dissipates.
If the battery is kept in a closed box, the explosive mixture will fill the box, and a spark can ( Will !!! ) make it explode.
3: A 60 Ah car battery are build to deliver > 600 Amps current for starting the car, this current is delivered so fast and strong that most electronic
current limiters don't react fast enough, which in the case with a MS, CS or 6021 / 6015 / 6017 will cause the device to let the expensive smoke out.
Older devices such as Delta 6604 or 66045 has a bimetallic fuse which is far too slow for the current from a car battery.
http://www.google.dk/ima...ql=&oq=&gs_rfai=
http://www.answerbag.com/q_view/2049030
http://forums.x-plane.or...ndex.php?showtopic=14377
http://en.wikipedia.org/...ry_(electricity)#Hazards
http://en.wikipedia.org/...tery#Exploding_batteries
Google can give you many more examples Wink
#2 Posted : 27 October 2010 22:16:57(UTC)
In another topic it was said that UPSs also contain batteries. True.
But those batteries feed an AC generator that will provide 230 V AC (or other household voltages) to your computers. Those AC generators do not support the full power of the battery.
Offline dntower85
#3 Posted : 27 October 2010 22:32:18(UTC)
dntower85
There are several companies producing equipment for off grid applications, that use car batteries with solar, wind and hydroelectric generators.
Some have cabinets for outside or garage storage, and come with some type of power inverter for AC applications. Some have 12V, 18V, and 24V DC outputs So there are ways to run a controller off a battery, I plug my cellphone in to my car all the time, it and draws as much amps as needed but has a fuse in the adapter in case of a short.
I would just have a fast acting 2amp fuse in place, that would keep the smoke in and not weld the Wheels to the track if the train derails.
Even better would be a Current limiting circuits http://en.wikipedia.org/wiki/Current_limiting
DT
Offline arconell
#4 Posted : 27 October 2010 23:08:09(UTC)
arconell
Hi Purellum,
You are absolutely right, all these things can happen! What I don't understand is that you don't plea for a total ban on all batteries world wide. My advice: don't ever come close to any car, lorry, airplane (they have batteries too), mobile phone, camping (people use solar panels there with batteries), caravan, computer, torch...
By the way, search for exploding gas tanks, laundry washers, TV sets, tires, airplanes, stoves, ovens, mobile phones, want more?
I don't want to be pedantic but this is ludicrous, nobody, not I even said that you should use a battery, I said you can use one.
By the way, my stepmother died today, may she rest in peace. At the blessed age of 98 years and as a result of falling out of her bed (this is true). I think I will go to bed now or do you think that that is too dangerous?
Ps: if the forum administrator wants to delete this message, fine with me, please do. If he wants to ban me from the forum: fine also.
Ps2: let's keep this a model railway forum, not a place to vent your fears, panics and what not...
Wishing you a good nights' sleep without nightmares, Robert
#5 Posted : 27 October 2010 23:08:11(UTC)
Edit: This was written while Arconell was posting and not an answer to his post:
You are both right; but in these cases the equipment are build for that purpose, Märklin controllers are not.
Most household UPS batteries are sealed and much smaller than a car battery, and much more suitable for controllers.
The wind turbines I work in also have UPSs, and even though the batteries last much longer,
they are changed every 3rd year for safety reasons, meaning that I have lots of those "in stock" BigGrin
No matter how fast a "normal" fuse is, it is not fast enough when it comes to protecting electronics.
I also wrote in the other topic where this came up, that current limiting circuits are the way to go, so I agree completely;
but it should be a separate device designed for the task, not the internal circuit in your Märklin controllers.
( It is possible that the current limiter in a MS2/CS2 can handle power from a battery; but in that case they are the only Märklin controllers that can. )
#6 Posted : 27 October 2010 23:18:14(UTC)
@ Arconell:
I'm only trying to describe the dangers of indoors use of CAR batteries with controllers not designed for them.
Offline GSRR
#7 Posted : 27 October 2010 23:29:47(UTC)
GSRR
Let's not make a mountain out of a molehill. I understood Robert using the battery as illustrative of what can be done, not what has to be or should be done. If someone wants to haul a battery into their house and connect it directly to their layout without any safeguards, so be it, their choice.
The seperate threads the last few days dealing with track feeds, transformers, etc. have been informative and engaging, as it should be. Keep it coming. I'm always happy to see people post about their layout or pictures of their rolling stock, but I also want to learn.
Robert,
Sorry for your loss. I see no reason for you to feel you have stepped out of bounds.
Thomas
#8 Posted : 27 October 2010 23:56:13(UTC)
Robert, sorry to hear about your stepmother. May she rest in peace after a long and hopefully rich life.
No need to delete/ban anything - we are human here...
#9 Posted : 28 October 2010 01:48:52(UTC)
Webmaster wrote:
...we are human here...
Well, I think most of us are! Not sure if anyone has registered with 'Alien' in their profile yet....although I do wonder about some of those members from the West Island! WinkWink
Offline arconell
#10 Posted : 28 October 2010 02:20:15(UTC)
arconell
Thank you and the others here for your words, she´s had a great and very fulfilled life, not always easy to say the least. Then again she never chose the easy way out. She went with a smile,
Best wishes, to all of you, Robert
#11 Posted : 28 October 2010 04:07:47(UTC)
You east Islanders are upset because we are the main land and are superior in all things except maybe Mobile Wrestling where the All Balacks (Mainly white) may for a short period of time may win the odd game through Bribery and corruption. RollEyes Blushing Blushing
(Into the trenches, flak jackets on) ThumpUp Razz
Offline mvd71
#12 Posted : 28 October 2010 12:01:25(UTC)
You tell'em Nev. We all know the grass is browner on your side of the fenceFlapper
Cheers....
Mike.
Offline kariosls37
#13 Posted : 28 October 2010 23:53:54(UTC)
kariosls37
in other news, hostilities on the Tasman fromt have resumed
A big Flapper from clean, green New Zealand (aka paradise)
#14 Posted : 30 October 2010 04:53:51(UTC)
Thanks, Per - most reasonable advice by you ThumpUp
And don't be surprised, my friend. Cemeteries are full with non-believers ... LOLLOLLOL
#15 Posted : 30 October 2010 07:03:32(UTC)
Cheers....
Mike.
Actually it is VERY green at the moment.. We have had more rain in the last month than the last five years... How long can you tread water??
You gotta love those greenies - when there is no rain it is global warming and when there is rain it is global warming... LOL They seem to forget that the plant life needs Carbon Dioxide to survive.. Razz
#16 Posted : 30 October 2010 13:46:02(UTC)
We always have rain on big sporting events and when car washing or gardening or having a picnic or barby or anytime we want to go outside. The sun always shines when indoors watching TV or playing trains. Taking trains outside means more rain. It is also cold so I am off to buy a car battery (several in fact) and use them to supply power to not just the trains but the whole house. The resulting explosion may stop the rain and will certainly make things warmer.
Marklin are now including a car battery in their catalogue with smaller ones as boosters. You can of course still buy the usual transformer/power supply etc which they recommend but heck why not live dangerously (and give up our warranties)
dave
Edited by user 30 October 2010 19:59:31(UTC)  | Reason: Not specified
#17 Posted : 30 October 2010 18:08:46(UTC)
TongueTongueTongue
This page was generated in 0.575 seconds.
