Online Nigel Packer
#1 Posted : 07 September 2009 13:39:51(UTC)
Nigel Packer
The existing "Known issues" topic seems to have dried up, so I thought I would create a new one for the 60214. As it happens, so far I have only one issue (the 60214 is a superb device), but it's an issue that has been in the CS2 since day one, and is in every software version so far.
Hardware version: 3.4
Software version: 1.2.5(1) TFP version: 1.23
Issue 1: Support for K-track 2275 double slips is incorrect. I will try and explain:
The 2275 double slip uses two point motors, so there are four possible positions for the switch blades. Physically, in order to change, for example, from the left-curve setting to the right-curve setting, both point motors must change position. However, using the keyboard of the CS2, when changing from left-curve to right-curve only one of the point motors is switched. Therefore, whatever way the k83 decoders and the point motors are connected, it is not possible for the CS2 keyboard screen and the physical position of the 2275 to match.
I have reported this problem several times, both here in this forum and directly to Märklin, starting as soon as the first version of the CS2 was shipped, but it hasn't been fixed yet. I can't believe I am the only customer to have noticed this!
Well, that's my short list of issues - any one else have any?
Nigel
PS The 2275 issue is still not fixed in software update 1.2.5(1).
#2 Posted : 16 September 2009 12:09:36(UTC)
I am trying to understanding which bit you think is wrong. Could you please comment if I am working with the same situation as you
With reference to the following, I presume that the correct double slip ICON has been selected and that you have a defined area on the keyboard that looks the same and is able to switch to each of the 4 aspects shown
In my case I am using address 13 and 14
UserPostedImage NW-SW orientation : pressing button causes 14 Red 13 Red
UserPostedImage NE-SW orientation : pressing button causes 14 Green 13 Green
UserPostedImage NW-SE orientation : pressing button causes 13 Red 14 Green
UserPostedImage NE-SE orientation : pressing button causes 13 Green 14 Red
Thus, There are 4 different states (pairs of commands) sent by the CS2.
Is the problem that the ICONs don't match ( but you can get all 4 states) ??
Using your Scenario switching from left curve (I call NWSW) to right curve (my NESE) I can see that , as you state only one solenoid state changes.
Presumably, if NWSW is set up correctly to match the physical turnout then selecting the (wrong) NESW aspect icon (bottom left) on the CS2 will achieve the desired physical state (because it changes both solenoids). Is this correct ?
Online Nigel Packer
#3 Posted : 16 September 2009 18:37:33(UTC)
Nigel Packer
Using your Scenario switching from left curve (I call NWSW) to right curve (my NESE) I can see that, as you state, only one solenoid state changes.
Yes, that's correct (but incorrect!).
All four states can be selected, but it's rather counter-intuitive since the icons can never match the physical setting of the turnout for all of the states.
I did consider un-zipping the update files and swapping the icons around, but I decided that life was too short, and that anyway the icons are kind-of animated, and that it might be a bit more complicated than that.
It's just rather annoying that this has never been tested, and several reports of the problem have been ignored.
I'm sure it will be fixed one day!
Nigel
Offline Steamer01
#4 Posted : 16 September 2009 23:50:31(UTC)
Steamer01
[size=1" face="Verdana" id="quote]quote:Originally posted by Nigel Packer
<br />The existing "Known issues" topic seems to have dried up, so I thought I would create a new one for the 60214. As it happens, so far I have only one issue (the 60214 is a superb device), but it's an issue that has been in the CS2 since day one, and is in every software version so far.
Nigel
Hello, I'm new here in the forum but not new in the hobby of modeltrains. I startet in 1963.
I have discovered another problem in the CS 60213 and 60214.
When you are switching the routes (turnouts and signals) in the position automatic of the CS, then it will happen that at one moment some of the accessories won't switch. That is the moment that the CS is receiving information from the boosters and another CS about temperature etc. Of the whole route one, two or three articles won't switch and everytime it is another article. [B)] So it isn't the turnout.
You will only see this problem when you have many turnouts / signals. In my situation I have 30 trains on the track and 10 trains are running at the same time, so the CS is very busy.
CS3 60216 + 8 x 60174 + 1 x 60175
www.rensenmodelbaanwereld.com
Offline efel
#5 Posted : 17 September 2009 01:22:43(UTC)
efel
[size=1" face="Verdana" id="quote]quote:Originally posted by Steamer01
Welcome to the forum Steamer01.
What you describe sounds like a big bug!
How do you avoid collisions on your large layout?
Fred
BTW: Fine website
Offline Ranjit
#6 Posted : 17 September 2009 10:38:37(UTC)
Ranjit
Welcome to the forum, Steamer01!
Ranjit
#Get Vaccinated
Offline Steamer01
#7 Posted : 17 September 2009 11:12:23(UTC)
Steamer01
[size=1" face="Verdana" id="quote]quote:Originally posted by efel
Fred
BTW: Fine website
Thanks for your greetings.
It isn't always possible to avoid collisions. I have also informed Märklin about this problem. They are working on it.
The same problem will show up when you make a choice for a new locomotive in the long list with pictures (max 3kB). I have about 60 locomotives in the list all with pictures and when you choice another locomotive at the same time that the routes are switching, sometimes one, two or three articles won't switch. [B)].
This problem isn't new; it exist for many months. I have seen it with the 60213 and with the 60214 too. (when this is prgrammed as master).
Offline supermoee
#8 Posted : 17 September 2009 11:54:47(UTC)
supermoee
Hello Nigel,
this problem is know since appearing of 60213. In the Märklin FAQ you can read the workaround: install the double switch as 2 single switches.
This bug will be solved in future, but since there is a workaround it has low priority for the programmers.
kind regards
Stephan
Online Nigel Packer
#9 Posted : 17 September 2009 15:24:16(UTC)
Nigel Packer
[size=1" face="Verdana" id="quote]quote:Originally posted by supermoee
<br />Hello Nigel,
kind regards
Stephan
Thanks, Stephan. I hadn't seen that in the FAQ (it's in German). I had already used that workaround myself, but I keep hoping that the problem will be fixed as it seems such a small change!
Best wishes,
Nigel
Offline Steamer01
#10 Posted : 17 September 2009 21:24:41(UTC)
Steamer01
There is a new issue with the CS 60213 / 60214.
Since the latest update the synchronization-function has disappeared. I talk about the 2nd CS2 in the processing mode.
It has worked (with some problems) before the new update was implemented.
Steamer01
Offline Steamer01
#11 Posted : 18 September 2009 00:13:17(UTC)
Steamer01
The next issue about the CS2 60213/60214:
When you have installed the newest update version in both the 60213 and the 60214 and you have programmed one of the CS's as a 2nd controller, you will see after a new start that all of the S-88 symbols in the lay-out are yellow. So you have to switch to manual operation in the settings of the routes. This is only in the 2nd. CS that the symbols are all yellow in all the lay-outs. It doesn't matter; than the first CS can be programmed for automatic operation, but it is also not normal. (CS 60213 connected by terminal to the 60214). [B)]
Steamer01
#12 Posted : 18 September 2009 02:52:19(UTC)
<br />Hello Nigel,
Stephen,
I take issue with this,
a) It is not the Programmers the set priorities. It should be the user advocates but is generally marketing (with CFO input as leverage)
b) A workaround is still an issue that needs resolution
This could be fixed in 5 minutes followed by 1 or 2 hours (max) of regression testing (which is not done by programmer anyway).
Furthermore, any known issue should be documented in any release notes along with a targeted fix release - if not a date, along with a new feature list and a bug fix list. This allows people to track both the fact that a problem exists and when (and how) it is resolved, rather than occasional FAQs that may be stumbled across.
#13 Posted : 18 September 2009 03:01:19(UTC)
Issue 2: Busy/Distracted CS controller can miss switching some points of a route
... That is the moment that the CS is receiving information from the boosters and another CS about temperature etc. Of the whole route one, two or three articles won't switch and everytime it is another article. [B)] So it isn't the turnout.
Hi Steamer,
Can you please confirm if the ICON for the failed accessory change or if it, too, fails to be processed by the Controller
FWIW, When programming, separate commands are issued to turn on the pulse and then turn off the pulse. If the 2nd command is sent immediately (or too soon) after the 1st then the logic (and ICON) changes but there is no physical movement of the turnout.
i.e. external controller do not leverage the pulse duration timer that we set for each device (200mS)
I am guessing that commands get "queued up" when handling interrupts from the other functions you mention, and that they get flushed in a rush without adhering to the needed timers or because the timer was started before/during the interrupt and had already expired resulting a short but ineffectual pulse.
P.S. could you please record the levels both HW and SW of your unit(s)
Offline supermoee
#14 Posted : 18 September 2009 03:17:11(UTC)
supermoee
Hello Clapcott,
it is the project manager of the CS2 project who set's the priorities.
And it is not that easy as you describe it, believe me.wink
And I'm sure that this development list is existing for internal use. Since it probably contains, together with the bugs, future features to be integrated, it is not in the interest of Märklin to make it of public domain. The competitors would know in advance what Märklin will do and follow up two lists, one public, one secret, is a waste of time and money. Not good in a period of csysis.
And the competitros did not have a list. But this is not disturbing anyone.
rgds
Stephan
#15 Posted : 18 September 2009 03:19:28(UTC)
<br />Hello Clapcott,
rgds
Stephan
They have a Project Manager !!!!
No wonder nothing is getting resolved.
Offline supermoee
#16 Posted : 18 September 2009 03:22:50(UTC)
supermoee
even if they wouldn't I'm sure you would find something to complain about wink
rgds
Stephan
Offline davemr
#17 Posted : 18 September 2009 12:16:06(UTC)
davemr
Hi Peter They probably have an assistant project manager as well !!!
Maybe a new owner will get things done and clear out the managers.
CS2 is an excellent item which should be fully bug free by now.
davemr
Offline jeehring
#18 Posted : 18 September 2009 14:44:44(UTC)
jeehring
rgds
Stephan
Of course they have !
If you knew really who is he and what was his career, you didn't talk like that !
And last but not least , which is great above all : he was also a hobby train enthusiast.
In passing, he and his team are human beings...
#19 Posted : 18 September 2009 14:56:54(UTC)
Originally posted by jeehring
If you knew who is he and what is his profil you didn't talk like that !
In passing, he and his team are human beings...like you.
I think you need to take Peter's tongue in cheek comment as not being a personal comment about the actual individual, but just an observation about Project Managers in general.
We don't call them 'Project Manglers' here for nothing!
Edited by user 07 August 2010 02:29:18(UTC)  | Reason: Not specified
Offline davemr
#20 Posted : 18 September 2009 15:12:07(UTC)
davemr
Peter is the forum genius. If he says it is the Project Manager that causes the problem then that is what it is biggrinbiggrin
I think 99% of knew it was tongue in cheek as was mine re the assistant project manager. These guys are everywhere making sure things dont work the way they should[:I]
davemr
Offline jeehring
#21 Posted : 18 September 2009 15:13:46(UTC)
jeehring
<br />They have a Project Manager !!!!
[size=1" face="Verdana" id="quote]quote:Originally posted by jeehring
<br />If you knew who is he and what is his profil you didn't talk like that !
So...OK, let's fire all project managers and send them to employment agencies !.A great idea , don't you think so ?!The world doesn't need project managers
My opinion : stupid corporatist rivalries only .
#22 Posted : 18 September 2009 15:25:29(UTC)
As I said, it was a tongue in cheek comment, no need to take it so seriously!
#23 Posted : 18 September 2009 15:41:33(UTC)
So why then, does just about every other software development company (Microsoft being a prime example) include a bug fix list in their release notes for every software version they release?
And again, for future developments why do companies like Microsoft issue details of what features are in upcoming versions of software. I've just been to the Microsoft TechEd Conference, and MS were presenting features of Windows Server 2008 R2, Office 2010 and Exchange 2010, all of which have not yet been released for general availability.
What is so special about Marklin that they cannot signal new features/fixes like any other software company?
Offline Hoffmann
#24 Posted : 18 September 2009 16:10:34(UTC)
Hoffmann
Hello Bigdaddy,
According to you Marklin should have Microsoft write the Software for the CS2wink.
That way we will get Bug-Fixes every week for the next 10 Years.
Microsoft is still sending me UPDATES for Windows XPbiggrin.
At least with the Marklin CS2 you do not get " A FATAL ERROR HAS SHUT DOWN YOUR COMPUTER WOULD YOU LIKE MICROSOFT TO LOOK INTO THAT PROBLEM [B)]".
To come to the point most CS2 users have (after the now available updates) no Problems what so ever in using it and I am sure that the few Problems (which are here posted) will be sorted out.
Martin
marklin-eh
Offline jeehring
#25 Posted : 18 September 2009 16:42:42(UTC)
jeehring
<br />So why then, does just about every other software development company (Microsoft being a prime example) include a bug fix list in their release notes for every software version they release?
Digital-for-trains market with PC markets ?
niche market with massmarket ?
"almost monopolistic" situation doesn't lead to similar strategies...
Offline Steamer01
#26 Posted : 18 September 2009 18:26:46(UTC)
Steamer01
Hi, all of you.
I don't expect that you give several solutions for the software-items. I only give a feed back of what I have discovered with the 60213 combined with the 60214. The problems I mentioned have nothing to do with the latest update. Everytime when an update comes, the CS 60213 / 60214 will work finer. But there are some problems that we have to mention. I report all the software-experiences to Märklin (in German), so the can work on it. Not everyone has such a big lay-out as I have (with 8 boosters that have to give feed-back to the CS and also a 2nd CS).
I haven't done all the experiences. I am still finding out some things and yesterday evening I found out that when you have the first CS (60213) only in use for the lay-out and the second CS (60214) in use as a controller, that the problems of non-switching routes during the search to another locomotive (in the long list of about 60 locs) dont't appear. The experience was only with six trains on the track and I haven't figured out yet what will happen with 30 trains on the track that drive automatically. (I have that possibility). I need more time for that.
But it is still necessary that the software will be developped to an higher level. I am glad with my two CS's, but Märklin is happy with some feed-back about large and complex lay-outs. So we can help each other.
I wonder if one of you has the same experiences with two CS's (or more) connected together with the sometimes non-switching signals / turnouts when the many boosters are giving feed-back about temperature / current and when you are choosing another loc out of a long list and if you have seen that the possibility of synchronisation has disappeared since the latest update? Cool
(hw 60213 = 3.1 and 60214 = 3.4; sw both 1.2.5 - 1).
Steamer01.
Offline davemr
#27 Posted : 18 September 2009 19:23:31(UTC)
davemr
Problem with the CS updates I would say why are they necessary.
Take for example the alphabet problem. If you wanted a 'm' you had to press the 'n' key and then you got a capital M.
The units were put out for sale I presume with this being known (or did nobody look at it and make a few tests)
If obvious errors were put right then there would only be the odd obscure bug to be corrected. This is after all a toy train controller which costs more than a lap top computer. Before all the zealots come on let me say again that it is an excellent product which could have been even better if obvious faults were put right before being sold to the public.
Roll on the new owners and a new dawn for Marklin.
davemr
#28 Posted : 18 September 2009 19:34:28(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by davemr
<br />If you wanted a 'm' you had to press the 'n' key and then you got a capital M.
biggrinbiggrinbiggrinbiggrinbiggrinbiggrinbiggrinbiggrinbiggrinbiggrinbiggrinbiggrin
Offline Steamer01
#29 Posted : 18 September 2009 19:41:23(UTC)
Steamer01
<br />Problem with the CS updates I would say why are they necessary.
The CS is a very complex computer. So it isn't possible to have a traincontroller with so much capacity that will be perfect from the first moment. Every modelrailroad needs other solutions.
During the development of the CS there were troubles as you know. The CS had to be developped in a very short time and nowadays it is the traincontroller with the best opportunities.
Windows too has many bugs, but it works fine though. Software is never ready for the long future. There will always be the necessary of further updates.
Steamer01
Offline Steamer01
#30 Posted : 18 September 2009 23:33:15(UTC)
Steamer01
I report all the software-experiences to Märklin (in German), so they can work on it.
The best thing that many customers can and also will do; myself included. As said before and now by you again, Märklin is happy to get qualified feedback; needless to say they also work on it seriously.
Thousand times better than waste of forum space for junk discussions about project managers, etc.
[size=1" face="Verdana" id="quote]quote:But it is still necessary that the software will be developed to a higher level. I am glad with my two CS's, but Märklin is happy with some feed-back about large and complex lay-outs. So we can help each other.
That's the right way to go. wink
[size=1" face="Verdana" id="quote]quote:if you have seen that the possibility of synchronization has disappeared since the latest update?
Yes. The sync buttons are currently not included in this version. It might happen that they're re-established with the USB version or postponed until the next update.
Thanks for the reaction mr. Hemmerich, so that are two of us that think in the same direction. biggrin
Steamer01
Offline davemr
#31 Posted : 18 September 2009 23:46:53(UTC)
davemr
Hi Find it interesting that the CS2 is a complex computer. I spent several years with complex computers and toy trains and complex computers just dont quite come in the same sentence but perhaps those who build computers would have a better idea as I only use them.
My CS2 runs the trains and switches some turnouts and signals etc and is great. It even has a door that closed when it switches off .. computers have come a long way lol.
Why doesnt Marklin give Peter (Clapcott) a CS2 before it is released and ask him to test it. I am sure he would soon come up with problems which should be sorted before the unit is sold.
It is a while back now that when on two rail I used the Lenz system and while in those days it would not do as much everything worked as did the Roco locomouse (originally made by Lenz)
Anyway this is Nigels thread and hopefully he will have his problem solved.
Funny how these threads develop when people make excuses for Marklin, why not just say we have a problem which shouldnt be there and hopefully they will get it put right quickly.
davemr
#32 Posted : 19 September 2009 00:02:06(UTC)
To me, it looks like a software threading priority problem regarding Steamer01:s issue... Operation critical processes should always have priority over "administrative" tasks in a unit that is supposed to control timing-critical tasks...
In an operational scenario, you rely on the control unit to be as failsafe as possible and accept some delay in GUI updates or other non-critical stuff...
If it is like Peter suspects, which is also a credible scenario, there is a simple software bug sending commands to the track without the necessary minimum solenoid switching delay between the commands...
I can't see why eg reporting a boosters temperature should be as "important" as operation control to the degree where it endangers operation reliability...
Offline Steamer01
#33 Posted : 03 October 2010 19:10:30(UTC)
Steamer01
Now, with the new update 1.4.0.(1) GFP 1.28 the CS2 seems to work better in the coöperation with routes. There was a big problem that some routes were not switching all the time, but now it goes better. Only when a mfx loc is registrating it self, there are some problems sometimes with some routes that are not switching for the complete serie. This problem still remains for when you are looking for another loc in the list.
But it is better than for the last 2 years.BigGrin
How are your experiences?
Greetings
Steamer01
Edited by user 04 October 2010 10:18:20(UTC)  | Reason: Not specified
Offline Hemmerich
#34 Posted : 04 October 2010 23:22:43(UTC)
Hemmerich
Edited by user 19 November 2010 01:26:51(UTC)  | Reason: Not specified
#35 Posted : 05 October 2010 02:47:00(UTC)
Hemmerich wrote:
Hi Riekus, you got a reply on your e-mail. Wink
ANd here we have another secret answer to a question.Angry Cursing
Lutz, Share is the operative word. be a good true strong forum member for a change. ThumbDown
Offline Steamer01
#36 Posted : 06 October 2010 00:58:20(UTC)
Steamer01
Thanks for an answer. I have tried it out. This evening I had 24 trains running on the track and there were no failures with the switching of routes. But as soon as you are searching on the CS2 for another train on the controller, than there were two signals that didn't switch from red to green.
As told, when you do nothing but automatic driving, everything seems to work properly now. But Märklin still has to work on the rest of the problem.
Steamer01
Offline dntower85
#37 Posted : 06 October 2010 01:18:49(UTC)
dntower85
24 trains running is great even if it does tax the system, how may routs do you have operating at one time?
DT
Offline Steamer01
#38 Posted : 06 October 2010 10:23:50(UTC)
Steamer01
There are much more than a hundred of signals and switches. At the same time there are about 8 routs that are operating and I can see that one route is not first finished before the other rout is going. All routs are switching in mixed mode.
The maximum on my tracks are 30 trains that are running together.
There are more than 40 routs, but only 8 can switch together.
Steamer01
Offline Nielsenr
#39 Posted : 07 October 2010 01:40:32(UTC)
Nielsenr
I am a new member as of today ... I run some blocks and alternating trains in a station. My only experience has been after an emergency shutdown where some 76XXX signals fail to operate. Sometimes I can manually force them into working, but usually the best way to fix it is to do a reboot of the CS2.
To Steamer01 and others using routing ... have you thought about starting a new post explaining how you use routes?? Most of what I have learned has come from the "Controlling Switching Running" book, No 07421, and "The HO Signal Book", No 03402. These books cover the basics but I would like to learn more of the routing capabilities. Seeing what others are doing and how they did it will often give me greater insight to how things are working and give me ideas on how to do more with routes. I am sure there are others who could learn from what you are already doing and incorporate more routing into their layouts.
Thanks!!
Robert
Offline GSRR
#40 Posted : 07 October 2010 02:50:16(UTC)
GSRR
Steamer01
Can you describe what you are using for feedback? Your K83, K84, and S88 are these Marklin using track power, or LDT / Viessmann using independent power source?
Of the 25+ trains you are running at a time, how many are MFX?
Do you use any PC control software?
r/Thomas
Offline Steamer01
#41 Posted : 07 October 2010 13:32:14(UTC)
Steamer01
Steamer01
I don't use PC control software. Only two CS2's. I use S88 decoders from Märklin and Viessmann and the K84 decoders are Viessmann (1 Märklin) en de K83 signal-decoders are from Viessmann with seperate power supply. All the tracks are powered by mfx boosters (Märklin) and the CS 60214 is only in use for the digital output that goes to the boosters and the signals / switches. The second CS2 (60213) is used as a controller and for the lay-out.
Steamer01
r/Thomas
Offline Steamer01
#42 Posted : 09 October 2010 16:17:39(UTC)
Steamer01
Steamer01
Today, 9 Oktober 2010, I did the same but now with 29 trains and almost everything went good. One of the trains was a shuttle. I tried it out for half an hour but than I should not use the controller (CS2) for otherwise there will be some problems. During the 30 minutes everything was going fine only the shuttle went in a wrong direction for one time and one signal didn't switch to green.
Steamer01
Offline GSRR
#43 Posted : 09 October 2010 23:47:58(UTC)
GSRR
Steamer01
Well that is some good news in part. What is the intermix of Loc decoders, is it all MFX or some Delta, FX, MFX?
Offline Steamer01
#44 Posted : 10 October 2010 19:12:14(UTC)
Steamer01
I use mfx and fx loco's together. There are more than 60 loco's and some other functiondecoders in wagons / cranes, .....
Steamer01
This page was generated in 1.935 seconds.
