Offline I_love_Marklin_37538
#1 Posted : 30 August 2010 06:08:23(UTC)
Ok
I was browsing on Trade Me looking at European Locos until I came across a Fleischmann loco,can they be compatible with MFX and sound decoders?
http://www.trademe.co.nz...es/auction-312989907.htm
I am still thinking if its worth buying
Offline kariosls37
#2 Posted : 30 August 2010 07:50:41(UTC)
kariosls37
Do you realise you are looking at an analogue loco? it says in the description.
So the quick answer will be no. you will have to wire in a MFX decoder yourself.
#3 Posted : 30 August 2010 10:26:58(UTC)
Some Fleischmann locos have a 6-pin NEM socket, some have an 8-pin NEM socket - some have an electronic reversing unit soldered in.
I can't say anything about the BR 50 in question.
It seems that Fleischmann put lots of locos in stock which were dumped into the market recently. You'll find analog locos, MM only locos (some even without load regulation and Uhlenbrock decoders), and MM/DCC locos with current ESU decoders.
They used to make a BR 50 in 1:85 (IIRC) - and I don't know which scale this model has.
Fleischmann steamers have a powered tender (the BR 50 has 2 driven axles) and normally are not prepared for smoke generators.
The Fleischmann steamers I have look very nice, but some are weak pullers.
#4 Posted : 30 August 2010 12:00:21(UTC)
It is silver wheels, It must be around 20 years old.
#5 Posted : 30 August 2010 14:50:54(UTC)
It is a Fleischmann 1179, and according to the following webpage is 1:87 scale, is AC only with an electronic reverse unit, and has no decoder or decoder interface. Motor is in the tender, with 4 wheels driven.
http://www.modellbahn-fo...3-1-0-0-1-0-0/index.html
#6 Posted : 30 August 2010 15:31:45(UTC)
Date of production from 1987 until around 2003.
#7 Posted : 30 August 2010 18:42:13(UTC)
They say it's "Spur: H0 1:87" ("Spur" means "gauge").
The "Adler" (which is 1:80) is also shown as "1:87", so this doesn't mean a thing.
http://www.modellbahn-fo...0-0-1-0-adler/index.html
Here's a thread (German) that says it's 1:85 (see post by ccs800):
http://www.nexusboard.ne...p/2408/br-50-ac-t299877/
ccs800 says it looks too big if placed beside a Märklin BR 50.
#8 Posted : 31 August 2010 00:45:04(UTC)
The lok is 1:85, the tender is 1:87! Not sure how that would make it look, but it can't be pretty!
This page was generated in 0.518 seconds.
