#1 Posted : 22 August 2010 18:43:26(UTC)
Some of my locos have different logos on their housing.
Example: Roco Re 6/6 = one side SBB - CFF - other side SBB - FFS
Märklin Ae 6/6 = SBB - CFF both sides
Märklin Ae 6/6 = SBB - FFS both sides
Why is this ?
Offline Unholz
#2 Posted : 22 August 2010 19:40:30(UTC)
Unholz
Probably because it is prototypical... Wink
SBB is the German abbreviation of the Swiss Federal Railways, CFF the French, and FFS the Italian version. In earlier days, most locomotives (and other vehicles) had SBB CFF on one side and SBB FFS on the other. However, some locos (mainly Ae 6/6) had SBB FFS on both sides because they were mostly used on the Gotthard line and thus mostly seen in action by German and Italian speaking engine crews and onlookers. Others which ran in Western Switzerland had SBB CFF on both sides.
Here is a rather recent list of the state of the Ae 6/6 fleet (in service or not, with or without coat-of-arms, green/red/Cargo livery, etc.):
http://www.bahnforum.org/dany/ae66/alterstand.html
#3 Posted : 23 August 2010 01:51:30(UTC)
Stephan,
Thank you for this explanation of the differences. I remember my 3050 had SBB CFF on one side and SBB FFS on the other. My 3638 (same prototype) had SBB CFF on both sides. I was not sure whether the 3050 was prototypical. The 3638 had the same inscriptions as when I saw the lok in person. Was the choice of inscription solely based on where the lok was stationed, or on in which part of Switzerland the chosen Canton (crest) was from?
I remember seeing a photo of at least one train where the modern logo was also in a different order than <+> SBB CFF FFS. I think it had CFF SBB FFS and the train was red. I don't remember if it was a regular unit or maybe on the Geneva - La Plaine line.
Offline TimR
#4 Posted : 23 August 2010 04:18:09(UTC)
TimR
Indonesia
That is another new thing that I learn from the forum today. ThumpUp
Now collecting C-Sine models.
#5 Posted : 23 August 2010 04:52:52(UTC)
Fascinating- thanks Stefan!
Offline mascagni
#6 Posted : 23 August 2010 16:07:17(UTC)
mascagni
Hi: It seems that the Swiss Federal Railways is very sensitive to the languages spoken in the areas that their trains operate. The example above is a good one dealing with the labels on the locomotives themselves.
In another thread: https://www.marklin-user...aspx?g=posts&t=16707 there is a video of the new ICN model from Roco which allows you to hear the various announcements programmed into the Loksound sound module. The announcements are multilingual, and the actual languages used in them are a function of where they are given. If you take the ICN from St. Gallen to Geneve Aeroport (the full W-E run), the station announcements are in German-French-English, and then the turn to French-German-English as one passes Biel/Bienne which is essentially the marker for the linguistic frontier.
I have never taken a train from Zürich to Milano, but I assume that when one crosses that linguistic frontier (in a tunnel connecting Canton Uri with Cantone Ticino), that the same thing occurs. The big difference is that Italian may not be used in Zürich at all and only appear when it is clear that the train is entering the Italian speaking area.-MM
Michael Mascagni, Tallahassee
#7 Posted : 23 August 2010 20:42:58(UTC)
As far as the north-south divide. I clearly recall hearing German and Italian Announcements for trains via the Gotthard in Luzern and Arth-Goldau. Trains from Luzern in direction of Bern had announcements in German and French (SBB).
I imagine that announcements in Lugano and Bellinzona (for example) have announcements in Italian first and in German second. There was a Website with Swiss train photos which added a section for sounds a few years back. I don't remember the name and the link is somewhere in the favorites list on my old (defective) hard drive. If I ever find it again, I will post it. In the interim, there is a nice selection of Swiss announcements on www.durchzug.info
Offline Unholz
#8 Posted : 23 August 2010 23:03:54(UTC)
Unholz
Mike, you are probably right about the individual crests also having influence on the choice of CFF and/or FFS. Some more research on this topic may be necessary, and from a short check I also gather that changes might have occurred during the 50 years lifespan of some Ae 6/6's.
And yes also to the CFF + SBB variant which was used on the two (green) BDe 4/4 + (A)Bt units 1301/1302 + 1801/1802 which exclusively operated on the short and "French speaking" DC line between Geneva and La Plaine.
The whole topic shows that we have a certain "language sensitivity" in Switzerland which should ensure that the linguistic minorities also are adequately represented on the federal rolling stock.
Offline Hemmerich
#9 Posted : 23 August 2010 23:22:09(UTC)
Hemmerich
deleted
Edited by user 27 August 2010 18:38:08(UTC)  | Reason: Not specified
#10 Posted : 23 August 2010 23:39:32(UTC)
Hemmerich wrote:
mascagni wrote:
... hear the various announcements programmed into the Loksound sound module.
Which "Loksound sound module"??? Wink
Guess what they announce in this train: Tilo Smile
As usual, this poster makes some unhelpful comment where a simple reminder (correction) that the (ICN) model that Mr Mascagni refers to is actually equipped with a Zimo decoder would have sufficed.
As far as the Tilo train, I guess that the announcements are primarily in Italian, unless of course it is one of the Tilo trainsets being used in another part of Switzerland, in which case, this would already have been covered in the discussion above.
Offline Hemmerich
#11 Posted : 24 August 2010 01:31:44(UTC)
Hemmerich
deleted
Edited by user 27 August 2010 17:29:10(UTC)  | Reason: Not specified
#12 Posted : 24 August 2010 01:45:48(UTC)
QUick , where can I get a Flak Jacket and tin hat as war has broken out again. Stuffing up another thread Cursing and who is making personal attacks to who?
Game Score:
Canada 1 germany 0 ThumpUp
#13 Posted : 24 August 2010 01:54:00(UTC)
Hemmerich wrote:
My question was intended to determine the cause for (t)his statement. It looked -not for the first time- like some incorrect or misleading information was published and Mr. Mascagni just picked that up "inadvertadly". Love
BTW: If mike c knew it so well, why didn't he correct him right away on his first response? But instead and as usual, he starts again one of his totally unneccessary personal attacks! Angry
mike c wrote:
... unless of course it is one of the Tilo trainsets being used in another part of Switzerland,
Is the destination sign of THAT train so badly readable? Laugh
If you would check the original thread about the ICN, you will find that I corrected the posting where I originally referred to the sound decoder as being from ESU. Living in North America, we are often the last to get details about coming models. The original information that I had was that Roco was using OEM ESU decoders. For some reason, Roco has decided to use Zimo decoders in some models. I do not know if this means that they are no longer working with ESU or whether this only applies to some models and the ESU cooperation will resume in the future.
I was referring to the language of the announcement and not to the destination sign on the train itself. If the photo was taken in Luino, the announcement probably would have been for Bellinzona, even though the sign still said Luino.
For those who are not familiar with Swiss geography, Luino is an Italian town on the south of Lago Maggiore. The line was built from Bellinzona to Luino to facilitate traffic to Torino and Genoa. At one point, it was considered as the possible southern point of the Gotthard route, but the SBB and FS decided that Chiasso/Como would be preferred, as it was on the line to Milano and further south.
Please post all comments regarding the ICN in the appropriate thread, which has not yet been blocked. This thread is about the inscriptions (markings) on SBB loks.
#14 Posted : 24 August 2010 03:20:16(UTC)
I don't know whether this is the appropriate thread or whether there may already be a thread about SBB EWI (EW-I) coaches, but I found this list of SBB Einheitswagen coach models:
http://gamos81.altervist...ro/Carrozze/SBB/EW-I.htm
The only missing information is that for Hag models, which can be found via Stefan Unholz' Hag UNUM database.
Offline mascagni
#15 Posted : 24 August 2010 15:27:27(UTC)
mascagni
My apologies to all for having assumed the ICN had a Loksound decoder. I stand corrected, but my apology is mainly for the chatter that it spawned.
Enjoy your trains, both model and real.
Be good, do good work, and keep in touch.--MM
Offline Hemmerich
#16 Posted : 25 August 2010 05:32:18(UTC)
Hemmerich
Edited by user 19 November 2010 01:54:27(UTC)  | Reason: Not specified
#17 Posted : 25 August 2010 07:27:31(UTC)
Hemmerich wrote:
.....is another shameful behaviour.
Lutz, Juhan and the Moderators will be the sole judges of good and bad behaviour in the forum, and we do not need your help. Please desist from deliberate provocative statements like this one. Do it again, and you will be taking (another) enforced holiday.
Addition by Webmaster - some of the off-topic comments by a couple of other members later in this topic are not good either, please refrain from personal comments about other members.
Thanks for your edits Juhan. I was out for most of tonight, so did not see some of the extra comments until late. As always, it is best to use the forum report function to report troublesome posts, rather than clogging threads up with it. Cheers. /Bigdaddynz
Edited by user 26 August 2010 05:47:17(UTC)  | Reason: Not specified
Offline TimR
#18 Posted : 25 August 2010 07:34:01(UTC)
TimR
Indonesia
Apparently questioning the meaning of your highness' post can now defined as "personal attack".
Hemmerich wrote:
There is (not just to me) not any reason for Michael to apologize about referring to information that he apparently picked up from a false statement which had been spread by somebody else without real knowledge. The fact that this person didn't correct him right away, but attacked me instead is another shameful behaviour.
Wow!
Those were some very strong opinions posted against a fellow member in just one paragraph.
There is no reason for Michael to apologize,
I know of one person that should have apologized for wrecking yet another informative thread, and I also know of one shameful behaviour, er no, make it shameless, being repeated over and over in every SBB threads in the past 18 months.
Maybe it's time to defect to 2-rail to avoid this ruckuss.
#19 Posted : 25 August 2010 07:58:59(UTC)
make it a big one while you are at it. Cursing Cursing
ANd maybe his "Signature" should be changed from :
This posting might be subject to change or removal at any time.
to
This member might be subject to (Tempory) removal at any time. ThumpUp ThumpUp
#20 Posted : 25 August 2010 08:04:32(UTC)
Tim,
I presume that you are referring to Lutzie moving to 2 rail??
#21 Posted : 25 August 2010 13:52:13(UTC)
nevw wrote:
Tim,
Shares in Hornby have just fallen BigGrin BigGrin
I an still finding parts of this thread interesting and informative so hopefully the good posts can keep going.
dave
Offline Macfire
#22 Posted : 25 August 2010 14:10:10(UTC)
Macfire
Hemmerich wrote:
Blah blah
Ad Nauseam
Hemmerich wrote:
Blah blah blah
Ad Nauseam
Hemmerich wrote:
Blah blah blah blah
Ad Nauseam
Hemmerich wrote:
Blah blah blah blah blah
Ad Nauseam......
Lutz.....
Oh forget it.............
You are just not worth the effort Cursing Cursing
Lord Macca
Offline Macfire
#23 Posted : 25 August 2010 14:11:49(UTC)
Macfire
I quite agree Tim.
Thanks guys for an interesting topic ThumpUp ThumpUp ThumpUp
Lord Macca
Offline Jeremy Palmer
#24 Posted : 25 August 2010 15:05:30(UTC)
Jeremy Palmer
Barbados
David Dewar wrote:
nevw wrote:
Tim,
LMAOLOL LOL LOL.
Good one David.
Jeremy.
Offline Unholz
#25 Posted : 25 August 2010 16:09:01(UTC)
Unholz
In an attempt to get back to somewhere near the original question Wink :
This is a (not so good) picture of the railcar mentioned by Mike with "reversed sequence" CFF + SBB because French is the standard language on the line where this vehicle was used:
http://www.flickr.com/ph...annes-j-smit/4083542712/
Offline mascagni
#26 Posted : 25 August 2010 17:03:22(UTC)
mascagni
Thank's Stefan for returning to the original topic.
I also point out that in Cantone Grigioni, where the RhB runs, the announcements are handled in much the same way. There, the main languages are German, Italian, and Romansh, and depending where you go, the signs in the stations and the announcements in the trains have different linguistic precedence. In addition, the trains have the name of the RhB in all three languages somewhere on them: German: Rhätische Bahn, Italian: Ferrovia Retica, Romansh: Viafier Retica.
Ciao.--MM
#27 Posted : 25 August 2010 20:40:38(UTC)
I think I remember some photos at www.polier.ch under P. Sutter.
Was the RAe 4/8 1022 or 1023 also at some point having the CFF before the SBB and FFS?
Edited by user 26 August 2010 04:44:54(UTC)  | Reason: Not specified
Online H0
#28 Posted : 25 August 2010 22:05:25(UTC)
Hemmerich wrote:
there are even discussions about Uhlenbrock being one of their suppliers now.
I have one Roco loco that had an Uhlenbrock decoder ex works.
Hemmerich wrote:
and since we're here in the HO forum
This is the H0 forum, not the HO forum (after the detailled EC vs. IC discussions I think this is worth to be mentioned).
Four months left 'til "Ho ho ho" ...
Offline Hemmerich
#29 Posted : 26 August 2010 03:57:42(UTC)
Hemmerich
deleted
Edited by user 27 August 2010 18:39:46(UTC)  | Reason: Not specified
#30 Posted : 26 August 2010 04:50:29(UTC)
Lutz, the topic was about the inscriptions on locomotives and perhaps also rolling stock. The fact that the French and Italian websites of the railway do not include the other letters in the corporate name is not really related to the discussion.
The modern trainsets of the Geneva - La Plaine line are currently labelled with the <+> symbol and the letters CFF, without any mention of the SBB or FFS.
... and now that the topic is back on the original topic, can we please keep it there...
Webmaster comment - Thank you Mike for getting it back on track.
Earlier non-topic posts in this topic will not be deleted - They will serve as examples of how things can go wrong
if you mix up the view of a person regarding models and a personal view of the poster.
Edited by moderator 26 August 2010 22:01:15(UTC)  | Reason: Not specified
Offline Hemmerich
#31 Posted : 27 August 2010 20:43:30(UTC)
Hemmerich
Edited by user 19 November 2010 01:55:14(UTC)  | Reason: Not specified
#32 Posted : 28 August 2010 01:40:31(UTC)
No Lutz, I was referring to this one:
http://www.railfaneurope...50/CFF_Bem_550_004-6.jpg
http://swissrail.fotopic.net/p54580480.html
It is possible that one or more trainsets have received the full <+> SBB CFF FFS logo since the last time I was in Geneva (2004). The last photo linked here was 2008 and bahnbilder.de shows photos in the RER livery as recently as Summer 2009.
Offline Hemmerich
#33 Posted : 31 August 2010 22:34:55(UTC)
Hemmerich
Edited by user 19 November 2010 01:55:53(UTC)  | Reason: Not specified
Offline Macfire
#34 Posted : 01 September 2010 01:46:10(UTC)
Macfire
Hemmerich wrote:
deleted
Lord Macca
Offline Macfire
#35 Posted : 01 September 2010 01:51:35(UTC)
Macfire
Hemmerich wrote:
That much for "currently" LOL LOL LOL
Not any more!
Lord Macca
Offline pserup
#36 Posted : 06 September 2010 09:14:54(UTC)
pserup
#37 Posted : 06 September 2010 11:18:58(UTC)
pserup wrote:
AGAIN
#38 Posted : 27 September 2010 14:50:04(UTC)
To all,
I'm pleased my topic has aroused many answers.
Another observation has made its mark.
SBB-CFF-FFS Ae 8/14 (Big scale)
by GSRR 22/11/2010 06:19:36(UTC)
This page was generated in 1.118 seconds.
