#1 Posted : 03 August 2010 20:29:18(UTC)
Suter-Meggen is announcing that the 6 coach IC "Riviera dei Fiori" SBB/FS Set is in stock today. The set recreates one of the better known IC trains between Switzerland and Italy in the late 1990s and early 2000s. The appropriate lok for this consist would be a Re 460 (37460) or one or two Re 4/4II (37356/etc) loks. It would also have been normal to see this train behind a Re 6/6 (from 37320) prior to 2000. For the Italian section, the train would have been pulled by a modernized E444 or by a veteran E646. The coaches are 1/100 in scale (26.4cm). After 2004, this train was operated under the Cisalpino banner and coaches like the ones in the 26544 Set were used instead of the SBB EC coaches. In some consists, the SBB WR (Restaurant) was replaced by a FS XMPR one. Unfortunately, Maerklin does not make a model of such a restaurant coach.
http://www.railfaneurope...sc/IC_Riv_dei_Fiori1.jpg
http://www.railfaneurope...90_111-9__Chiasso-02.jpg
#2 Posted : 03 August 2010 21:48:16(UTC)
there goes the wallet! Won't be ordered from Suter though- still haven't got the fake crocodile caper resolved Crying
#3 Posted : 05 August 2010 07:18:10(UTC)
I already have this consist in 1/87 using Roco coaches, including the option of replacing the SBB Restaurant coach with the Italian one. I also have a 4367 Set where I have replaced the Restaurant coach with a 42173 model. Most frequently, I have broken this set up and used a few coaches including the WRm, the Panorama Apm and a regular Apm to reproduce the EC Transalpin with the OBB coaches from the 42725 Set. The remaining coaches from the set I am using alongside the Apm from the 25544 Cisalpino Set and a 42163 to recreate a typical Gotthard IC (eg Basel to Locarno).
The only reason that I would consider the new set is the destination signs, which are not easily visible at layout distance. As I already have quite a few SBB EC Coaches in 1:100, I may pass on this unless it is on sale.
Here is a link to a thread containing photos of the consists I mentioned (scan down the page):
https://www.marklin-user...aspx?g=posts&t=14983
Offline Hemmerich
#4 Posted : 13 August 2010 02:45:42(UTC)
Hemmerich
There is no IC "Riviera dei Fiori" SBB/FS Set from Märklin. Märklin announced and delivered the set #43670 as Ep.V "Eurocity Express Train Passenger Car Set"; exclusive consisting of SBB coaches. Only combining coaches from two sets allows it to be run as the corresponding IC (Apm, Apm Pano, 6xBpm) at some time.
#5 Posted : 13 August 2010 07:22:04(UTC)
From www.maerklin.de (translated)
Highlights:
(Train Name) Zugname "Riviera dei Fiori".
(Route) Zuglauf "Nice-Ventimiglia-Genova PP-Milano C-Como-Chiasso-Lugano-Bellinzona-Arth-Goldau-Luzern-Olten-Basel SBB".
This is a Set of 6 Eurocity coaches of the SBB CFF FFS, as run as the IC "Riviera dei Fiori" between Basel and Nice/Nizza. I referred to it as a SBB/FS Set because the coaches can be pulled by either a SBB Re 460, Re 6/6 or Re 4/4II (solo or tandem) for the Swiss section and by a E645, E444 or similar FS lok for the Italian section. It is also possible that a SNCF lok is used to pull the lok from the Italian border station to Nice (Ville). This way, the model appeals to more than just Swiss modellers.
So, what exactly is your problem today?
Respectfully,
Offline Hemmerich
#6 Posted : 14 August 2010 19:35:10(UTC)
Hemmerich
www.maerklin.com/en (original) states:
"EuroCity Express Train Passenger Car Set.
H0 - Article-No. 43670 EuroCity Express Train Passenger Car Set.
Gauge: H0 Era: V
Prototype: 6 different Swiss Federal Railways (SBB/CFF/FFS) EuroCity express train passenger cars of different car types. 1 type Apm EuroCity open seating car, 1st class, 1 type Apm EuroCity panorama car, 1st class, 1 Mark IV type WRm dining car, 3 type Bpm EuroCity open seating car, 2nd class. Train name "Riviera dei Fiori". Train route Nice - Basle SBB. The cars look as they did about 2004.
Model: The cars have adjustable buffers. The cars are ready for installation of a current-conducting car connection, either the plug-in 7319 close coupling drawbar or the 72020/72021 close coupler that can be uncoupled. The dining car has a pantograph that can be used to supply power for lighting. Total Length over the buffers 161.0 cm / 63-3/8". DC wheel set for each car 4 x 700580.
Highlights:
* Train name "Riviera dei Fiori".
* Train route "Nice-Ventimiglia-Genoa PP-Milan C-Como-Chiasso-Lugano-Bellinzona-Arth-Goldau-Lucerne-Olten-Basle SBB".
One-time series."
Nothing was announced anywhere by Märklin regarding IC or FS coaches for this set.
#7 Posted : 14 August 2010 21:38:08(UTC)
Yes, that is what Maerklin printed in the Brochure and on the web site. Does that make it correct? No.
The train known as "Riviera dei Fiori" was long operated as an IC and not as an EC in Switzerland (IC 344/345). It ran from Milano Centrale to Ventimiglia and Nizza (Nice) as an EC (EC 159/160) on the FS and SNCF networks. At a later point in time (between 2005 and 2009, the train was operated as CIS EC 139/140 on the Basel - Milano route as part of the Cisalpino joint venture between the SBB and Trenitalia (FS).
See: http://www.reisezuege.ch...;znummer=345&fp_id=1
According to the operational agreements between the SBB and the FS, this consist was not always equipped with a Restaurant coach and was resultingly downgraded from an EC to an IC in the schedule.
As modelled by Maerklin, the set does include a SBB WRm and would thus technically qualify as an "EC". Irregardless of that fact, as I have stated, the train was still labelled an "IC" in Switzerland, hence my referral to it as such. If you have any problems with that, maybe you should take it up with the SBB.
http://www.railfaneurope...IC_Riviera_dei_Fiori.jpg
http://www.railfaneurope...ar/EC/panorama/basel.jpg
Any information provided regarding the addition of FS coaches to this set was purely in relation to prototype and does not change the composition of the set as offered by Maerklin. It may, however, be of interest to members who may wish to run this train as prototypically as possible.
Offline Hemmerich
#8 Posted : 14 August 2010 22:37:20(UTC)
Hemmerich
And even on the set box. BigGrin
YES!!! ThumpUp
Nothing new (at least not for me, others and surely as well not for Märklin). You just didn't get it yet - this set has been announced intentionally as Eurocity set and even indicating the coaches within the set description correctly as EC coaches. The fact that the train with this name was operated just as IC (operating times needed? Laugh) for known reasons doesn't change anything to Märklin's intend in their creation of a set similar to #4367 in order not just to have restricted use for this single train, but primarily for use of many other EC compositions running with these SBB coaches; as desired by any user.
Since I have -intentionally- two of those nice sets, I can easily compose a complete "Riviera dei Fiori" composition as it ran in the period designated by Märklin and thus most prototypically.
However, nothing will me or others restrict to use these sets or just some of its coaches for any other EC, SBB IR or even today's ICE substitution trains between Stuttgart and Zürich.
...as I have stated, the train was still labelled an "IC".
There was never any "IC" label on that train, not even on the model coaches. The only indication to an IC was provided by the train schedules.
"EC Riviera dei Fiori"
Märklin Apm-Bpm route label
If you have any problems with that, maybe you should take it up with Märklin. Flapper
#9 Posted : 15 August 2010 01:00:28(UTC)
I am getting a bit tired of editing/removing posts, so please be gentle towards eachother - Just state your own real life opinion/experiences of a model and put "personal issues" aside...
Goes for all us "old goats" and all other members too... /Webmaster
Gee, I'm glad I didn't get to moderate this thread! Thanks Juhan! /DB
Edited by moderator 20 August 2010 00:57:46(UTC)  | Reason: Not specified
#10 Posted : 15 August 2010 01:22:32(UTC)
My intent was to provide information about the availability of the Maerklin set as well as some information about the prototype that it was based on. The coaches are known as EC or Eurocity coaches as they were ordered with the intent of updating the SBB's fleet, specifically to replace the older 1960s and 1970s UIC coaches (UIC-X, UIC-Z Prototype) in the then newly introduced Eurocity services. Thus, any set containing these coaches could be referred to as a Eurocity Set, regardless of whether the destination signs said IR (Interregio), IC (Intercity) or EC (Eurocity).
Maerklin's correctness in terms of Swiss destination signs and decals is already well known in this forum. Their expertise in this area even extends to German coaches that pass through Switzerland. This can be seen on the destination signs of last year's Trix TEE Roland Set, which included a special route from Basel via Zuerich instead of the regular route to Luzern via Olten. Only the single coach with destination Chur made a stop in Zuerich. It can also be seen in the fantasy labelling of the RABe EC where the 1st class coaches disappeared completely from the trainset.
Thanks for the link to www.3rotaie.it. If you would have read my earlier post, you would have noted that the train was operated as an EC between Milano Centrale and Nice (Ville). The website that you mention clearly is most concerned with the train as operated on Italian rails. It remains that the train was integrated into the SBB Schedule as an IC during most of it's time of operation.
I ask you again, what is your problem today?
Respectfully,
Offline Hemmerich
#11 Posted : 16 August 2010 18:29:06(UTC)
Hemmerich
Nothing else did I. Different to you I even told the forum that they can easily not only assemble a "prototypically correct" Riviera dei Fiori just composed with coaches from this set, but use them as well for many other alike trains - which I think is a great idea and offer from Märklin. ThumpUp
Thanks for the confirmation of Märklin's correct labelling of this set. So, we can all agree that there was no need for them nor to most of their customers to call it something else! BigGrin BigGrin BigGrin
No problem. Besides myself, this site is most likely already known to many other people, in particular those with a passion for Märklin trains. Smile
PS: About problems - apparently some people still have their "daily problem" with Märklin. Cool
#12 Posted : 16 August 2010 21:58:19(UTC)
Those who wanted to assemble a SBB Eurocity, Intercity or Interregio train using the modern SBB Eurocity coaches have long had the ability to do so, using either the 4367 Set or the individual 4365, 4368 and 4369 coaches and the 42173 restaurant coach. Additionally, the 4266 Eurofima Am coach as well as the 42163 Bpm and SBB EWIV coaches which were routinely attached as domestic "Kurswagen" on international trains, could be added to the consist. Thus, the 43670 is nothing new, but a set of similar coaches released with the specific destination signs for the "Riviera dei Fiori", which was operated as an "IC" in Switzerland and as an "EC" in Italy and France.
I am not stating that Maerklin's labelling of the set was incorrect. I was only providing additional information about the consist, including which loks would be used to pull the train on the various national sections. I provided information on the equivalent Roco 1/87 models for those who might wish to recreate the train in exact scale, as well as providing some other suggestions, like adding an EC Apm (1st class) in the Cisalpino livery from the 26544 Set, which was also common between 2004 and today.
Regarding the link to the Italian forum, I have been long aware of that site. It's information is good but no better than any other site for information.
For once and for all, I have no problem with Maerklin. I may have an issue from time to time with certain models. AFAIK the only daily problem that I seem to be having is with one specific member, who likes to spout off in every topic that I post.
Respectfully
#13 Posted : 17 August 2010 01:17:18(UTC)
Respectfully
Not all your topics Mike BigGrin
Offline Hemmerich
#14 Posted : 17 August 2010 01:41:45(UTC)
Hemmerich
All these coaches are knowingly no longer produced; the predecessor of this new set even since more than 15 years - actually the reason why this new set was created, including an update to the appearance of these coaches. It should therefor attract many Märklin fans who are looking TODAY for such a new set/coaches.
Those actually comparing the old coaches with this set should/will also realize the differences and can therefor be assumed to better know what they're talking about.
Yes, nothing new. Situation for those is the same as above - no longer in production except EW-IV coach #42162. BigGrin
Thus, the 43670 is nothing new...
Maybe just for those who haven't seen this set personally (see above) RollEyes.
PS: We're here to discuss (Märklin) model train stuff.
Edited by user 18 August 2010 00:07:22(UTC)  | Reason: Abusive hint about other person removed - Much to common with this user and next time will give susp
#15 Posted : 17 August 2010 11:07:33(UTC)
Hemmerich wrote:
we're here to discuss (Märklin) model train stuff.
Comment removed by Webmaster..
Why is it that my thread letting people know that this new Set is available and how this consist can be portrayed on layouts or in collections with a Swiss or Italian theme is challenged because I referred to it as a IC Set and mentioned both the SBB and FS where this train runs?
Edited by moderator 17 August 2010 21:26:22(UTC)  | Reason: Comments on person removed
Offline Hemmerich
#16 Posted : 19 August 2010 23:57:59(UTC)
Hemmerich
First of all, this is not the thread of user "mike c" - it is just one thread of this forum like any other (only with that person "accidentially" being the creator).
Second, doubtless there are many other people who are quite more familiar with both the prototype and the model of this Märklin train composition - those who have experienced either one or both live in operation and thus don't need to rely upon second sources. It is not only their right, but also "privilege" to comment on misleading or incorrect information which is clearly different from their own knowledge (needless to say that personal attacks/bashing also influences willingness of sharing).
In order to understand the different prototype train classifications as well as the coach composition of the train "Riviera dei Fiori" it is mandatory to specify as well the corresponding operating period. In conjunction with the Märklin set it is 2004 (even extending up to at least 2005).
There is for example a major difference between this "Riviera dei Fiori" train here and the prototype train with the same name at the time when it operated as reflected adequately by the Märklin set (even the inclusion of the - actually very nice - dining coach matches the composition at that time). For discussions of such 87:1 topics IMHO the "prototype" section would likely be more/most adequate.
It sounds quite "funny" if one and the same person calls this Märklin EC coach set (not the prototype train) in one place of this forum an IC and in another one an EC, even "translates" the trainset announcement of both the referring dealer and Märklin to his own wishful thinking (might have been one of the reasons why the link which I made to the helpful Italian website for Märklin train fans was not mentioned before).
All forum readers interested in this trainset can look excited forward in getting it from their favorite dealer; they should not be dissatisfied; all coaches are surely different from those mentioned older ones (there is even one typical Märklin "Schmankerl" within the set, but I'll leave that finding up to everyone her/himself). Smile
Online H0
#17 Posted : 20 August 2010 00:05:25(UTC)
"Schmankerl" sounds like a positive surprise (not the typical Märklinisms we're used to).
I haven't ordered this set. Now you make me curious about the "Schmankerl".
I guess the Quiz section is the best place for the "Schmankerl" quest.
Offline Hemmerich
#18 Posted : 20 August 2010 00:19:59(UTC)
Hemmerich
Since it's no real quiz, neither for the owners of this nice set nor any others interested in getting their set, I intentionally mentioned it still here.
Anyone interested in a quiz is surely welcome to open a thread there. Wink
#19 Posted : 20 August 2010 01:25:38(UTC)
The weakness in the control of this thread is considerable. Deletions are made without the knowledge of the poster.
I anticipate that every thread opened by Mike will go the same way and I doubt by now anybody will have much of a clue regarding this model as the thread is just and argument between two people who will never agree.
Any fun with model rail just does not exist in a thread about a toy train.
To be fair to Mike I have in the past been keen to read his posts but quite frankly what is the point.
If I like this set I will buy but as I dont then I wont but I hope it sells well for Marklin and those who buy enjoy their purchase.
Offline TimR
#20 Posted : 20 August 2010 02:09:42(UTC)
TimR
Indonesia
Sadly agree with everything you said, Dave..
Sadly, it may also the intention of the one of the parties to cause such "disruptions" to make the threads unreadable.
The elephant in the room...?
Why do only Mike C's threads have to endure these senseless back-and-forth arguments?
Other members have been able to post critical threads of Marklin with little or no disruptions like the ones here - there are normal disagreements, of course, but this is different - those are generally resolved very politely in this forum (we agree to disagree).
There are unhealthy issues here that I think need urgent attention.
Now collecting C-Sine models.
Offline bmcrae
#21 Posted : 20 August 2010 08:11:57(UTC)
bmcrae
Pisses me off. I love my Märklin trains, ESPECIALLY my Swiss items!!! I've got what any non-participant in the hobby would conisder a large collection (but to the average active poster here my collection looks like...... 'peanuts' Cool )
I enjoy the technical information and reviews Lutz offers, and I enjoy the background info and attention to detail Mike brings. But like parallel lines, never the two shall meet. And in this case they move in directions 180 degrees opposite to each other. The threads that interest me most and barely worth reading anymore.
#22 Posted : 20 August 2010 13:32:51(UTC)
Hi Brian. I also like Swiss stuff but no little about the prototype and Mike is great in that respect but reading the above is just confusing and to me useless.
dave
Offline Macfire
#23 Posted : 20 August 2010 14:55:48(UTC)
Macfire
I suppose I should stay out of this one but I have an itch in an appropriate place:
Okay Lutzie
You have had your daily dose of "Mike Cee" bashing (as you sometimes have refered to him).
The term in this particular case refers to the Originator of the thread.
Not, as you insinuate, that Mike is claiming ownership
No. Most people have their "Daily problem" with you!!!!!
Congratulations on maintaining your position as the Forum's No.1 Plonker
Now where did I put that ointment?
Lord Macca
Offline Macfire
#24 Posted : 20 August 2010 15:04:10(UTC)
Macfire
Okay Lutzie
I mean it Lutz.
Everytime Mike posts something, you "jump down his throat".
That is such a shame as you manage to ruin a thread with your snide remarks.
And that turns the likes of me off - and I don't buy the article in question!
Lord Macca
#25 Posted : 21 August 2010 01:14:19(UTC)
Okay Lutzie
For those folk in Dire need I know where one can get free samples of PREP H.
It is very effective.
Maybe a sample should be sent to No 1 Plonker, it may help.
NN
#26 Posted : 21 August 2010 01:56:35(UTC)
Well, there is no real competition there!
NN
I very much doubt it! Cursing
However, since this thread no longer seems to be about the '43670 SBB/FS IC Riviera dei Fiori', I'm reluctantly locking it.
Lutz, you would do well to take notice of the opinions about you here, and change your forum behaviour. I know the moderators have almost had enough of having to deal with your nonsense. And as Juhan said to you recently...."Basta!"
Guest (4)
This page was generated in 0.783 seconds.
