Offline nyc5450
#1 Posted : 04 August 2010 01:40:45(UTC)
nyc5450
Hi folks,
I am considering purchasing a M3083 SNCF. I would like to convert it to digital. I believe that it is the same as a 3111 Beligin, and based on the older M S3/6.
I have searched the forum for information about this conversion. If I remember correctly, there was a post about the difficulty of fitting the new brush plate into the body casting.
I believe that it has a LFCM motor, but I am not certain.
Has anyone converted this type of locomotive to digital? If so what works and what does not?
Offline Ross
#2 Posted : 04 August 2010 02:19:57(UTC)
Ross
Hi John,
I have converted this loco using a 60904 kit with a few mods. See article below
3111 Conversion
nyc5450 wrote:
Hi folks,
I am considering purchasing a M3083 SNCF. I would like to convert it to digital. I believe that it is the same as a 3111 Beligin, and based on the older M S3/6.........
Edited by user 03 January 2025 03:17:35(UTC)  | Reason: Link corrected 03-01-2025
Ross
#3 Posted : 04 August 2010 02:26:26(UTC)
I have just converted a 3111 (Or had it done). all we did was to fit a Permanent Magnet and a decoder. Kept the Original Armature and Brush Plate.
N
Offline nyc5450
#4 Posted : 05 August 2010 23:12:14(UTC)
nyc5450
Hi folks,
Sorry it has taken so long to get back and thank you both for the very helpful information. The office has been MAD for the past two days!.
Ross, that is exactly the article that I remembered. Does the five-pole armature make the loco run that much smoother? I appreciate your directions, however grinding away on the brush plate seems a bit drastic.
Nev, when you had the conversion performed, what decoder di you end up using? Did you need to make anyother changes like replacing the headlamp bulb? How does your 3111 run?
Thank
#5 Posted : 06 August 2010 01:20:37(UTC)
John, I used a Lokpilot 3 and had to change the Head lamp. Nothing else except soldering.
it runs very well, these days if fitting a decoder and Magnet and the original 3 Pole Armature is OK I do not change it.
I find that the Magnet and Decoder makes for a lot smoother running than original and it saves work and $$$.
I have 2 other Delta Locos to upgrade and will be following that path.
N
Offline nyc5450
#6 Posted : 06 August 2010 02:37:27(UTC)
nyc5450
Many thanks Nev!
What is the correct light bulb to use? Forgive the question,however I'm a novice
at digital conversions.
Offline Ross
#7 Posted : 06 August 2010 04:28:28(UTC)
Ross
John,
The 214121 motor shield is mainly used for diesel and electric locomotives as it has a curved area to allow it to mount into the loco chassis and for the motor boggie to turn, this is what is cut/grind down to size to allow it to fit into the body shell.
You will notice in my tip that the motor shield is mounted upside down to get the brush springs below the armature bearing.
With the five pole motor it runs very smooth, very nice.
nyc5450 wrote:
Hi folks,
Thank
Ross
#8 Posted : 06 August 2010 10:46:49(UTC)
nyc5450 wrote:
Many thanks Nev!
John, Bulb and Socket:
M604180 Bulb Sockert for 3125
M610080 Light Bulb
Nev
Offline antycapp
#9 Posted : 20 February 2021 12:36:58(UTC)
antycapp
Hi John,
http://members.ozemail.c...pdf/60904_conversion.pdf
Hello everyone, sorry if I intrude, I'm looking for information about the digitization of the 3083, but unfortunately the link you posted so long ago no longer works. Would it be possible to get the pdf back? Thanks so much.
I learn, I learn!
Offline Ross
#10 Posted : 20 February 2021 21:09:05(UTC)
Ross
Hi All,
This is the correct link to the old article I wrote because the article was renamed 31-12-2024
3026 + 3111 difficult 60904 conversions
Hope it helps
Originally Posted by: antycapp Go to Quoted Post
Hi John,
See correct link above.
Edited by user 31 December 2024 04:42:22(UTC)  | Reason: Not specified
Ross
This page was generated in 0.707 seconds.
