Offline FMS
#1 Posted : 05 August 2010 21:47:44(UTC)
FMS
Hi there!
I need some help with the following situation.
With my layout i use Feeder Track 24088, can i plug directly the MS2 like i do with the MS1, or for this MS2 i need the Connector Box 60115?
Is it possible to buy the locomotive card separated?
Sorry for such a simple questions.
FMS
#2 Posted : 05 August 2010 22:06:04(UTC)
I have test the MS2 on 24088 feeder track but not working.
The MS2 must request new 60113 Connector Box only or plug into the CS2.
Offline FMS
#3 Posted : 05 August 2010 22:09:59(UTC)
FMS
Blushing Forget the conector box part...i just found the answer:
"For K Track. This box is for connecting a transformer and up to 2 Mobile Stations.
Dimensions 96 x 85 x 40 mm /3-3/4" x 3-3/8" x 1-9/16"."
So my other question is:
Is it possible to plug to the Feeder Track 24088 MS" in the first socket and the MS1 at the second one?
FMS
Offline FMS
#4 Posted : 05 August 2010 22:17:26(UTC)
FMS
Hi Steven! Tks
But they say that 60113 "is for making connections for a power pack or transformer and up to 2 Mobile Stations (60653)".
What you´re saying is that i will not be able to upgrade my layout with the MS2 just by plug it to the Feeder Track 24088 OhMyGod
I thought that it would be simple as swap the devicesConfused i mean just disconect MS1 and connect MS2Confused
FMS
#5 Posted : 05 August 2010 22:18:26(UTC)
You need two old MS1 to connecter the 24088 feeder track or 60115 box.
But you need 60124 10-pin to 7-pin adapter cable for connecting a second mobile station to the 60115 Connection Box or 24088 feeder track.
Offline FMS
#6 Posted : 05 August 2010 22:47:56(UTC)
FMS
Ok.
Let´s forget the connection of a second MS (I or II).
My question is:
Can i replace the former MS1 that is connected to the Feeder Track 24088 with the new MS2?
Sorry for being so anoying but i nedd to clarify this question.
FMS
Offline FMS
#7 Posted : 06 August 2010 00:54:25(UTC)
FMS
Hi, can somebody please help?
Steven said that it´s not possible to plug and play MS2 to feeder 24088, but the plug on the MS comes with a 10 pin connector, ans the socket on the 24088 connector box also have 10 pin connection:
So is it possible to plug, MS2 to the Feeder Track 24088, and play?
The thing is that my layout im 4000km away from me since i´m in Finland (where i bought the MS2) and the layout is back home in Portugal, so i didn´t had the chance to try it. tomorow i will be at Frankfurt and if something elseis needed to plug the MS2 to my track i may try to get it there.
FMS
#8 Posted : 06 August 2010 03:26:59(UTC)
It is NOT possible to use the MS2 in connection with the 24088 in any way.
Offline FMS
#9 Posted : 06 August 2010 07:07:04(UTC)
FMS
Tks Per!Cool
Ok, let´s try to get the connector box....
Tnk you both Per and Steven
FMS
#10 Posted : 06 August 2010 09:42:20(UTC)
No. The MS2 does not work at all with the 24088 feeder track.
And you cannot use a MS1 as a slave to a MS2.
AFAIK, you can use a MS1 and a MS2 together only if they are both connected to a CS2. The MS2 cannot be used with the CS1.
Offline AJ
#11 Posted : 08 August 2010 10:13:56(UTC)
AJ
Thanks FMS for asking the question and everyone else for clarifying. I have a 24088 making its way to me from India. Glad to know its useless Sad I had been hoping to do away with using the spade connectors. Tell me that the 24088 will be of some good - like it works with CS2.
For MS2 then any alternatives to the 60113 connector box and spade connectors?
Alok
#12 Posted : 08 August 2010 11:27:35(UTC)
24088 contains only sockets and a bridge rectifier (same for 60115).
Digital track signal is generated by MS1.
Both can be used with CS1 and MS1.
Unscrew the box from 24088 and use it like a 24188 ...
60113 contains the processor that creates the digital track signal.
You can use a 60214 instead of a 60113 ...
Offline AJ
#13 Posted : 08 August 2010 14:05:59(UTC)
AJ
Tom, i am guessing that the 60214 connects to the tracks with spade connectors. I hadn't realized that the processor from the 60113 was built into the 60214. So if I used a 60173 booster with the 60214, then the booster would plug into the tracks as well in addition to connecting with the 60214 via the 9pin cable.
Using the 24088 as a 24188 is a good use although not what I had originally planned BigGrin RollEyes
Alok
Offline FMS
#14 Posted : 01 September 2010 04:55:39(UTC)
FMS
Just for the record, i manage to get the connector box and everything is working now!
I like the MS2 very much, functions, design, that blue lightSmile very happy with this purchase.
FMS
This page was generated in 0.670 seconds.
