Offline Brakepad
#1 Posted : 25 June 2010 13:14:13(UTC)
Brakepad
France, Metropolitan
Hi friends,
This is my first topic on this section.
3 months ago I purchased a HAG Re 4/4 II for a very cheap price (54€). This locomotive included the awesome "type 88" motor with ball bearings, however, there was an explanation for such a low price:
1-It had been used on a layout with overhead wires, and the previous owner had removed the pickup shoe (easy to fix-I adapted a Roco pickup shoe)
2-Worst of all, the roof had been "weathered" in a way that I did not like at all. The looking of this loco was not good.
So I decided to try to improve the roof. I had to "unweather" the roof (difficult) and repaint it.
This is how the loco looked when it got home:
Removed the housing, removed all the accessories (pantos, windshield, roof equipment) and tried to wipe off the roof as much as I could, or, at least, until the surface was flat and levelled enough:
Purchased spray primer & silver paint from Tamiya, and masked the body loco. For the front & rear ends, as they were quite irregular, I used play-doh (!), and even if I did not know at all if it would work, it did, actually.
I prepared a box to be used as a "painting cabinet":
Roof in primer, after two coats (the product is awesome):
After the primer got dry, the finish silver paint was applied:
And this is the final result, after tha paint got dry and the masks were removed:
Notice the job the play-doh has done on the front end. It's not a professional job (I should have peeled all the paint off), but the looking has improved, in my opinion.
Best regards.
Offline Darren W
#2 Posted : 25 June 2010 20:11:25(UTC)
Darren W
Good job on a difficult task. Removing the old paint without damaging details would be tricky.
Has anyone tried a sandblaster like this one?
https://www.micromark.co...DBLAST-GUN-SET,9117.html
Cheers...
Darren
#3 Posted : 26 June 2010 02:52:09(UTC)
Hi Brakepad,
Nice job, and very well described. Did you use paint spray cans?
Offline obxbill
#4 Posted : 26 June 2010 22:13:10(UTC)
obxbill
Very well done! Playdoh does work well. I've used it for masking camo on aircraft models before.
Bill
Offline jonquinn
#5 Posted : 27 June 2010 20:00:31(UTC)
jonquinn
well now I must get one of these little grit blasters. there are several on ebay, but not with the paasche brand, but look the same, and a little less expensive.
Offline Brakepad
#6 Posted : 28 June 2010 00:02:27(UTC)
Brakepad
kimballthurlow wrote:
Hi Brakepad,
Thanks for your comments guys.
Yes, both primer & silver paint were spray. I have no air brush.
And I have to say that Tamiya spray products are 1st class.
The playdoh trick has been really helpful. I recommend it to everybody.
This page was generated in 0.696 seconds.
