Offline dragos
#1 Posted : 24 June 2010 23:52:01(UTC)
dragos
can anyone tell, if it is possible to plug the new MS2 direct into the ECoS, and use it as an extra controller, in the same way as one could do with the original MS?
Björn
#2 Posted : 24 June 2010 23:55:48(UTC)
Hi, Björn!
Plug in: Yes.
Use it: No!
Same plug, no damage done if you plug it in - it just won't work.
See also here:
https://www.marklin-user...aspx?g=posts&t=15930
(Märklin 60212 is ECoS compatible hardware)
Offline dragos
#3 Posted : 25 June 2010 00:48:54(UTC)
dragos
H0 wrote:
Hi, Björn!
Plug in: Yes.
Use it: No!
See also here:
Tom:
thanks! How about a MS2 and 60113 into the "sniffer" plug? Could that be a possible hook-up?
Björn
#4 Posted : 25 June 2010 01:14:36(UTC)
Sniffer port should work.
I'd setup all locos on the MS2 as DCC locos (even if they are MM or mfx locos on the ECoS and in reality).
Offline Hemmerich
#5 Posted : 25 June 2010 02:20:05(UTC)
Hemmerich
Edited by user 20 November 2010 01:38:02(UTC)  | Reason: Not specified
Online Purellum
#6 Posted : 25 June 2010 02:53:41(UTC)
Hemmerich wrote:
There's nothing to "sniff" for the ECoS on the MS2. Wink
Hello Lutz.
Please read Bjørns question again, maybe then you'll understand Wink Wink
Björn
Wink Wink Wink LOL
#7 Posted : 25 June 2010 10:33:15(UTC)
Hi, Për (Pürëllüm) and Björn!
Sorry for going OT, but which is correct: "Bjørn" or "Björn"?
Is the former Dänish and the later Swëdish? Are these different ways to write the same name depending on the available characters?
Got me cönfüsëd ...
Online Purellum
#8 Posted : 26 June 2010 01:15:56(UTC)
Hello Tom.
I was wrong Wub spelling Björn's name as Bjørn.
Bjørn is the danish version, the pronouncacion is the same.
#9 Posted : 26 June 2010 02:13:13(UTC)
Learned something new ... ThumpUp
... and "ö" is on my German keyboard. Wink
Online Purellum
#10 Posted : 26 June 2010 02:18:45(UTC)
Take care, Tom, the German word "öl" is pronounced almost like the Danish "øl";
but it is not the same RollEyes BigGrin
Offline Philip
#11 Posted : 28 June 2010 16:44:15(UTC)
Philip
Hi Per.
One could probably explain it this way: the German "öl" will be used in an engine, while the Danish "øl"; will be poured into a person. Wink Wink
Philip.
Let's keep it simple.
MFDWPL
This page was generated in 0.415 seconds.
