marklin-users.net community
| Forum
Home
Community Forum
Login
or
Register
Forum
Active Topics
Login
Register
OK
General topics
Digital
Digital conversion - Is It really worth the cost?
2 Pages
1
2
Go to Page...
Email this topic
LinkBack Topic URL
Retweet this Topic
Share Topic on Google+
Like this Topic
Share on Facebook
Digg this Topic
Reddit this Topic
Share on Tumblr
Watch this topic
Print this topic
» Normal
Threaded
Previous Topic
Next Topic
sudibarba
#51
Posted :
21 April 2010 21:48:40(UTC)
Retweet
I cut off all capacitors and chokes and do not add anyback.They are for radio frequency supression.Mine all run fine without any.Some people think the chokes you get in kits help protect the decoder. The decoder has built in over load protection. Put them on if you want. As I said, I don't and have never lost a decoder other then by my screw ups.
Eric
User Profile
View All Posts by User
View Thanks
GSRR
#52
Posted :
21 April 2010 22:01:23(UTC)
Retweet
You have been a member since:: 01/03/2009(UTC)
Alan,
Could you possibly post a few pictures? As Eric says, differing opinions for the single capacitor, but nothing else has worked. The only other thing is to triple check your connections, soldering, and proper grounding??
Thomas
ETE
ECoS iTrain TouchCab C-Gleis German Era Id & IIIb USA Era IIIb SBB Era III SJ Era IV GC Era V
User Profile
View Thanks
rschaffr
#53
Posted :
21 April 2010 22:05:08(UTC)
Retweet
So do I, but that should not cause his problem. On the 3021, the choke is a large oblong device on or near the input from the pickup shoe, I recall. Again, I don't see that causing a problem with the decoder whether it is there or not, but I would remove it if you have not already done so.
One caution make sure that the function common (blue) is not connected to the chassis in any way. If you are using the chassis for the ground on you lights, the blue should be isolated and insulated.
-Ron
WWW
User Profile
View Thanks
aos
#54
Posted :
21 April 2010 22:17:42(UTC)
Retweet
Many thanks everybody for all the support. Sadly, I am away on business over the next few days. When I return, I will literally remove all the wiring and start again from scratch. It must be afundamental error that I am committing. Regards, Alan.
WWW
User Profile
View Thanks
aos
#55
Posted :
21 April 2010 23:00:06(UTC)
Retweet
Hi folks, Latest News Flash!! - I thought I would give it one more try this evening and hey presto, we have lift-off
Admittedly, I have the lighting wires the wrong way round,
but that is a minor issue. It turned out to be the earth black wire which was not connecting properly
I have cured that by attaching it into the screw hole which held the old reversing unit and tightening the screw, giving a secure fastening
Once again, thanks to everyone for all their patience and advice
I am glad that I perservered.
Without your tremendous encouragement, I would have given up hours ago.
Onwards and upwards is all I can say. Bring on the next loco. I shall continue with the easier ones first. Once I have some of those done, I shall look at doing something maybe a bit more complicated, Loksound, maybe
WWW
User Profile
View Thanks
GSRR
#56
Posted :
21 April 2010 23:34:19(UTC)
Retweet
Alan,
Great news. Can you tell them difference in the running and noise level?
If you look at my picture, lower left of the motor shield, with the blob of solder above the screw? That is the black wire. Some people use the M* 231470 solder clip which you can insert the screw into before placing it into the motor shield.
How was yours place before?
Thomas
http://www.modelspoorh0....n%20en%20Esu%20info..pdf
ETE
User Profile
View Thanks
sudibarba
#57
Posted :
21 April 2010 23:37:08(UTC)
Retweet
Congradulations! As I said a while back, you are now also in a position to do you own repair work as need arises. Ah, now let's see, which spare parts (brushes, tires, motor covers & armatures(rare)) can you amass for your supply room?
Eric
User Profile
View Thanks
GSRR
#58
Posted :
21 April 2010 23:41:37(UTC)
Retweet
Alan,
Going forward this sticky is a good resource.
marklin-users.net forum » General topics » Digital » Motor parts for digital conversion of M locos...
https://www.marklin-user...&m=239257#post239257
Thomas
ETE
User Profile
View Thanks
aos
#59
Posted :
23 April 2010 15:48:15(UTC)
Retweet
Well, I am back on the railways this morning
. I have rewired the lighting wires so that the correct headlight shines for the direction of travel
For anybody who might be interested in converting in the future, here is a list of the lessons that I have learned the hard way
It is better to locate the decoder somewhere first! I know it sounds like a trivial issue, but the wiring is extremely flimsy and for the likes of me, with hands like the proverbial bunches of bananas, everything leaps uncontrollably all over the place
. I am sure that those of you who have converted before can vouch for this.
Now, attach the wires to the necessary locations. It just means that the wiring ends up less tangled and therefore, the installation will hopefully be a lot neater.
Since my locos are pre 1984, none of them have the 8 pin interface plug fitted. This meant that I had to cut off the interface plug attached to the decoder. The result is that the wires are rather short, especially for the longer locos. I needed to splice the wires to the existing wiring. On reflection, I would definitely advise buying the ESU extension harness
It is about €3.
Anyway, what do I think of the result?
I like the independence of the digital control
I like the slow running characteristics,
although they are obviously not as good as my new digital starter set BR01 loco. I have kept the 3 pole LFCM. I may look at changing it in the future, but I have a lot of locos to convert, so that is not a high priority.
The old light bulbs do flicker quite a bit, but I suppose that is a small penalty
The motor does seem to run quieter than when it was analog. Could that be wishful thinking on my part?
Conclusion: Definitely worth the effort. I shall proceed with converting the others
Once again, a big thank you to Ray, Eric, Ron and others who encouraged me to persevere.
WWW
User Profile
View Thanks
Posted :
23 April 2010 15:57:35(UTC)
Retweet
You're very welcome, Alan!
By the way, the motors should and do run more smoothly and much more quietly when upgraded to digital. It is a by-product of effectively changing to a DC motor, with a lot less "cogging" going on at low revs.
User Profile
View Thanks
Ian555
#61
Posted :
23 April 2010 16:03:09(UTC)
Retweet
Hi Alan,
Well done.
Ian.
User Profile
View Thanks
rschaffr
#62
Posted :
23 April 2010 16:54:15(UTC)
Retweet
Alan:
If the light flickering gets too much for you, Marklin sells a small light socket (part # 276770) that has two wires and fits inside the light base on these older loks. It can be wired to the appropriate light feed for the direction and the decoder function return. This eliminates the flickering . These sockets take the same same bulbs as most digital loks (part 610080, I believe).
-Ron
WWW
User Profile
View Thanks
GSRR
#63
Posted :
23 April 2010 20:38:01(UTC)
Retweet
Alan,
When you have a chance can you post a few pictures of the conversion?
Thomas
ETE
User Profile
View Thanks
aos
#64
Posted :
23 April 2010 21:32:20(UTC)
Retweet
Thomas, must I really, it is pretty untidy, but it does work
. Incidentally, I have just received an email from ETS in Germany to say that they have shipped my order of 3 * 60760 High performance conversion kits. So, hopefully, I will receive them early next week and start the next three conversions then.
WWW
User Profile
View Thanks
marklinsa
#65
Posted :
23 April 2010 21:54:31(UTC)
Retweet
Hi Alan
By the way. Herman, what part of South Africa are you in? I had the 'opportunity' to work for the gold mines in Welkom for 3 years from 1984 - 1986. What a lovely country. The scenery is magnificent. I had a great time visiting Johannesburg, Durban and CapeTown. Alan
I currently stay in Johannesburg (so called West Rand) and work for an engineering company. I use to sell mining timber to Gold Fields (Kloof and Driefontein mines) some years ago. Its about time you return for a visit!
Herman Steyn
DRG Epoche 2, SBB & Narrow Gauge
www.herman.rula.co.za
http://www.samodelrailway.hot.co.za/
WWW
User Profile
View Thanks
2 Pages
1
2
Go to Page...
General topics
Digital
General topics
- General MRR
- H0-scale
- Small scale
- Big scale
- Prototype
--- Videos
----- Steam
----- Electric
----- Diesel
----- Accidents
- Digital
- Model railroad software
- Model railroad photography
Reviews
- Loco Reviews
- Reviews of rolling stock
- Accessories reviews
- Model kit reviews
Collector's Corner
- Collector's Corner general
- Märklin Sprint
- Construction kits
- Steam engines
- Tinplate toys
The Projects & Workshop area
- Track plans
- Painting & Weathering
- Model railroad wiring
The Club Corner
You
cannot
You
cannot
You
cannot
You
cannot
You
cannot
create polls in this forum.
You
cannot
vote in polls in this forum.
Powered by YAF.NET
This page was generated in 0.540 seconds.
