Offline TomB
#1 Posted : 12 April 2010 11:07:53(UTC)
TomB
Märklin did not manage to make the models run syncronously.
Olli from Hamburg has made a perfect trimming of the decoders.
Files for ESU LokProgrammer
Edited by user 15 April 2010 21:26:19(UTC)  | Reason: Not specified
Tom Blikstad
HO, german/swiss trains, Märklin K+C, ECoS I+II,
Viessmann, Kühn, MBTronik, WinDigipet 2012, WinTrack 11
Offline Hemmerich
#2 Posted : 13 April 2010 20:51:18(UTC)
Hemmerich
Edited by user 21 November 2010 02:07:51(UTC)  | Reason: Not specified
Offline Sander van Wijk
#3 Posted : 13 April 2010 21:13:54(UTC)
Sander van Wijk
Hi Tom,
Thanks for this interesting link! Even though this isn't exactly my cup of tea in terms of era's, I do know at least one person who is going to benefit from this. As I'm working part time at a hobby store, I do know of at least one set we have tested which didn't consist of two locos running perfectly synchronous out of the box.
Sander
#4 Posted : 13 April 2010 21:47:27(UTC)
As the operation of the motor is dependent on many factors, including the settings of the decoder, it is normal that not every set will have the same operating specs. I found that one of my Re 4/4IIs had too much pressure exerted by the spring on the brushes. Once this was adjusted, it worked as expected. I have not as yet received my 37320, but I will test it when it finally arrives on this side of the pond.
Offline TimR
#5 Posted : 14 April 2010 02:01:54(UTC)
TimR
Indonesia
This is true, as has been discussed recently in the "double-heading" thread.
This setting might work for some, but obviously will not be everyone. In fact, none of my duplicate models (MFX or otherwise) actually have exactly the same speed and speed curves - even if they have the same decoder and/or settings.
I don't think any manufacturer in today's MRR world can honestly claim that they can make an out-of-the-box super-precise, perfectly synchronized double header in H0 scale.
If I recall from Steventrain's photo of the 37320 manual, Marklin advises their customer to properly adjust the settings of both locomotives to try and get them synchronized, before double heading them. To put simply, they had never claimed or guaranteed that the two loks would run in perfect synch for double header use.
Edited by user 14 April 2010 05:57:13(UTC)  | Reason: Not specified
Now collecting C-Sine models.
Offline Hemmerich
#6 Posted : 14 April 2010 21:19:59(UTC)
Hemmerich
Edited by user 21 November 2010 02:08:17(UTC)  | Reason: Not specified
Offline TomB
#7 Posted : 14 April 2010 22:40:13(UTC)
TomB
The manuals, page 9:
Both locomotives are designed to be operated together. If problems arise when running the locomotive togetger in multiple unit operation,
we reommend that you set up the m.u. combination from the beginning again so that the locomotives are syncronized with each other.
You can achieve this by adjusting the V-max and V-min for one locomotive to the behavior of the other locomotive.
Tom Blikstad
Offline TimR
#8 Posted : 15 April 2010 01:59:16(UTC)
TimR
Indonesia
Hemmerich wrote:
Simply wrong! The correct Märklin statement can be found in the #37320 user manual (chapter "Information about operation").
My post above is simply my intepretation of the statement that Marklin put in the manual, as TomB posted it:
Both locomotives are designed to be operated together. If problems arise when running the locomotive together in multiple unit operation,
Doesn't change the fact that the above statement is a disclaimer.
Marklin simply says "are designed to be operated together" - this can be literally translated that both models share the same drivetrain (gearing), motor, and decoder (settings) - ie: they share exactly the same drive characteristic from one another.
The rest of the description from the beginning of the words "If problems arise..."
seems to stand up to my earlier intepretation about it. Customers may need to make manual adjustment - that doesn't sound like a guarantee.
Now OTOH if the manual says,
"Both locomotives have been syncrhonized perfectly at the factory to be operated together."
Now we're really talking...
You are certainly entitled to your opinion, Lutz... if this is really your experience.
Anyway, rather than simply saying that my opinion is wrong,
why don't you post your settings or the techniques that you used to guarantee how two models with DCM motors will be able to run in synch for hours without any adjustments needed?
Because in my experience, even if you managed to get even exactly the same models in synch, one or both loks would soon began to "drift" from the original setting. One would began to run slower, or faster. So the distance between the two running models would always change over time.
#9 Posted : 15 April 2010 02:23:13(UTC)
Lutz says that his locos "worked fine simultaneous right out of the box".
One wonders whether he was able to hand pick the samples he has! Wink Wink
Unfortunately, the manual for 37320 is not available for download from the Marklin website (at least not when I looked).
#10 Posted : 15 April 2010 02:35:39(UTC)
The prototyical max. speed of both Re6/6 and Re4/4 is 140 km/h.
I first adjusted the Re6/6 to speed setting 175 (of 255). 140,2 km/h on a straight track section.
Then I adjusted the Re4/4 to 167. Also just above 140 km/h.
Both locomotives were initially set to 255.
I have set both the acceleration and decelartion time to 7,5 seconds on both locomotives.
They run perfectly in a double heading.
The adjustments are done with a CS1.
See my excel sheet:
http://www.saebonet.com/Svein/Tog/images/Swiss/37320/37320.xls
#11 Posted : 15 April 2010 13:28:05(UTC)
If a manual mentions problems may arise then you can be sure they will as appears to be the case in the above posts.
For enthusiasts it can be enjoyable getting things to work properly but not so good for those who expect a model to work straight out the box. Nice set though.
dave
Offline mascagni
#12 Posted : 15 April 2010 20:25:33(UTC)
mascagni
My red HAG Re 10/10 set has always run great together.--MM
Michael Mascagni, Tallahassee
Offline Hemmerich
#13 Posted : 16 April 2010 13:20:17(UTC)
Hemmerich
Edited by user 21 November 2010 02:08:43(UTC)  | Reason: Not specified
#14 Posted : 16 April 2010 13:38:31(UTC)
"Beide Lokomotiven sind optimal aufeinander abgestimmt." = "Both engines are perfectly matched." (according to Mr Google)
Offline TimR
#15 Posted : 16 April 2010 14:50:08(UTC)
TimR
Indonesia
Do we not believe Marklin's own English translation in their own manual? BigGrin
I think it's still the same meaning to what is written in the English manual..
#16 Posted : 16 April 2010 14:56:14(UTC)
Probably, but then I haven't seen the English manual......Wink
#17 Posted : 16 April 2010 17:25:36(UTC)
optimal does'nt mean perfectly, close to perfection, there is the same word in german: perfekt.
If the loco runs perfectly at the same speed, they've could of used this word: "perfekt".
There are too many friction points in a Märklin loco to run perfect at the same speed at all times.
Even with Roco locos having wurm gears their identical running characterists may be closer than Märklin locos but not perfect.
# 1.perfect
# 2.perfekt ...........
#18 Posted : 17 April 2010 01:14:07(UTC)
Now who is telling Porkies,
Lutz or the rest of the participants in this topic.
NN
#19 Posted : 17 April 2010 01:52:24(UTC)
What we need is somebody who has a set that worked straight out the box. I dont suppose that there is anything wrong with having to do a bit of work before the set runs properly but this should be stated on the box or by the dealer etc before purchase as not everybody wants to fiddle with a new model.
#20 Posted : 17 April 2010 05:38:19(UTC)
NN
Unless Märklin quality controllers match each loco set to its nearest optimal, almost perfect, marklin enthusiasts: perfect running speed, I have my doughts.
The easier way out would be setting the CV's on the same par.
Any Märklin motor (except the C-Sine) has too many obsticles to run perfectley all the time, at the same speed and there is nothing Märklin can do about unless they change the:
1.) Brushplate
2.) Gearing
3.) add Ballbearings
End of story.
I personally would'nt like to run 2 locos as a double header with 2 motors all day.
Another failure is if you leave the Acceleration & Breaking delay "ON".
In my opinion it would put more strain on both loco motors if the speed is not perfect.
Both loco motors would react in the opposite direction of pulling and pushing, with other words if the front loco is going faster it would automatically trying to increase the power and the second loco is getting pushed would decrease its power.
With the breaking & Acceleration delay "OFf" it may limit the push pull friction.
The german interpretation has for some reason allowed some members to assume the word "optimal" means perfect or have been misguided by some cheap translation error.
Unless you have sensors monitoring the motor constantly of its speed and power output you will never, never, never and I say it once more, never achieve the same speed of both locos for a long period of time.
Sofar, who is telling Porkies, if you believe everything is said on this forum on its face value, you are a besotted believer and your path into heaven is granted.
#21 Posted : 17 April 2010 06:58:39(UTC)
Thankyou John, I am a true believer, but as not true, besotted or one eyed as someThumpUp ThumpUp Scared Scared
#22 Posted : 17 April 2010 07:29:38(UTC)
I always tried to be a true believer, but than, so many lies are told.
When you find the absolute truth, what do you do with it ? Every body thinks you're telling lies or porkies.
Is it worth telling the truth ? and if you're not, are you a true believer ?.
I like to stick to what I know and I know very little and this makes me almost a true believer.ThumpUp Scared.
What I say, hear, smell and see are 4 different believes and I can't tell you, if any of them is worth the truth. OhMyGod
#23 Posted : 17 April 2010 15:18:20(UTC)
May the Force be with you. Live long and prosper.
#24 Posted : 17 April 2010 21:55:00(UTC)
I have tested a little bit more.
My earlier mentioned settings works very well at 80 km/h, with very small individual speed difference.
When changing the speed to 90 km/h the individual speed difference gets bigger.
This means that it will be very difficult to adjust the speed of the two locomotives to be accurate at any speed level.
Anyhow, I think the consist runs very well.
#25 Posted : 17 April 2010 23:19:45(UTC)
I prefer to run locomotiv alone puffing alone with cars avoidance of the.
If i want run doubleheaded locomotiv,i prefer instead two of the same locomotivs.
With difference roadnumbers!
#26 Posted : 18 April 2010 10:10:47(UTC)
May the Force be with you. Live long and prosper, amen.
This page was generated in 0.696 seconds.
