4 Pages<1234>
#101 Posted : 13 March 2010 21:20:13(UTC)
The locomotives come with normal couplings as well as with a fixed bar, so they can be run either as two coupled locomotives or as a double consist. Both loks have their decoders set to the same number, so when you call them up, they respond as a single unit. It is possible to reprogram each lok so that they can be operated on their own. I presume that each set has been tested during production to ensure that the max speed, acceleration and deceleration are matched as closely as possible.
If you wish to operate two Hag loks as a Re 10/10, it should not be too difficult. All you have to do is to synch the digital IDs for both loks and adjust the acceleration, deceleration and max speed so that the loks work in tandem. Hag's Re 10/10 set has one advantage, that the two loks can be controlled from the same slider via a cable connecting the two loks. For the Maerklin set, the announced Roco set or any combination of individual loks, the two slider set up may be problematic when entering a signal stop zone or other section w/o power.
I guess that it would be possible to run a wire from one lok to the other using Viessmann's power conducting close coupler or by adapting Maerklin's own one for the loks.
The other option may be to run the Re 4/4II with the slider at the rear and the Re 6/6 with the slider at the front, leaving a minimal distance between the two.
Prototypically, some Re 4/4II are assigned to the Cargo division, while others are assigned for Passenger operations. The road number of your Hag lok may be that of a lok assigned to the passenger division. Prior to 2002, it was possible to see a wider selection of Re 4/4II in combo with Re 6/6. Of the Maerklin loks, 34/3744, 34 /37344, 37343 and 37356 are passenger loks. 34/37341, 37342, 34345 and the loks from the 26534 and 29859 Sets are currently Cargo loks. Of the Cargo Loks (37345, 29841), the loks are Cargo loks, but both have from time to time been leased to the Passenger division for use between Zuerich and Lindau on the run to Munich.
Maybe one of the members has the current list of the cargo and passenger assignments. I had it on my old PC but could not remember the website.
Offline TomB
#102 Posted : 13 March 2010 21:35:20(UTC)
TomB
Hi California.
I will get my 37320-set next week, but I can still answer.
Yes, the locomotives has each one high-efficiency propulsion motor and each one ESU Lokpilot V3.0 mfx with digital adresses 44 and 62.
The Re 6/6 has got a sound generator. You can drive different trains.
Yes, the two drives should already be adjusted to go in a double traction. But, they are not, so we have to do the adjustment ourselves - at least set the same vmax.
Tom Blikstad
HO, german/swiss trains, Märklin K+C, ECoS I+II,
Viessmann, Kühn, MBTronik, WinDigipet 2012, WinTrack 11
Offline TimR
#103 Posted : 14 March 2010 02:37:01(UTC)
TimR
Indonesia
I think the Stummi review of 37320 mentioned that this is not the case..
Further adjustments to the settings parameters are necessary to ensure both the Re4/4 II and Re6/6 run in synch.
Now collecting C-Sine models.
#104 Posted : 14 March 2010 04:33:46(UTC)
Tim,
I maybe wrong from time to time, and if I am, I would appreciate if members would isolate the disputed sentence so that we could tell with certainty whether I was wrong about the motor settings or wrong about the coupling options for the model in question? In any case, I had read that both loks were preset to 62.
AFAIR the Stummi post referred to differences in weight that may be the cause for differences in the performance of the individual motors and that some tweeking may be required to ensure proper operation in tandem.
Offline Loadmaster
#105 Posted : 14 March 2010 04:55:18(UTC)
Loadmaster
After listening to all the conversations about this set, I guess I need to exercise my credit card for the purchase of the set.
Robert
Offline TimR
#106 Posted : 14 March 2010 06:48:08(UTC)
TimR
Indonesia
Sorry, Mike... only referring to adjustment of digital parameters of both loks..
I'm used to running MFX; so hardly pay any attention to decoder address.
In my observation,
actually even two identical loks with exactly the same motor and drivetrain can drive at slightly different speed even if all parameter settings are the same.
Even with a precision motor SDS; this is sometimes the case... with 5-pole motor, a lot of other factor come into play.. ie; state of lubrication, how the motor is assembled (yes, factory new lok can ran choppy depending on how much they screw up)..
So in a way, the Stummi finding is not that surprising..
Offline Guus
#107 Posted : 14 March 2010 18:03:07(UTC)
Guus
Hi Mike,
In reply to your question on a comparison between a Märklin Re 6/6 and a HAG Re 6/6, I've shot a couple of pictures for you.
I received my 37320 set yesterday and must say I'm very pleased with Märklins long awaited version of the Re 6/6.
Both locomotives of the 37320 set have their own digital address, 44 and 62 respectively, or alternatively log-in individually via mfx with the appropriate mfx equipment. As has been mentioned before by other members the locomotives are designed to be operated together. If problems arise, it is suggested in the product booklet that the Vmax and Vmin of one of the locomotives is adjusted to the behavior of the other locomotive.
Left Märklin Re 6/6; Right HAG Re 6/6
HAG Re 6/6 Rapperswil
Märklin Re 6/6
Roof layout, note Märklins prototypically "correct" orange wiring
edit:18-05-2010: added pictures of details of the two locos
HAG Re 6/6
Märklin Re 6/6
Märklin Re 6/6
HAG Re 6/6
HAG Re 6/6 coat of arms position
Märklin Re 6/6 coat of arms position
Märklin middle bogie construction
Märklin Re 6/6 cab I
I realize that the pictures aren't of top quality but I hope you can get an idea of the differences between the two brands.
Edited by user 18 May 2010 21:38:42(UTC)  | Reason: Not specified
Kind regards,
Guus
Offline Guus
#108 Posted : 14 March 2010 18:48:11(UTC)
Guus
Maybe not the specific site you have in mind, however I think the one I often visit is a valuable source of information on the Re 6/6 and Re 620:
http://www.re620.ch
Kind regards,
Guus
Offline bmcrae
#109 Posted : 14 March 2010 20:03:29(UTC)
bmcrae
Hi Guus. Thanks for the pics. Nice to see you again, sorry no email contact for a while but soon I can find some time I hope.
Cheers!
#110 Posted : 14 March 2010 20:16:04(UTC)
You have been a member since:: 21/10/2004(UTC)
Very good, Guus.
Hopefully mine this week.Smile
Offline TimR
#111 Posted : 15 March 2010 01:38:56(UTC)
TimR
Indonesia
Thanks for the pics, Guus..
Gotta say, I think the Marklin version is still the best looking of the bunch... (might be just so used to the common Marklinism BigGrin)
Wife finally given the green light to order a 37321...
#112 Posted : 15 March 2010 15:20:15(UTC)
Nice to hear from you again Guus. The Marklin does look the better of the two and I expect will also be cheaper.
dave
#113 Posted : 15 March 2010 15:37:18(UTC)
37320 arrive mine today - too heavy set, Photo later.
Offline MarioFabro
#114 Posted : 15 March 2010 15:51:29(UTC)
MarioFabro
Thanks Guus... eagerly awaiting for my set Drool should be on its way from Germany (we always have to wait a few more weeks here in the US but .. no VAT Razz 37321 should also be forthcoming! ThumpUp
All in all, my status is Woot
#115 Posted : 15 March 2010 18:36:43(UTC)
Here is the picture.
http://steventrain.fpic.co.uk/p63735586.html
Offline pserup
#116 Posted : 15 March 2010 19:17:33(UTC)
pserup
A few weeks ago I was convinced I had to have the 37320 set, but now I'm inclined to wait and see if M will release a green Re6/6 next year which I will then hook up with my green Re4/4II. Reading previous posts I can't see what is gained from buying this rather expensive set...
37321 on the other hand is a must Razz
#117 Posted : 16 March 2010 02:03:42(UTC)
@pserup,
I don't foresee another green Re 6/6 in the near future. I think that it is more likely that we will see a Re 6/6 in red, either with round or square headlights, possibly as early as a Summer or Fall New Item and most certainly by next year.
It was interesting to note that neither the Re 6/6 nor the Re 620 (Cargo) were released as Trix models this year, so I would expect to see at least one of these as a Trix Summer or Fall item, much in the same way as the RABe EC was announced last year.
A green Re 6/6, probably with rectangular headlights will likely be the next model in that colour.
If you are interested in a Re 6/6 in green, you may wish to go for the current model. I have seen the Re 4/4IIs being listed on eBay for up to 179 EUR and with the white LEDs, it may be a better seller than some of the earlier models.
I wonder whether Maerklin will release other Re 10/10 Sets in the future?
#118 Posted : 16 March 2010 02:39:16(UTC)
I do have to question how the Re 6/6 will be a sucess for marklin from a marketing perspective, considering almost every other oem already makes one.
I know Markling coming out with one HAS to hurt HAG as there is now an alternative in metal for less $$, but will the HAG and Roco alternatives effect Marklin's sales?
Offline TimR
#119 Posted : 16 March 2010 04:51:41(UTC)
TimR
Indonesia
Your question is a valid one.
I am concerned with the fact that despite being a late arrival in the market with Re6/6 (and its price); Marklin simply do not deliver it with the best available package that are available to them.
A glass half full?
Even a 37321 is about the same price as a 39235 (a steamer of, arguably more expensive looking design and SDS propulsion).
Undoubtedly, 37320/37321 will be a sales success with Marklin customers, at least for now, as the 3-rail AC market is quite entrenched somewhat - we tend to favor Marklin alternatives, although I recognize a growing number of buyers favor a pick-and-match to replace some Marklin OEM stuff with that of other brands.
But the real test will be the reception of the Trix DC version - which I seriously doubt will be a runaway success.
Offline MarioFabro
#120 Posted : 16 March 2010 14:21:54(UTC)
MarioFabro
mike c wrote:
... I think that it is more likely that we will see a Re 6/6 in red ...
I also think that a red one will be next.. if history teaches us something with Marklin.
Mike, I have a couple of questions for you:
- the 37320 RE 10/10 green is listed as era IV. Do you still see them in era V or VI? I think you can still see Ae 6/6 and Re 4/4 II in green livery on the SBB network today.
- how about a red combination? Era V-VI?
- with the 37321 Re 620 Cargo could I couple a 37345 Re 420 in the same livery? Would it be prototypical?
Offline vilithejou
#121 Posted : 16 March 2010 14:43:27(UTC)
vilithejou
MarioFabro wrote:
Is this prototypical?
http://www.railpictures..../1/4/6814.1066143720.jpg
In Swiss the combination is unimaginable!!! You can put all with all!!!
Joan Vilarrúbia
vilithejou@yahoo.es
Fan of Märklín, Kroko lover
#122 Posted : 16 March 2010 18:37:48(UTC)
I'm with you 100% Tim, I think the trix version will be an extremely tough sell. Lets hope they get some mileage out of the AC mold!
I'm doing my part- I'll be buying the 37321 and if they do an RE 10/10 "Cargo" set in the future I'll take that too. (already have the HAG ones in red and green.)
#123 Posted : 16 March 2010 18:50:34(UTC)
I have test the 37320 RE6/6 front bogie have few derailment on 1st radius 24130 curved.
No problem on 2nd radius onwards, Turnouts etc. I think the front and rear bogie very hard tight on 1st radius curved.
#124 Posted : 16 March 2010 19:37:09(UTC)
The Re 421 (37345) are normally used for operations between Switzerland and Germany and operations in Germany. It is very rare to see a Re 421 coupled to a Re 6/6. In Germany, it is common to see 2 Re 421s coupled together or combined with a Re 482 to pull a freight train.
The photo does show a Re 421 coupled to a Re 6/6. This is not a normal combination. The photo may have been taken at an exposition or other special event. The caption at the bottom of the photo when viewed through the normal window of railpictures.net, indicates that the photo was taken at Luino (IT) in June 2003. The Re 421 differs from the Re 420 in a few aspects. The end railings were modified to suit German regulations, a DB pantograph and safety equipment were installed. A Re 420 is just the new designation for the original Re 4/4II. The Re 4/4III, with it's slower top speed and greater tractive power is now known as Re 430.
#125 Posted : 16 March 2010 20:05:01(UTC)
I am surprised that you have any problems with the front bogie, as it is likely the same bogie as the one used on the proven Re 4/4II. Is it possible that the cable for the slider is somehow interfering with the rotation inside the chassis? Have you had the same problem when the lok is reversed and driven through the switch motor bogie forward?
#126 Posted : 16 March 2010 21:12:31(UTC)
Hi Mike,
Problem solved as no derailment after run 10 times on 1st curved. Just derailment on first few 1st radius.
#127 Posted : 16 March 2010 21:26:51(UTC)
Review of 37320 and pictures now on Cave forum.
#128 Posted : 16 March 2010 22:12:03(UTC)
And now we are waiting for it to appear here... Wink
Offline 7gauges
#129 Posted : 17 March 2010 15:17:09(UTC)
7gauges
5HorizonsRR wrote:
How are the locomotives set up to run together? it seems like they are two independent locomotives. Can they run individually without each other? If so, how are they set up to run together- 2 decoders with the same address as CV values synched?
I just received this set yesterday. Very nice. I do wonder why they didn't include any sounds, it would have been a great feature.
One odd effect, my CS2 60214 with the latest update would not allow the MFX locos to be registered individually, I had to put both engines on the track before the CS2 would recognize their existence. The manuals say that the locos have two different adresses 44 and 62. So in essence I could never run this set apart, right? I find this very strange. I am curious if this is a CS2 feature I missed. What I also found strange is that I can't see the decoder settings at all. The pair of engines run fine and are perfectly synced - but I doubt I would run them together all of the time.
Edited by user 17 March 2010 21:44:52(UTC)  | Reason: Not specified
Offline Guus
#130 Posted : 17 March 2010 16:33:04(UTC)
Guus
Could you elaborate on that please. The Re 6/6 has a sound module and speaker.
Kind regards,
Guus
#131 Posted : 17 March 2010 18:12:51(UTC)
@7gauges,
the Re 6/6 is equipped with sound module and speakers, as Guus stated. The Re 4/4II is the same model as the 34/3734(X) series. No sound module has ever been offered on a Re 4/4II as the circuit board and metal frame were not developed with enough space to permit the installation of Maerklin's sound module. It is possible that some future modification to the model might permit this.
I don't have the CS2, let alone a CS. I am still using my trusty old 6021. I do know that the CS2 is supposed to allow for consisting, so you can link two decoder addresses together so that two loks can be operated as a MU. Previously, the decoders had to be set to the same address, which is how Hag's Re 10/10 Set is delivered. Changing the Lok Address is easy, even with a 6021.
If you want to alter the CV settings, make sure that you have only one of the loks on the track at the time.
I am waiting for my Set and will do some tests when it gets here. I am looking forward to operating the Re 6/6 as a solo lok with one of my DB, FS or SBB Schnellzug/IC trains. I think that it will only run infrequently as a Re 10/10 on my layout.
Offline 7gauges
#132 Posted : 17 March 2010 21:51:02(UTC)
7gauges
I suspect it has something to do with the fact that the MFX only registers both engines as a 4/4 and doesn't see the 6/6 or any of its functions.
I am really having a hard time with this one ... I may hook up to an MS1 and see what happens - I am starting to wonder if the Marklin folks set up the 6/6 with the electronics of a 4/4 .... because that is all the CS2 sees. Surely marklin can't screw this up!
Offline Guus
#133 Posted : 17 March 2010 23:12:39(UTC)
Guus
Both locos register as expected with my MS1, both individually with their assigned name. I don't own a CS yet, but what I do know from my dealer's CS is that it sometimes takes a considerable amount of time for a new locomotive to register properly (last time I checked a new loco more than 2 minutes). I presume you've also read the remark in the instructions about multiple unit operation.
Interesting problem, please let us know what you've found out.
Kind regards,
Guus
#134 Posted : 18 March 2010 01:09:32(UTC)
I wonder if it is possible that the two are already preprogrammed to register as a consist on a CS2? One question again, were both or just the Re 6/6 on your track when you tried to read the lok settings?
If they are programmed as a consist, then it makes sense that outwardly, the two would be seen as a Re 4/4.
Hopefully one of our digital experts can weigh in on this one. I might know a lot about Re 4/4 and Re 6/6 but I know next to nada about MS and CS as I still use my trusty old 6021.
Offline TimR
#135 Posted : 18 March 2010 01:52:46(UTC)
TimR
Indonesia
Hi..
With MFX controller (CS/MS/CS2/ECoS etc); each individual MFX lok would automatically be assigned an address by the controller so there is no possibility of address conflict.
In the case of 37320, even if both the 6/6 and 4/4 II got assigned the same address from the factory, each would be assigned an individual address, so there is no way that they can be registered as a consist from the word go.
In FX setting (or ordinary Lokpilot) I can see the sense why Roco or Hag would assigned them the same address, but with MFX it is irrelevant due to controller-decoder relationship.
Setting up consist have to be done manually in MFX. Both still kept their individual address; but the consist basically called up both address at the same time. If you call up the consist, both lok would respond...
Ok, so didn't really explain the problem other than it is indeed strange how both loks registered as 4/4.
Offline 7gauges
#136 Posted : 18 March 2010 03:12:28(UTC)
7gauges
As someone already pointed out - no issues at all with both loks showing up on the MS1, as individual MFX loks with different functions - no idea why they both register as a 4/4 on the CS2 without sound functions (and without some of the lighting functions as well).
I tried to register them individually, at first on the CS2 - the CS2 timed out and said it couldn't read the 6/6's address - it did read the 4/4's and will still run the both of them as 4/4's.
I am truly mystified. I cant even read the decoders. I did try other MFX and DCC loks on the CS2 and had no issues. Is there an auto-consist feature that is turned on by default in the CS2? If there is I am at a loss to find it.
On another note - this RE 10/10 is truly a visual and operating prize (when not hooked up to the CS2)- I am very impressed. Good job M!
I think there is some setting on the CS2 that is F'd, and with that awesome documentation (not) it came with, this could be a bit of test.
#137 Posted : 20 March 2010 03:45:28(UTC)
I think you should check the section in the CS2 instructions dealing with consisting. It is possible that the Set was delivered so that the CS2 would recognize the two as a consist. That would perhaps explain why both were showing in normal mode as the same lok. If I am correct, you can disable the consisting feature and the loks should then show up as individual loks, each with their own tag and lok id address.
Offline MarioFabro
#138 Posted : 23 March 2010 18:40:15(UTC)
MarioFabro
Any pic on 37321? Mine appears to be in the mail from Lokshop
#139 Posted : 23 March 2010 18:56:50(UTC)
Have a look at large picture on ebay (MS-Toys).
http://cgi.ebay.de/MS-TO...hnen?hash=item53e05a0076
#140 Posted : 23 March 2010 18:57:47(UTC)
I ordered my 37321 from ETS the other day, I've only seen the pics of the one Station500 had on ebay. I'm looking forward to it!
Offline jeehring
#141 Posted : 24 March 2010 04:13:05(UTC)
jeehring
Guus wrote:
Hi Mike,
looking at the first photo ,both look great, I like the Marklin RE 6/6, once again because the global appearance is a little less toyish and looks more real, also how they deal with the glass of front lights is a good point : more realistic.
Edited by user 24 March 2010 14:44:24(UTC)  | Reason: Not specified
#142 Posted : 24 March 2010 04:27:56(UTC)
jeehring wrote:
looking at the first photo , I like the Marklin Re 6/6 once again the global appearance is less toyish and looks more real, also how they deal with front lights : more realistic.
I have not as yet received my 37320, so I have not had the chance to have the model in hand. I am looking forward to setting it down next to my Hag and Roco models and will provide a head to head comparison when I receive it.
I am not certain what you are refering to in regards to the front lights. I know that Hag did have a problem with light shining through beneath the motor bogie.
The light emitting from the Maerklin Re 4/4IIs is rather diffuse, compared, cay, to my old 3050 which emitted clear beams that could be seen on the layout. The Hag New Generation locomotives also have this feature. It involves milling of the light channel/lens so that the light is amplified and focused into a beam. This feature seems to have been dropped in Maerklin and many other models, likely as a cost cutting measure starting in the 1980s. I would be interested in more details about your comment about the lights.
Once I have received my Re 6/6, I will be closely examining all three models and comparing them to the photos and information that I have from the SBB, SLM, BBC and on the web. I am more interested in running the Re 6/6 with one of my passenger trains, as I don't normally run trains that are long enough to require a Re 10/10. My green and red Hag Re 6/6s are analog only. I can only use my 3 Roco Re 6/6s in digital operation. For freight trains, I already have two Hag Re 620s in the Cargo livery that are digital ready.
(Maybe one day, I will put all my container cars together to make one long train with a Re 10/10.)
If anybody has both the 37320 and the 37321, can you confirm that the decoders are different? Are there any other differences between the two models? (Other than the lights)
Offline jeehring
#143 Posted : 24 March 2010 04:49:12(UTC)
jeehring
on the picture the lights are swiched off.
I'm talking about the external appearance: the glass of lights. Into model-making it always has been a hard subject : how to make them more realistic.( model makers could confirm, I think...!Wink ) The glass of lights is one of the reasons why many many MRR models look toyish (also car models, etc....)...
I like the way they did on Marklin RE 6/6 (on the photo above: IMO better than on Hag model)
About this particular subject, generally Marklins are good, they are above average by comparison with other industrial manufacturers.
IMHO those kind of details - skillness, know how, painting - are more important than things like : exact lenght at scale, 1 cm missing or 1 cm over, etc, etc...
If you take some models from MicroMetakit you will see that lights are even not functionnal !( expensive models , 2500/3000 E for 1 model !). The reason is : Micro metakit considers that it is not possible to make realistic appearance with miniature Bulbs or LED...they use some special material: the result is astonishing ! (but not functional OhMyGod )
Edited by user 24 March 2010 14:46:49(UTC)  | Reason: Not specified
#144 Posted : 24 March 2010 21:49:39(UTC)
No problem, Juhan.
Marklin Swiss Twin electric loco set, Total weight 1.5kg included package.
RE6/6.
Model weight - 650g
Lenght - 222mm.
Sounds - Blower/Whistle.
Decoder + Motor = MFX with high-efficiency propulsion.
Derailment - Some few on 1st radius but no problem after.
Childen? - Age 14 and over.
Coupling? - front and rear.
Headlight? - Three at front and three at rear white LEDS.
Loco body - Metal.
6021 address coding - 62.
60212/3/4 Name at factory - RE 6/6 11687.
Traction Tyres? - Four on motor bogie.
RE 4/4.
Model weight - 590g
Lenght - 171mm.
Sounds - No.
Derailment - No Issue on C-tracks.
Loco body - Metal.
6021 address coding - 44.
60212/3/4 Name at factory - RE4/4 II 11319.
Offline Hemmerich
#145 Posted : 27 March 2010 21:49:35(UTC)
Hemmerich
steventrain wrote:
RE6/6.
Model weight - 650g
RE 4/4.
Model weight - 590g
Can't confirm any of this - Re 6/6 weight is 679g, Re 4/4 weight is 531g (measured on different scales with +-1g Tol.)
PS: An excellent product review has been published by the Modelleisenbahner magazine; they too confirm the very good running performance in a MT; also easy to adjust.
But knowingly quite some bs was and still is published by people who never had these models in their hands.
BTW: Auto-registration of both locos with a CS-II works seamless and very quick (as usual), regardless whether they're placed onto the track simultaneous or individually; there is also no predefiniton of a MT.
#146 Posted : 27 March 2010 22:07:54(UTC)
steventrain wrote:
Lutz,
I think that this is why some of the members reported the Re 6/6 showing up on the CS2 as Re 4/4.
It is labelled as Re 6/6 but look carefully at the photo of the lok on the left.
Offline TimR
#147 Posted : 28 March 2010 01:06:27(UTC)
TimR
Indonesia
Your advertising of the quality of Marklin's flawless engineering and technical excellence would have been much more successful and productive had you not always taken the opportunity to take a swipe at other member's opinion in 99% of the posts that you make.
Offline 7gauges
#148 Posted : 28 March 2010 03:44:36(UTC)
7gauges
Yyou again show yourself as an arrogant "Arsch mit Ohren" with that kind of comment.
Point of fact - there is a known issue with registering these engines and it was tied to the latest update of the CS2.
If you have nothing useful to say F-off and quit being such a twat.
Edited by moderator 29 March 2010 21:03:40(UTC)  | Reason: Not specified
Offline seatrains
#149 Posted : 28 March 2010 06:59:24(UTC)
seatrains
Steventrain, excellent information, excellent pictures, nice layout, Thank you..
Thom
#150 Posted : 28 March 2010 11:49:39(UTC)
7gauges wrote:
BTW: Auto-registration of both locos with a CS-II works seamless and very quick (as usual), regardless whether they're placed onto the track simultaneous or individually Go to Quoted Post
It has been quiet for a week or so. No Lutz Postings. DO you think he had a vacation somewhere where there was no internet? and is a bit emotional about returning home and being able to advertise his views.
NN
Guest (13)
4 Pages<1234>
This page was generated in 1.219 seconds.
